Author of "101 Projects"
Porsche 911 Dyno Documentation Project...
It was recently suggested to me that dyno charts on different engines should have been included in the new book. While this was impossible due to space limitations, I can post them on the website.
So, I would like to start an "open-source" project where you guys donate copies of your dyno run, and post them to the website. Maybe we can start a thread here where you post the dyno chart and then give the characteristics of your engine: - case - crank - rods - piston/cylinders - cams - Fuel System - Compression ratio - Normally aspirated or turbo - Boost / size of turbo - Max HP - Max Torque Sound like a good idea? There must be loads of people with dyno reports out there... -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Excellent idea, though Juan would probably be updating weekly...
Keith 1979 930 2007 WRX wagon |
ooo I like it. If/When I get mine done I'll gladly donate it.
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
well I'm sure if he had the time/money he'd do it daily
Short Stroke 3.2
Case - SC Crank - SC Rods - SC Piston/cylinders - Mahle, cutouts for up to RSR cams, 98mm for 3,164cc Cams - Early 911S grind Heads - Either 930 or SC, ported, converted to twin plug (with 964 distributor) Fuel System - MFI throttle bodies, bored to 40mm, converted to EFI injectors (944 Turbo), MoTeC 3D injection and ignition Exhaust - SSIs with standard 2 in 1 out banana muffler Compression ratio - 10.3:1 Normally aspirated or turbo - Normally aspirated Boost / size of turbo - NA Max HP (flywheel est) - 273ps at 6220rpm – 270hp, or 245hp at the wheels Max Torque - 231 ftlb at 5100rpm (not shown) Dyno - Dynapack hub dyno (1.1x transmission correction used) ![]() The 2.0 it replaced Case - '69 2.0 Crank - '69 2.0 911T Rods - '69 2.0 911T Piston/cylinders - '69 2.0 911T Cams - Apparently they were E cams Heads - '69 2.0 911T Fuel System - Webers Exhaust - factory rusty heat exchangers, 2 in 1 out banana muffler Compression ratio - ??? about 8.6:1 I think Normally aspirated or turbo - Normally aspirated Boost / size of turbo - NA Max HP flywheel - 122hp at about 6000rpm - about 108hp at the wheels Max Torque - don't know Dyno - Bosch rolling road (transmission loss measured by coastdown at 11.5%)
1975 911S (in bits) 1969 911T (goes, but need fettling) 1973 BMW 2002tii (in bits, now with turbo) Last edited by CamB; 04-09-2003 at 02:54 PM.. |
Wayne,
If you set something up I am sure loads of people will put there figures up. I'll put mine up, 100% standard Euro but will be a bench mark. 105,000 miles no rebuild 215bhp at flywheel 205nm torque at ~5000, will have to scan the dyno print in. regards h
H '87 911 Euro |
The following dyno run was made on my 1981 Euro 930 about a month-and-a-half ago. At the time, the car was stock with the exception of a 1 bar spring that had been shimmed to ~1.1 bar. As of today the car sports a new Tial wastegate @ 1.1 bar and a complete C2 intercooler setup.
I also plan on adding a Blitz EBC and upgrading the turbocharger shortly. I will be dynoing the car again soon to compare to my baseline and post the results here.Case - stock 930.60 Crank - stock 930 Rods - stock 930 Piston/cylinders - stock 930 Cams - stock 930 Heads - stock 930 Fuel System - K-Jetronic CIS Exhaust - stock Euro, no cat or air pump Compression ratio - stock 7.0:1 Normally aspirated or turbo - turbo Boost / size of turbo - 1.1 bar on 100 octane / stock 3LDZ (K26) Max RWHP - 312.7 @ 5200 RPM Max RWTQ - 351.0 @ 4300 RPM Dyno - DynoJet 248C
Montana 911
Oh yeah....I will have to get her on a Dyno and see what she's got.
H.D. Smith 2009 997.2 S 3.8 PDK 2019 Ford Ranger Lariat FX4 Baby Raptor 2019 Can Am Renegade 1000R XC 2020 Yamaha YFZ450R |
Keep 'em coming, at least until I build some type of input wizard for the site...
-Wayne
I will dig out the dyno plot for my 1971 2.2S and post it tomorrow.
Alan.uk |
Wayne, consider asking what ignition system also? Would be interesting to know which of the modded cars are twin-plug, or Motec, or etc. Also, will responses be specific enough to determine displacement or should you ask for that too?
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
Re: Porsche 911 Dyno Documentation Project...
- case: 3.2 Carrera - crank: stock - rods: Carrillo - piston/cylinders: 98mm Mahle Sport - cams: Webcam 131e grind - Fuel System: PMO 50 carbs runnin on 98 octane race gas blend - Compression ratio: 10.3:1 - Normally aspirated or turbo: normally aspirated - Ignition: single plug with recurved Euro SC distributor - Max HP: 280 at rear wheels - Max Torque: 240 at rear wheels Here's the engine it replaced: Bone Stock 1980 SC 3.0 with minor fuel enrichment/ignition mods and SSIs with sport muffler: There are two pulls shown on this sheet- one before the fuel enrichment mods and one after. It gained almost 8 RWHP and 12 ft/lbs of torque from minor tuning tricks. TT
Tom Tweed Early S Registry #257 R Gruppe #232 Rennlist Founding Member #990416-1164 Driving Porsches since 1964 |
Wayne - I have a few dyno sheets I can send your way (one from my 930 and one from my 911). It what would be really great if you could come up with a way of grouping these so that people can search by engine type and modification. That way people could get an idea of what results the various upgrades can achieve. Also, baseline (pre-mod) dyno sheets are very hepful.
Bill |
Good idea - I added that info to my post above.
1975 911S (in bits) 1969 911T (goes, but need fettling) 1973 BMW 2002tii (in bits, now with turbo) |
Wayne,
I don't know if I am stepping on toes but you might put a posting on C2turbo.com. They have a bunch of dyno postings on that site
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
Here is an example of a nicely done table of dyno runs. Concise, comprehensive, easily read, links to charts might be a nice +
Dr.-Ing. Mario Schacht
Wayne-
If you could standardize the inputs I'd volunteer to take the compiled data and do a statistical analysis. It would allow one to say things like "X option adds 3 hp, while Y option adds 5 hp." With such an analysis, most inputs would be best as Yes/No responses, such as Factory or Pre-80s (?) Heat Exchangers. The fewer inputs the better. The downside is that certain data is not used, such as component manufacturer, but hey that's life. Eric
1995 993 C2, speed yellow. Protomotive Stage 1 twin turbo. JRZs, RS parts, DL1 logger, etc. |
Excellent idea and we're definitely working on it, Wayne!
The Chicagoland crew is working on some upcoming dyno sessions/events (hopefully within the next few weeks or within the next month) We'll keep you all posted. Ahmed "Alcrazy" - Yes, I'm all crazy about "turbodriven" cars! '76 Porsche 930 '87 Buick Grand National '92 Mitsubishi 3000GT VR4 All 3 heavily modded. '02 Volvo S60 T5 (of course it's also a turbo!). Still a virgin......no mods......for now........
Always feeling the NEED for SSSSSSSSSSSSS(the sound of all my turbos)SSSSSSPEED !!!! Porsche 930 (for sale) Mitsu 3000GT VR4 (for sale) Buick GN (for sale) (all 3 heavily modded) Yamaha YZF-R6 (one day I may install a turbo on the R6 or upgrade to an R1 or Hayabusa and turbo it!) Sold! Yamaha Virago (Sold) get the feeling I like "turbodriven" vehicles?? ![]() |
Dyno Shop for group rates??
My 70 S now has a 2.7 RS Spec with MFI. I have always wanted to put it on a Dyno and see what the real HP is. I am sure many Pelicanites feel the same. I know the books state 210 hp. What is it REALLY?
Anyone have connections to a So. Cal. shop to help us ALL out? Maybe give group rates and pass the info to Wayne? |
Wow, this is great....can wait to see what works and what doesn't work on our engines.
Warren & Ron, may you rest in Peace. |
