Porsche Crest 3.0l CIS upgrades?
3.0l CIS and need guidance/suggestions on upgrading HP
Old 06-12-2019, 02:07 PM
Vintage Owner
Jack Stands's Avatar
Have you seen Bruce Anderson’s book? I think that other than changing to 964 cams or increasing displacement, your options are limited with the CIS injection.
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 06-12-2019, 02:15 PM
believe swapping to a 2 out (e.g. ssi) exhaust helps out too.
Kwalls, welcome to the forum -- looks like you've already hotrodded your SC -- what have you changed up on it so far?
Old 06-12-2019, 02:21 PM
I have not looked at his book but, will check it out! I'm thinking of 964 cams and going with PMO's just not sure if the cost levels with the gain in hp?
Old 06-12-2019, 02:32 PM
Love this forum! The car has had the following from the previous owner:
- engine rebuild & gearbox
- 16x7 & 9 fuchs
- open can sport muffler
- suspension upgrade
Super fun and I have a lot to learn
Old 06-12-2019, 02:48 PM
Switch to 15s. Did I beat Bill to it?
Ass-engine Nazi slot car -- PJ O'Rourke
Old 06-12-2019, 02:50 PM
Trippyloaf's Avatar
What’s going on here? Looks like it might be setting you back.
Old 06-12-2019, 06:04 PM
LakeCleElum's Avatar
Kay Wall(s): In my 73.5 with short gears:
My 3.0 with CIS is reportedly making 209 HP at the rear wheels. Here is a copy of the ad from when I bought the used engine: Note is has high compression 3.2 and early exhaust also:
Recently removed upgraded '81 SC engine and transmission from my '81 SC after car was damaged in front, causing parting out the car. Upgrades include 1) Max Moritz 3.2 liter pistons and cylinders, 2) 964 cams, 3) Raceware hardware, balanced rods, Carrera oil pump. New parts included: intake valve sleeves, rod bearings and rods balanced, and rocker arms.
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 06-12-2019, 07:08 PM
disband
juanbenae's Avatar
carbs are the best way to get more HP out of a CIS equipped car....
especially is you are already considering cams.
Old 06-12-2019, 07:34 PM
Under the radar
Trackrash's Avatar
Especially if you replace the pistons as well....
Gordon
'71 911 Coupe 3,0L outlawed
Old 06-12-2019, 07:45 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Old 06-12-2019, 08:40 PM
Still here
pmax's Avatar
Old 06-12-2019, 09:53 PM
Jonny H's Avatar
See post 206.
Classic Retrofit CDI+: Dyno Results
www.classicretrofit.com
Old 06-12-2019, 11:23 PM
Bill Douglas's Avatar
SSI exhaust system adds some HP and loses weight from behind the back wheels.
Old 06-12-2019, 11:45 PM
Flojo's Avatar
SSI and Max&Moritz-tuning with 3.2 Pistons
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 06-13-2019, 01:35 AM
Nux Nux is offline
Nux's Avatar
+1
although a little expensive, this is a well proven and plug & play solution with no other mods needed. About 220-225hp.
Old 06-13-2019, 02:54 AM
Crotchety Old Bastard
RarlyL8's Avatar
We supply modified CIS components for race cars. The fuel distributor is modified for higher flow and the WUR can be made adjustable if needed to compensate. This is generally done to satisfy spec class rules. If your class has no rules on induction then carbs will give a bigger bump. The difference in fuel mileage and smoothness is noticeable however and a consideration.
Old 06-13-2019, 06:44 AM
disband
juanbenae's Avatar
Originally Posted by pmax View Post
OK pnutz, that one made me laugh out loud....
Old 06-13-2019, 08:41 AM
You didn’t mention what year your SC is, but from what I’ve read, early (‘78/‘79) U.S. or euro CIS is a bit simpler and flows better, and will better compliment the 964 cams, higher compression stock pistons & cylinders (or Max Moritz 98mm), SSI’s, exhaust, etc..
If you find additional coin, a 915 with shorter gears, or R&P swap can enhance the mechanical advantage as well.
Good luck, an SC on a bit of a diet with a slightly tweaked engine can be fun and reliable...
Old 06-13-2019, 03:09 PM
Also the 3.1 kit and Webcam 20/21 grind
Old 06-13-2019, 03:27 PM
Tags
cis upgrades , engine 3.0 , hp increase , modifying
