Jacking points
Every time i jack up my 911 3.2 on a two post ramp on the four points under the car it always takes the under seal off,I have four rubber blocks with a slot in them so the pinch welds go in them and not bend them up.
HOW DO YOU JACK CAR UP WITHOUT DAMAGING THE UNDER NEATH.
Old 03-03-2019, 09:37 AM
Anyone
Old 03-04-2019, 04:07 AM
Maybe try a different brand jack pad? Parchment paper?
Is the undercoating adhering to he jack pad or cracking and falling off?
Old 03-04-2019, 04:15 AM
Uncertifiable!!!
Uwon's Avatar
There are 10mm (check size) threaded holes at each corner of the belly pan, just next to the pinch welds. Get yourself four hockey pucks, drill out the centre, including a recess for the bolt head and screw them in. As I recall, on one corner I also had to saw a slit on the puck as the threaded hole is too close to the pinch weld.
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 03-04-2019, 04:42 AM
(man/dude)
Jonny042's Avatar
Some pics of mine in this thread:
Custom hoist/lift support pads
Johan is correct in that they are 10mm bolts. I had to bevel the edges that sit against the body at the rear.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 03-04-2019, 05:05 AM
Hi
I don't have these 10mm holes on my car
Old 03-04-2019, 05:50 AM
(man/dude)
Jonny042's Avatar
Later 3.2's had jacking points welded to the body but if your car had those you probably wouldn't be asking the question. Guessing you have an early 86 or older.
Your car has the holes, they are covered/filled with plastic plugs. Look carefully in the locations pictured in the other thread and you'll find them.
Old 03-04-2019, 05:58 AM
Mines a 1983 3.2 one of the first
Old 03-04-2019, 05:59 AM
7783911's Avatar
Do I need to use Montreal Canadian pucks?
Old 03-04-2019, 06:07 AM
Recreational User
porschenut's Avatar
You're in Ontario so you'd use Leafs pucks.
Canadiens. Or just call them Habs.
Old 03-04-2019, 06:30 AM
Flojo's Avatar
Originally Posted by Jonny042 View Post
Later 3.2's had jacking points welded to the body ....
they still do exist in the parts list and you can order These to weld them to the car.
I thaught about it many times to do it...
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 03-04-2019, 07:01 AM
7783911's Avatar
well, thats a quandry...original montrealer..so big decision
Old 03-04-2019, 07:33 AM
I need to order these parts, as I'm missing one... do you know what the part # is?
1987 Porsche 911 Carrera Coupe
Old 03-04-2019, 07:37 AM
It is one of the many little annoying design "flaws" that the earlier Carreras did not have a jack pad anywhere. I have a scissor lift. I use it for a lot of tasks that don't really require a lift, but having the car up higher and not bending over is a lot easier on my back. Even a task like waxing the car is a lot easier when the bottom of the door is at a comfortable height when seated on a roll around chari.
Anyway, I use the slotted pad on the pinch welds up front. It is a slow process to get the lift pad of the scissor jack up close to the seams, but it is fairly easy after many time of doing it. In the rear, there is a flat area under the torsion bar that is perfect for a standard hockey puck to fit.
I have thought of having a lift point tack welded on to make it faster to lift the car.
Old 03-04-2019, 09:10 AM
Vintage Owner
Jack Stands's Avatar
Could these be the parts shown as #25 on the illustration? 999 103 125 shows as 4 used on the car. 40
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 03-04-2019, 07:03 PM
Uncertifiable!!!
Uwon's Avatar
I agree with Jonny as both my ‘86 nd ‘78 have the threaded holes.
Johan
Old 03-05-2019, 03:44 AM
Flojo's Avatar
These are just the plugs to fill the bores/thread.
Old 03-05-2019, 04:57 AM
Jonny042 thats a nice looking floor on your car.
do you have any other photos of it.
Old 03-05-2019, 07:16 AM
Flojo's Avatar
we are going t make these alloy pucks soon.
here is a prototype fitted to a friends ST-tribute build
Old 03-05-2019, 10:50 AM
7783911's Avatar
Flojo..idea on when and cost? Includes bolts to mount?
Old 03-05-2019, 11:02 AM
