-   -   [BUILD THREAD] The 69 911s Blasphemy Build - LASTERN (http://forums.pelicanparts.com/porsche-911-technical-forum/1037129-build-thread-69-911s-blasphemy-build-lastern.html)
rennch 11-20-2020 11:56 AM
I gave lead filler a shot for the first time!
<iframe width="560" height="315" src="https://www.youtube.com/embed/0uLjfVWWwec" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
rennch 11-24-2020 02:02 PM
Applying my newfound lead skills to the 911!
<iframe width="560" height="315" src="https://www.youtube.com/embed/QsUHamFkOKE" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
rennch 11-25-2020 11:34 AM
My Blasphemy Build Subaru/Porsche 911 was featured on Mike Brewer's website today. Super cool! https://mikebrewermotoring.com/features/me-and-my-car/me-and-my-car-michael-oneals-blasphemy-porsche-build/
rennch 12-11-2020 12:11 AM
Good progress on lead filler for the drip rail delete. Making progress!
https://uploads.tapatalk-cdn.com/202...943d6d686f.jpg
https://uploads.tapatalk-cdn.com/202...4b7324dbe2.jpg
https://uploads.tapatalk-cdn.com/202...672cea9b96.jpg
https://uploads.tapatalk-cdn.com/202...6e66b9a8fc.jpg
https://uploads.tapatalk-cdn.com/202...9239758c7d.jpg
https://uploads.tapatalk-cdn.com/202...7c67eacf88.jpg
https://uploads.tapatalk-cdn.com/202...159e5d1ea9.jpg
rentalcar 12-14-2020 12:47 AM
Wow, amazing results! You make it look so easy in the videos. :D
rennch 12-16-2020 02:04 PM
Here's a timelapse of the progress I've made on this 1969 Porsche 911s race car that I'm converting back into a street car. I had to completely rebuild the back end, both quarter panels, and the front end, as well as a blasphemous power plant choice!
It's been really fun so far.
<iframe width="560" height="315" src="https://www.youtube.com/embed/wmPmLrUqpe0" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
https://youtu.be/wmPmLrUqpe0
rennch 02-06-2021 11:22 PM
My rear suspension control arm pickup points had to be refinished, since the original had been cut off. I had a 3” square tube to modify.
https://uploads.tapatalk-cdn.com/202...4487c9fdfa.jpg
Sized with calipers, cut, and narrowed, ready for welding.
https://uploads.tapatalk-cdn.com/202...438eddff51.jpg
https://uploads.tapatalk-cdn.com/202...9aa9616f0d.jpg
https://uploads.tapatalk-cdn.com/202...34b2b7156c.jpg
https://uploads.tapatalk-cdn.com/202...45eea10bbf.jpg
Test fit, pre welding.
https://uploads.tapatalk-cdn.com/202...e460c88f3b.jpg
https://uploads.tapatalk-cdn.com/202...09bde68b8d.jpg
https://uploads.tapatalk-cdn.com/202...dcdac0637e.jpg
https://uploads.tapatalk-cdn.com/202...18b04e961d.jpg
LJ851 02-07-2021 08:40 AM
How do you plan to keep your alignment settings without anything to hold the bolt in the slot ?
LukasM 02-12-2021 02:12 AM
I am surprised you are not getting much feedback on here Michael, but I think you are doing an amazing job on the build, experimenting, learning and figuring things out as you go.
Glad to see that your Youtube channel is really picking up, too! http://forums.pelicanparts.com/support/smileys/clap.gif
rennch 02-12-2021 03:46 AM
Thanks Lukas! Yeah, it seems I can’t get any traction with this build thread, so I have mostly given up on it. The channel is finally starting to experience some good growth though!
rennch 02-20-2021 07:16 PM
So...I did my first captive nut thing just now. Before I weld in the bottom of my rear seat section, I needed captive nuts so I could mount the battery. So, I made this bracket, drilled the holes, then welded on this captive nut set up. It looks awesome!
https://uploads.tapatalk-cdn.com/202...ec473df1bf.jpg
https://uploads.tapatalk-cdn.com/202...3e272edf91.jpg
https://uploads.tapatalk-cdn.com/202...ed327ec953.jpg
https://uploads.tapatalk-cdn.com/202...d8aa095e90.jpg
https://uploads.tapatalk-cdn.com/202...c360128471.jpg
Rodney Nelson 02-20-2021 08:24 PM
Looks great, you better show us some details in a video!
I ended up buying a Rivnut Kit because it seemed that Jeff from Home Built used them all of the time... of course I have yet to have the opportunity to use them.
brainz01 02-20-2021 08:30 PM
Love your channel. Thanks for all the vids!
rennch 02-21-2021 12:59 PM
I will, of course! There’s going to be a mega video or two coming out this week.
rennch 02-23-2021 02:17 PM
SO much cool fabrication on this one. I have (had?) a giant hole where a rear seat would have been, so I've had to custom fabricate all of the sections to accommodate my Porsche 996 (G96) transmission into this 1969 body, plus make a spot for an Odyssey 925 battery and my Haltech ECU. I had 30+ hours of work in this video! Hope you enjoy.
https://youtu.be/G_B0a5D-T74
TxGerman 02-24-2021 08:57 AM
From a structural support perspective, if you are trying to limit "oil canning" or flexing of a flat surface like a drum, you might want to consider using a reinforcing element that has a vertical rib, something along the lines of angle iron. Using flat bar/strap material may not provide the structural support that I think you are hoping for.
Dennis
rennch 02-24-2021 09:54 AM
Dennis
well, you're probably right! I thought about that, and I think if I were leaving it raw steel, I'd probably go that route. But after undercoating on the underside, some sort of dynamat on the topside, I think it will be ok. Thanks for the suggestion.
rennch 02-24-2021 09:55 AM
Thanks man! Been good quarantine fun!
rennch 03-03-2021 10:05 AM
After over a month of fabrication, I finally welded in this rear seat section. So much work!!
https://uploads.tapatalk-cdn.com/202...d616673844.jpg
rennch 04-16-2021 05:54 PM
https://uploads.tapatalk-cdn.com/202...6f9f4c63ba.jpg
https://uploads.tapatalk-cdn.com/202...8c1844aee4.jpg
We aren’t in Kansas anymore, Toto. An incredibly cool visit to 3D scan some parts I’m prototyping for production.
