If you don't have muffler you will get pulled over in a minute.
Old 11-22-2019, 12:55 AM
Crotchety Old Bastard
RarlyL8's Avatar
Are the Rarlyl8 headers being made to run with Gt3 mufflers now?
That is one thing we are working on right now. We just released an Active Exhaust System that works with headers. It is based on our ST street series muffler that have either GT3 or S tailpipe configurations. The sound level on this muffler at idle and cruise is just a bit louder than stock, jump on the throttle and it is Sport loud. The valves allow an alternate high volume path to exit along with the standard path. Here is a picture of the prototype being tested using OEM early exchangers. Production units will have the valves angled back. We are testing these with our new long tube headers now as well.
We also have a version of these new headers that will be modified to accept 997 and 991 GT3 mufflers. A couple of Pelicanites have sent me the mufflers and secondary systems to work it up. Those systems should be finished before the new year. There is a twin cat system in the works as well, lots of exiting things coming for 2020!
Old 11-22-2019, 06:59 AM
Still here
pmax's Avatar
Originally Posted by 911pcars View Post
These are available in two flavors. If you can dial your repro system to 110 dB, that's about the right sound pressure level (SPL). Allow your neighbors to review, then proceed accordingly.
Originally Posted by Shaun @ Tru6 View Post
George's headers (thank you Scott! 4flyboy) with a custom muffler which is essentially a pair of megaphones masquerading as a muffler on my M491. It's loud. (apologies for cameraman's finger)
The wail on a racetrack ... that's a beautiful sound but puttering about in a parking lot, why is it so loud ?
Old 11-22-2019, 11:11 AM
I'm good with tools.
AG81's Avatar
Originally Posted by pmax View Post
why is it so loud ?
I did not realize that "AWESOME" had a decibel level.
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 11-22-2019, 11:15 AM
Shaun @ Tru6's Avatar
"which is essentially a pair of megaphones masquerading as a muffler"
Tru6 Restoration & Design
Old 11-22-2019, 11:24 AM
Still here
pmax's Avatar
^^^ OK, so there's loud and there's racecar loud ... without the muffler or with a fake muffler, it's closer to the latter. Yeah, in one's neighborhood, better check with the neighbors since it is loud at any speed. That active exhaust tech makes sense for the BOBW.
Is that idle wavering on the M491 or is it just the exhaust puttering ?
Old 11-22-2019, 12:21 PM
3rd_gear_Ted's Avatar
Per data from Bill V. @ 6500 RPM its about 325 Hz. and I'm also guessing 110 decibels.
About as much fun as you can have with your clothes on IMO
1980 911 - Metzger 3.6L
2016 Cayman S
Old 11-22-2019, 12:39 PM
the idle is lumpy from a combination of a custom Sal Carceller chip designed to work with the headers and muffler.
I have no idea what hp the engine is generating, I'll go to a dyno this spring. The car is MUCH quicker than it used to be but there are far too many factors to determine the cause. In doing the headers and muffler, also done:
Swapped in a spare 1975 915 that shifts like a Honda. I have to rebuild the original to the car box as it has a terrible 5th gear whine. The '75 was rebuilt at one time and I think it has custom gearing and probably a 7:31. When i rebuild the original one I'm also taking the '75 apart to replicate it as best as possible.
In swapping that box in, I had to use a different clutch cable. Doing that found that I only had one bushing in the throttle bell crank at the pedal box so I was never getting full throttle.
I also removed all AC components, blower and the wing (saved 30 lb on that alone) for an estimated over 100 lb loss in the rear of the car. It actually sits higher now from all of the weight loss.
So with all of those things changing at one time, I am looking forward to seeing what hp the chip and exhaust produce.
Old 11-22-2019, 12:41 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
Open exhaust? Ok.
If you're fortunate to have one of these for trips to the grocery store, you'll need earplugs and earmuffs to avoid hearing loss, plus a separate bank account for bail, fines and vehicle impound fees.
2018-19 version (4.0 liters):
2019-20 version (4.2 liters). This one is less painful:
Sherwood
The second (newer car) sounds like dog crap compared to the first one..
Marc
Old 11-23-2019, 01:24 PM
Go straight pipes!!!!
Old 11-23-2019, 01:33 PM
Bucketlist's Avatar
I love my turbo with the zork, never been stopped, never been bugged by neighbors.
If the budget ever allows I will replace my old headers with some tuned from Rarly8.
If you haven't seen the above videos you should, I almost skipped them. The sound track in the first one makes my heart flutter.
1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters.
Old 11-24-2019, 05:30 AM
sugarwood's Avatar
nkotselas,
Have you gotten a suitable answer in this thread?
My car has B&B headers and muffler.
It is loud, but not obnoxious like a race car.
Here is an old startup video
Compare the volume of the starter with the idle.
Let me know if you want me to take another specific recording.
1986 Bosch Icon Wipers coupe.
Old 11-24-2019, 06:14 AM
autobonrun's Avatar
I took some SSI decibel measurements several years back (link). I think my hearing is improving with age because it sounds much louder now.
Performance Test done - SSI vs Stock SC
1979 Porsche 911SC Targa
1996 Porsche 993 C4S
2005 Porsche 996 Turbo S
2020 BMW X3M Competition
2003 BMW M5
Old 11-24-2019, 01:55 PM
Eva
911SauCy's Avatar
These threads are always good for a laugh...
A muffler is what manages your sound level. Headers do impact it marginally, but the majority answer to this inquiry is, what muffler will you bolt to these headers.
I got pulled over once, stock exchangers, Fabspeed cat-delete and muffler delete. Cop stopped me to "hear the car take off".
Not sure what the aversion to police is in this thread. smh
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 11-26-2019, 08:27 AM
autobonrun's Avatar
Good point about the mufflers. When I installed my headers, I also installed a dual out Dansk muffler.
I ended up having a cap/cover made for one of the exhaust tips later in life. However, I only use the cover when I decide to leave the house early am. Without it, the SC is very loud when cold. Not bad once it warms up.
Seems like someone on this board named Ben fabricated the cover. Hard to remember, but it is a very well made stainless steel cover.
2003 BMW M5
Old 11-26-2019, 08:35 AM
Under the radar
Trackrash's Avatar
There are a different sort of police on this coast.....
Gordon
'71 911 Coupe 3,0L outlawed
Old 11-26-2019, 10:07 AM
Eva
911SauCy's Avatar
Party poopers you might say
I'm also the wrong guy for input on this thread
I have headers and M&K 911R and am seriously considering megaphones for the street
Old 11-27-2019, 05:49 AM
RETIRED
Joe Bob's Avatar
Originally Posted by nkotselas View Post
Thanks joe bob, nice seeing you still around here I’ll never be able to forget the dancing banana that was next to your name. My brother got a set of Carrera decals from you 5 or so years ago.
Muffler is certain. Thinking M&K 2+2 in raw finish. This isn’t race car loud is it? If memory serves me right the SSI’s are a little to small for 3.2 and choke up top end. I’m willing to part with the heat the defrost hasn’t worked in years anyways
Still alive and kicking...thanks.
2012 ML350 3.0 Turbo Diesel
Old 11-27-2019, 03:34 PM
