JCstomper's Avatar
Solid to hydraulic lifter conversion?
I did a search, and it seems like it is possible. But I am wondering if anyone sells a kit, or has actually done this.
I'm looking to convert a 3.0sc engine to hydraulic lifters, and the easiest path to do so while the engine is apart being rebuilt and converted to 3.2SS.
Thanks!!
Sent from my SM-G955U using Tapatalk
Current Garage:
VW Rallye Golf, 820whp VW r32, TDI Touareg
Old 09-12-2019, 08:48 PM
HarryD's Avatar
I am confused. Where exactly do you think these lifters go in an air cooled 911 overhead cam motor?
#18 is the cam
#19 is the rocker arm
#20 is the valve.
I do not see a lifter anywhere in the picture.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 09-12-2019, 10:13 PM
Functionista
manbridge 74's Avatar
Usually people convert back the other way for more performance/revs. Priced 993 rockers arms and lifters lately? Also you would need an oil filter on the pressure circuit so a larger oil cooler up front to add on as well. Cubic dollars here unless you have a bunch of 3.6 parts lying around.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 09-12-2019, 10:40 PM
Diss Member
Quicksilver's Avatar
I believe the standard way people upgrade to hydraulic lifters is called a 3.6 upgrade.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 09-13-2019, 02:49 AM
Bill Verburg's Avatar
Bingo
Bill Verburg
Old 09-13-2019, 08:12 AM
If you are ambitious, a variocam could be possible with the chain box setup on the air cooled motors
Old 09-13-2019, 09:29 AM
JCstomper's Avatar
I found this amongst other things
https://rennlist.com/forums/964-forum/141504-switching-to-hydraulic-valve-lifters.html
Current Garage:
Old 09-13-2019, 04:26 PM
Reiver
Reiver's Avatar
Besides the difficulty of this you are changing what is a classic design....you could kill the resale of your vehicle.
De Oppresso Liber
Strength and Honor 5th Legion
Old 09-13-2019, 05:29 PM
JCstomper's Avatar
Last concern on my list.... I bought a car to drive, not worry about its investment status.
Current Garage:
Old 09-14-2019, 07:56 AM
rkeele's Avatar
why do it??? are you afraid of valve adjustment?? I don't get it
Old 09-16-2019, 09:32 AM
It would not increase HP one bit, just add a lot of complex oiling to your engine.
The valve adjustment would not be necessary, but unless you drive a LOT that is not an issue.
It is your car, and your money, do what you want. But like others have mentioned, your best bet is do a 3.6 upgrade. Lots more HP, and all engineering is done already. And likely not much more than the cost of a hydraulic conversion on a 3.2
Old 09-16-2019, 10:58 AM
this seems to only address converting the solid lifters on a 964 (3.6l engine) to use the hydraulic "bits" from a 993 -- don't think head design on a 3.0l sc engine would be compatible --
Old 09-16-2019, 12:35 PM
JCstomper's Avatar
Got ya. I also found a few links for converting them on a 3.3 as well.
Current Garage:
Old 09-16-2019, 05:39 PM
