LinkBack | Thread Tools | Rate Thread |
Got Boost?
Operation get 3.0 on Pick-Up truck: How much does a Carrera 3.0 engine weight?
I am going to have to conduct a highly classified operation to go into my mechanics shop and get my engine out of there. My intelligence sources are telling me that they may close out the place therefore rendering the place impossible to get into and possibly loose my engine.
My question is, how much does an Carrera 3.0(Similar to SC) engine weight? The engine has everithing on it, fuel injection ect. The engine is not attached to a transmission, I already managed to get the transmission out of there. I am planning on getting 2 or 3 friends to pick it up and dump it on a pickup truck. Is this feasable?
"The only motivation to make you go race after race, travel after travel, is winning. The possibility that you have for winning. If you don't have that, nothing else can make you work." -Ayrton Senna- |
I don't know how much a 3.0 weighs but My dad and my friend were able to pick up my 2.0T motor but it was a longblock., barely. A ramp and a comealong might be a better idea at least for your friends back's sake
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
We were able to pick my 3.0 from ground level and place it into an engine stand. It was about a 3 foot lift. 4 grown men were able to lift it, no problem. Just make sure to get a good grip somewhere, there are not too many good places to lift from. Guesstimate of fully accessorized 3.0 engine (fan, cis, and exhaust) is about 400-450 lbs.
May want to bring a dolly w/ castors to move engine from garage to truck, then just lift engine onto the bed.
Charlie Stylianos 1982 SC Targa www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles) |
Here is how I got my 3.0 into the bed of a 4X4 with two people.
I would think four guys in relatively good condition could do the job.
I put mine in the back of my van using steel pipe as rollers under the exhaust. Put a couple of 2x6 as ramps, but the engine at the bottom and lift put on of the pipes under and roll up slightly and continue until you have it flush on the bed and then push. Done, took about 7 min. saves a lot of backs. good luck
My C3 was ~400# ± a few when I shipped it.
400-450 lbs...fully dressed..is about correct. Look here in the archives and under Bill Verburgs's name, I believe, for more detail.
---Wil Ferch
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
My 50-year old neighbor and I lifted my fully intact 2.7 from a floor jack, fully up (20" up?), to the bed of my 4X4 Toyota PU without too much grunting. We are both pretty big guys but it wasn't much of a struggle. We lifted on the SSIs and the rear engine mount.
Troy
Troy Past: 1975 911S Silver Anniversary-rebuilt and sublime. Past: 1988 Carrera-backdated with a 3.6 and all the goodies. Present: 2011 GMC 2500HD with the 6.0 & 4x4!, 2004 Toyota Sequoia (wife's) |
Irrationally exuberant
Personally, I think you guys that lift these motor with your backs are crazy. New backs are NLA. Sure the opposed thumb and upright stance are nice but the large brain is what you should to be using for this task.
-Chris "Lift with your head, not with your back."
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Non Compos Mentis
Wow. That makes my head hurt, just thinking about lifting with it.
Chris,
You are absolutely right. I have always been pretty casual about lifting heavy objects because I could. Now, as I get older (36) I find my back is sore more often. Hopefully, the habit of "just grabbing the darn thing and moving it" will stop and I'll start doing as you suggest and use my brain, feeble as it is. Troy (with a sore back)
Got Boost?
Thanks for the replies, I think I will have acces to an engine lift to put it on the pick-up, so the only thing I will need to do is get it down on the floor of my garage until my car is ready. So far I am thinking of getting rollers under it and ramps like someone said.
Got Boost?
Ok, It took 4 people to handle the engine with not much problem. The engine is save at last.
Thanks for the responses.
