Leaky Injector Connector
Look at the difference between one (very wet) and two(bone dry).
I have taken the fitting apart twice and cleaned and reseated, still seeping.
Is there supposed to be an O ring or seal in there?
Old 06-06-2020, 04:30 PM
Swap injectors. Maybe you need a new injector.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 06-06-2020, 04:56 PM
Fuel line........
From the picture you had posted, the fuel line to the injector is not properly oriented. You could see that it is going to the fitting at an angle. Loosen the fitting and re-align the metal fuel line. This is a compression fitting and relies on good surface to surface contact. Keep us posted.
Tony
Old 06-07-2020, 06:27 AM
kevingross's Avatar
Are you sure the leaking is coming from the fitting?
Kevin
Catellus Engineering
catelluseng@gmail.com
http://www.catellusengineering.com
https://www.facebook.com/catelluseng/
Old 06-07-2020, 11:57 AM
Still here
pmax's Avatar
There's an O-ring on the injector which seals it against the housing.
https://www.pelicanparts.com/techarticles/Porsche_911/05-FUEL-Injector_O-Ring_and_Sleeve_Replacement/05-FUEL-Injector_O-Ring_and_Sleeve_Replacement.htm
Old 06-07-2020, 12:36 PM
AndrewCologne's Avatar
I also guess it simply comes from the Fuel line thread which connects to the injector.
If the fuel really would come up from the injectors outlet upwards through the manifold and the injectors seal .... then then valve would be permanently closed to make this kind of closed chamber that overflowing till the fuel gets squeezed out of the injectors sealing ring
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control
All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models:
https://nineelevenheaven.wordpress.com/english/
Old 06-08-2020, 08:39 AM
Swapped injectors and now neither is leaking so I am leaving well enough alone.
Thanks guys
Old 06-08-2020, 08:58 PM
Discseven's Avatar
Tony
Way to look at things Tony! Compliments ~~~
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 06-09-2020, 06:18 AM
