LinkBack | Thread Tools |
Rating:
Author of "101 Projects"
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
A flaky injector could easily be affected by heat which would help explain the 2 minute issue. One cylinder starts misfiring which then starts to throw other things off.
Matt B '73 911E |
Doesn't sound too bad, hows it driving?
Work to Live, don't live to work... |
Functionista
Ah yes, couldn’t make it out exactly from your pic I guess.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
-Wayne
There's still a bunch of stuff disconnected and hanging down below, so it will probably be tomorrow until I can drive it...
-Wayne
914-6
When the fuel rail was out, was it checked for rust? I got a 3.2 in a 914 that sat for 4 years, the "T" line to the side rails rusted almost to the point of being blocked. same crap in the return line to the tank.
Targa_PB_78_SC
Sorry, this is not really any help ...
But if you are looking for some help "beating the snot out of it on the highway", I might be up for a trip
BareRearedRookie |
-Wayne
It's not exactly a good time to go out on the highways of Los Angeles to flog your Porsche. Today, I worked on the interior, and tomorrow I'll clean up the fuel lines and realign the windows. Then I'll see if we're still on lockdown. You'd hate to see me test this thing in a good ole' Los Angeles high speed chase (although that would be very noteworthy - most high speed chases involve pretty much very boring cars).
-Wayne
If you go make sure you’ll have a full tank of gas and a blowup doll in the passenger seat. It’ll make for more drama when the news choppers try to decipher if your passenger is voluntarily or involuntarily joining the run.....
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Wildman Emeritus
Could be fodder for a new book. "101 Ways To Elude Police" by Wayne Dempsey.
Mike Andrew 1980 SCWDP 2024 Suby Forester 2018 BMW X1- Wife's 2000 Boxter - Sold |
Consider removing the firewall insulation for better airflow. Might run hot the way it is. Belt changes and timing checks would be easier, too.
I have a 3.2 that is perfectly smooth cold, idles a little rough warm, but smooths out again around 1500 rpm.
I've now found several small vacuum leaks that two smoke tests didn't turn up. I see you don't have half the vacuum plumbing I have -- just to say that a cold smoke test at 1 psi is not that reliable. |
-Wayne
-Wayne
Searched this post but didn't see it in the results, did you ever do a system fuel volumetric test to see if any cylinders are being starved? e.g. measuring each injector output while installed in the rails on the engine to include the "system".
Thought is potentially having good pressure but marginal flow that actually shuts off or starves a cylinder when it drops off the warm up RPM. This is based on your observations of a left/right difference after the car kicks down. |
Poking and prodding ugly looking fittings. Looks like you only have the fuel pressure regulator and damper hooked up? No crankcase breather? I'd recommend testing the regulator and damper with a hand vacuum and then hooking up a vacuum gauge on the intake. (That's what I'm going to do this weekend.)
Brew Master
Am I the only one who finds it odd that cylinder 4 is running 30-40 degrees hotter than the other 5? When I get time I'm going to have to fire up my car and take some readings. I don't recall any of mine being that far apart.
Edit: You mention a few times early on that you measured temps and "they were all fairly even" (post 88, page 5). I haven't come across a post yet where you have temps. Just seems odd to me that the one is a good bit higher than the other five when the other five are all within 10 degrees.
Nick Last edited by cabmandone; 06-04-2020 at 05:44 AM.. |
