Author of "101 Projects"
Wayne 962's Avatar
Originally Posted by manbridge 74 View Post
Clarification: the one pictured above is inverted and needs to be flipped....
Thanks for the thought Jeff, but they were installed from the factory in the "upside-down" configuration. This one is pretty much in the same configuration / orientation as the factory installed location.
-Wayne
Old 05-31-2020, 06:35 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #381 (permalink)
A flaky injector could easily be affected by heat which would help explain the 2 minute issue. One cylinder starts misfiring which then starts to throw other things off.
Matt B
'73 911E
Old 05-31-2020, 06:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #382 (permalink)
Pete000's Avatar
Doesn't sound too bad, hows it driving?
Work to Live, don't live to work...
Old 05-31-2020, 08:58 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #383 (permalink)
Functionista
manbridge 74's Avatar
-Wayne
Ah yes, couldn’t make it out exactly from your pic I guess.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 05-31-2020, 09:33 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #384 (permalink)
Wayne 962's Avatar
That is a possibility. I think new injectors are in order if this problem doesn't go away...
-Wayne
Old 05-31-2020, 11:22 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #385 (permalink)
Wayne 962's Avatar
There's still a bunch of stuff disconnected and hanging down below, so it will probably be tomorrow until I can drive it...
-Wayne
Old 05-31-2020, 11:23 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #386 (permalink)
914-6
When the fuel rail was out, was it checked for rust? I got a 3.2 in a 914 that sat for 4 years, the "T" line to the side rails rusted almost to the point of being blocked. same crap in the return line to the tank.
Old 06-01-2020, 11:53 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #387 (permalink)
Targa_PB_78_SC
mike sampsel's Avatar
Sorry, this is not really any help ...
But if you are looking for some help "beating the snot out of it on the highway", I might be up for a trip
BareRearedRookie
Old 06-01-2020, 02:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #388 (permalink)
Wayne 962's Avatar
Yup, had the fuel rail cleaned along with the injectors...
-Wayne
Old 06-02-2020, 02:16 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #389 (permalink)
Wayne 962's Avatar
It's not exactly a good time to go out on the highways of Los Angeles to flog your Porsche. Today, I worked on the interior, and tomorrow I'll clean up the fuel lines and realign the windows. Then I'll see if we're still on lockdown. You'd hate to see me test this thing in a good ole' Los Angeles high speed chase (although that would be very noteworthy - most high speed chases involve pretty much very boring cars).
-Wayne
Old 06-02-2020, 02:18 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #390 (permalink)
ischmitz's Avatar
Send a message via Skype™ to ischmitz
-Wayne
If you go make sure you’ll have a full tank of gas and a blowup doll in the passenger seat. It’ll make for more drama when the news choppers try to decipher if your passenger is voluntarily or involuntarily joining the run.....
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 06-02-2020, 07:00 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #391 (permalink)
Wildman Emeritus
Could be fodder for a new book. "101 Ways To Elude Police" by Wayne Dempsey.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 06-02-2020, 07:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #392 (permalink)
Consider removing the firewall insulation for better airflow. Might run hot the way it is. Belt changes and timing checks would be easier, too.
206 637 4071
Old 06-02-2020, 07:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #393 (permalink)
I have a 3.2 that is perfectly smooth cold, idles a little rough warm, but smooths out again around 1500 rpm.
I've now found several small vacuum leaks that two smoke tests didn't turn up. I see you don't have half the vacuum plumbing I have -- just to say that a cold smoke test at 1 psi is not that reliable.
Old 06-02-2020, 08:48 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #394 (permalink)
Wayne 962's Avatar
The other 914 doesn't have that, and it's way too loud in the passenger compartment - I had to install the "helicopter style" headsets in there!
-Wayne
Old 06-02-2020, 06:58 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #395 (permalink)
Wayne 962's Avatar
How did you finally find the vacuum leaks then?
-Wayne
Old 06-02-2020, 06:59 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #396 (permalink)
NoBozos's Avatar
-Wayne
Sure ain't no white Bronco...
Old 06-02-2020, 08:53 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #397 (permalink)
NoBozos's Avatar
Searched this post but didn't see it in the results, did you ever do a system fuel volumetric test to see if any cylinders are being starved? e.g. measuring each injector output while installed in the rails on the engine to include the "system".
Thought is potentially having good pressure but marginal flow that actually shuts off or starves a cylinder when it drops off the warm up RPM. This is based on your observations of a left/right difference after the car kicks down.
Old 06-02-2020, 09:53 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #398 (permalink)
Poking and prodding ugly looking fittings. Looks like you only have the fuel pressure regulator and damper hooked up? No crankcase breather? I'd recommend testing the regulator and damper with a hand vacuum and then hooking up a vacuum gauge on the intake. (That's what I'm going to do this weekend.)
Old 06-03-2020, 09:29 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #399 (permalink)
Brew Master
cabmandone's Avatar
Am I the only one who finds it odd that cylinder 4 is running 30-40 degrees hotter than the other 5? When I get time I'm going to have to fire up my car and take some readings. I don't recall any of mine being that far apart.
Edit: You mention a few times early on that you measured temps and "they were all fairly even" (post 88, page 5). I haven't come across a post yet where you have temps. Just seems odd to me that the one is a good bit higher than the other five when the other five are all within 10 degrees.
Nick
Old 06-04-2020, 05:24 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #400 (permalink)
