Any decent shop or electronics person can change that connector. And the pin crimp-er tool is nice but not required. The pins can be crimped carefully with needle noose pliers and then soldered and shrink tubed. Again, decent electronic skills needed here.
You don't need a pin extractor tool if you plan to replace the pins and the connector, you should replace both. Just cut the old connector off and install new pins then seat them into the new connector. Also worth mention is that those wire harnesses have a shielded braid that MUST be also connected to a pin.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
I could have sworn I found the harness side connectors here on the host, but can’t locate now?
These connectors are called 'Junior Power Timer' or 'JPT' and the one you need is 3 pole.
Search for "junior power timer connector 3 way" you will find them.
Car runs GREAT otherwise. We tried a new two wire CHT sensor, but that didn't solve the problem (switched back to the previous two wire CHT) and I've been casually troubleshooting the issue, including unplugging the CHT sensor and jumping the CHT sensor (no change in either case). The motor has an @salcarceller MAF / injector / ECU setup, but that was on pre-rebuild and the hot start problem started with the rebuild. @KTL your BMW flywheel set screw issue is interesting. We did replace both flywheel sensors, but we also installed an Aase lightweight flywheel as part of the build. I wonder if my issue is heat related with the set screw or set screw sensor. Could the gap grow enough at full operating temp to cause the no-start, but 10 minutes later shrink enough to allow starts? I believe I need an oscilloscope to test the flywheel sensor outputs? Alas, I don't have one and I wouldn't know how to use it if I did. Apologies for the tangent here.
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
You can test the sensors with a multimeter for resistance any open shows bad, i heard you can check with the ac function and crank the engine should show some AC voltage
Do you have spark during the no start? Just remove center wire from Dizzy and put a test plug on it, does it spark during cranking?
If you have spark then your Flywheel Sensors are fine. If you have spark, then spray 2 shots of starter fluid into the intake and try starting. If she catches you have a fuel issue! Quote:
Like I said, I've been *casually* troubleshooting! It hasn't been a huge issue, save for fueling up on the back end of a drive. On the front end, I can start the car, drive a few miles to the gas station, shut it off, fuel up and it starts right up again, no problemo. I am extra diligent about not stalling the car in traffic though. That would SUCK!
Schleprock
I don't think the heat is great enough to cause the air gap issue with the reference sensor. We've run our Carreras on the track on very hot days and never encountered any hot no-start conditions
When you guys did the rebuild, did you install new reference sensors or reuse the old? I'm just wondering if they are old enough to have some issue with the wiring itself. Try messing with the two black connector wires where they lead out to the actual sensors on the back of the engine? How old is the fuel pump? They can be pesky with age as well.
Kevin L '86 Carrera "Larry" |
As far as I know, fuel pump is original. I've got some troubleshooting to do. I've just been having so much damn fun driving the car. Thanks for the ideas!
Revised diag steps:
- During no start event 1. Turn key to RUN but do not start engine, then verify that the idle control valve is vibrating and humming. 2. Test for spark 3. Spray starter fluid into intake Do them in that order, if one of those steps fails do not move on to the next step.
To reduce possible pin corrosion in this often-times wet environment, apply dielectric grease to those contacts.
Sherwood |
I had one pair of sensors that only lasted a few years. After those few years it was like the car was haunted. The sensors would read fine with a ohm meter when cold. Once they warmed up they would on occasion get flaky. I finally replaced them after every other test and that solved my problems.
Once removed it was easy to test them hot and one of them would cut out. It was weird. I was happy to throw them out.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
FWIW, I replicated the issue yesterday and was able to ascertain the following... 1) thanks to Sal's fuel pump prime feature in his ECU, I could at least hear the pump running during every subsequent restart attempt and 2) I connected my Fluke up to cylinder 3 spark plug lead, to check RPMs, and it showed ~300 RPM during no-start / cranking. I assume the latter qualifies as "having spark." Will confirm IAC valve operation and attempt starter fluid test next time. FWIW, here's another thing, while the car is failing starting attempts and when it eventually starts, I smell something difficult to describe and, more importantly, something I've never smelled before in 30 years of being around cars. It isn't unburned fuel. IDK what it is. It's pretty pungent tho. After the car finally starts, the smell quickly disappears. Anyone have an ECU breakout box I can borrow? OTC 3226, or the like? I'd love to take reference sensor measurements.
https://www.pelicanparts.com/cgi-bin/ksearch/pel_search_2016.cgi?command=DWsearch&LastVisited_input=0804&make=POR&description=022906233B
Wow 15 dollars for a 5 cent piece of plastic! |
Frank
Does it smell a little like rotten eggs ? |
It’s a bit dear, but not when you account for all the factors. I hear you though, the tally adds up as you start fixing things!!! Eye watering at times... |
Not particularly. It has more of an acrid quality.
Also, currently running a pre-muffler, so not a cat issue.
The BMW crank sensors work in the 84-89 3.2L and they are Bosch OEM sensors at reduced price. The part number for the BMW sensors is:
Bosch # 0.261.210.002 about $80 Pelican has them: https://www.pelicanparts.com/More_Info/12141708619.htm?pn=12-14-1-708-619-M14&bc=c&q=0.261.210.002 The Porsche Bosch sensor # is 0.261.210.005 about $150 The only slight difference is that the BMW sensor harness is a tad longer. I've used the BMW sensors in the past with no issues other than a few dollars saved.
