+1 on auto-off headlights, inflatable adjustable lumbar support for those longer drives. I love the analog feel and smells of air cooled 911s. Can’t change that!!
Northeast Ohio 1987 Porsche 911 Targa 1966 VW Beetle, 6V |
I wish the 915 transaxle was on par with a g265 trans/188mm diff from a BMW of the era. They are silky smooth and handle loads of power for boosted application. Essentially I guess a g50 swap but the cost is just too much to be justified.
The stupid phillips head bolts that hold the rotors to the hubs. I replaced mine with allen head ones when doing my brakes, but it would still be nice to have had them "from the factory". Not that mine functions badly but just a nicer quality feeling turn signal. It feels likes I'm going to break it if I do anything with it haha.
1986 Supercharged 911 - 3.3l, MS3 Pro, full sequential, Vortech V1 s-trim |
Formerly known as Syzygy
This should be already the case - your headlights should turn off automatically when you turn off the key. But I know what you mean. The parking/running lights will stay illuminated. But, this is can be changed without much trouble. It's a 10 minute job if you've ever taken out your headlight switch. If you haven't, then you can expect to double that time. Our headlight switch is a wonderful piece of simple wiring/switching gear in our cars. Power goes in and depending on the position of the headlight switch (off/position 1/position 2) and the ignition key (off or run), it will direct that power to a number of different standard sized terminal pins located on its back. ![]() If you take a gander at this little matrix I made up a few years back, you can see which conditions send the power to which terminals. You can see that the headlights should be ON whenever the ignition key is in the RUN position and the headlight switch is in position 2. Makes sense, right? But how to get the running lights to go off with the ignition key and on when you pull the headlight switch out to either on position? If you take a look where it indicates terminal N, you will see that it is only pushing power whenever the ignition switch is ON and the headlight switch is in position 1 or 2. Notice that I indicated on that chart N is for the license plate and ash tray lights? Go out now and check your car. Hit your parking lights only with the key off. All your corner lights will come on. Check the license light - should be dark. Now turn your ignition to the RUN position. Your license light just came on, yes? Cool right? So how will all this mumbo jumbo help your parking lights turn off with the ignition? Well, also refer to that same chart and you will see that the parking lights indicated (and wired) conveniently as 58R and 58L for your parking lights on the right and left (thank you Captain Obvious). Yeah, so what...? So if you move your parking light wires to terminal N, they will turn off with the ignition key. If you leave your headlight switch on any position, or if you forget to turn them off, all the lights will go out with the ignition key. One caveat and some advice: if you do this modification, it's probably a good idea to document which wires you moved from and to, perhaps with little labels behind the switch. ALSO, and this is important: be sure to move ALL the wires from any of the terminals that you don't want to run when the ignition is off that might run when the headlights are on. This includes anything on pin 30 which is HOT at all times and 58A which I think may be the dash lights, pin 58 and pin 57 which is for the little green light that lights up on your tach when you're driving about with just your running lights turned on. Anything that is on any of those pins that are energized when the light switch is in any position other that off will be energized if they aren't also moved to pin N. EDIT: Just to be clear, your headlight switch still has to be on for your headlights to work but it wouldn't have to be turned off as they'd go out with the ignition switch off. And there will be quite a few wires to attach to terminal N, so you'd have to use bridging clips or MacGuyver something together to get them on there. Good luck to anyone trying this out. Think about what you're doing before you do it and test, test, test, because it would really suck to want to go for a drive and have a flat battery because your glove box light has been on for the last couple weeks...
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. Last edited by Canada Kev; 06-18-2019 at 05:24 AM.. |
Wow, that's a really great idea! I had to make a run to a local FLAPS to buy one of those manual impact screwdrivers when I rebuilt my parking brakes so I could get the rotor off. I still buggered up the screw and had to replace anyway, but using an allen head would have been a better idea than just using another philips screw.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
![]() Sent from my SM-G965U using Tapatalk
Some kind of switchable traction control would be nice, especially for rainy days. I know oversteer is part of the 911 experience, but it would be nice to have some help with it from time to time!
I also wish that the 3.2 cars had OBDII ports and diagnostics. Check engine lights are a pain in the ass, but those codes can really help track down issues and help make you aware of problems. And better sound would be great. Engine sounds are awesome, but sometimes you just want great-sounding music for your drive. It's wild how much better the stock sound systems in cars are nowadays compared to what they used to be. |
1988 Carrera
I would love to have a quite ride. Anything above 70 MPH and the radio is useless. I'm working on it.
88' Carrera 79' SC gone (lost to Katrina) 75' Targa gone 72'914 gone 72' 914 gone too |
Kevin,
Nice write up! Taught me something new, thanks!
Robert ----------------------------------------- "A man must consider what a rich realm he abdicates when he becomes a conformist." ~ Ralph Waldo Emerson ~ (thanks to Pat Keefe) |
Just FYI
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains |
Anyway, I would change the HVAC system because it doesn't make any sense.
IG@ADDvanced Youtube@ADDvanced www.gruvdesign.com |
+1 Kevin. Great suggestion and write up!!
The heat is simple, pull the levers, and adjust the lever to blow on your feet, or the windshield. Same with the fresh air, feet or windshield, but the fan control is from no fan to full blow. AC, is like any car, on or off and what fan speed, and the other knob is how much cold. You want the fresh air lever on top all the way to the left to prevent fresh outside warm air to dilute the ac cold air.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
More power, EFI...modern engine management, etc.....
https://www.youtube.com/watch?v=jul062yL-U4 regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
That’s simply not true at all. As can be seen in crash testing footage. Stretch and body momentum means that the your head can still hit hard surfaces. The only belts that restrain you enough are racing harnesses. The airbags act as part of an overall system to slow you down.
This is based on my 1975 911S Rat Rod. My ‘89 3.2 is being left alone as its pretty original, in good shape, and worth leaving original. Stuff I have done...the short list
What else might be nice.....
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
^The point is, airbags were designed to protect people who were (are) too stupid to wear seatbelts. Since I always wear seatbelts, I like not having a steering wheel airbag. Now, side curtain airbags--those are useful even if you are wearing seatbelts.
Quick story--my bro-in-law hit a deer going about 55MPH; the deer didn't slow the car down at all and he had a deployed airbag in his face. No bueno. |
Bigger engine, Better suspension.......the list goes on and on for me. The better solution is for Porsche to make a future 930X. I want a car with every modern feature that looks identical to my restomod and weighs 2500 lbs or less. A tall order but you said hypothetical.... I would pay new Porsche prices for that car.
1975 911s Restomod, 2005 MV Agusta F4 AGO, 2002 Moto Guzzi V11 Scura, 1983 BMW R100RT, 1978 R100S, 1989 R100RS, 1991 R100 classic (x2), 2023 Ford F150 Lightning SOLD: 93 R100R, 03 R1150GSA, 85 R100S Mono, 03 996 turbo, 16 Norton 961 Commando, 03 R1100s BCR, 77 R100s, 09 S63 AMG, 74 911, 88 R100RS, 78 930, 01 996 C4, 05 Cayenne, 09 Audi TT, 03 Moto Guzzi V11 LeMans, 07 WRX STI, 03 R1150GSA, 78 R100/7, 01 Audi S4, 98 Audi A4, 98 R1200c, 78 GL1000, 92 Accord, 89 KE100 |
You will have to start with the old tub, and do all the magic, and end up with a Singer and the insane price of a bespoke car, half a million and up.
Where can you get a carbon hood like that?
