Installing RS panel and this happened
I am installing RS door panels and I have this mismatch on the bottom where one of the the screws go. Actually I think another one is going to be the same. Any ideas, it is off by about 1/4" The black thing is the door panel and it is located by those plastic clips so the panel really cant be moved around.
1988 Carrera coupe 1966 250 Ducati 2015 VW Golf TDI gone because Dieselgate! 2021 VW Golf TSI 2014 Ninja 300 |
You can either drill an new hole in the door, in the panel, or use one of these fasteners...
Enlarge the hole and use a rivnut. Even though the hole is now somewhat oval it should work since there’s so little load on the fastener.
Sent from my iPhone using Tapatalk |
Guest
Posts: n/a
mine ('76) secured into a piece that backed up the door panel and move side to side at least a 1/2"...
1971 914-6 GT 3.6 1974 911 1976 911S leaf green backdate 3.2 |
disband
are all the fastener loose? if not try loosening everything and slightly tighten in a circular pattern around the perimeter after seeing if it will offending fastener will go home. see if each one can give a little to make them all line up enough
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Been here a while
as others have said, on my cars, the nuts in the door are mounted in slots (sort of) so they have some play or movement to them, a fair amount as I recall. Not all that different than the seat mounting points in impact bumper cars.
looking for 1972 911t motor XR584, S/N 6121622 |
