clock
1987 carrera, clock stopped working while driving. I checked, fuses, none burnt
any suggestion?
Old 06-14-2019, 11:32 AM
WPOZZZ's Avatar
They just die. If you had a working clock, you could swap them to see if it is the clock or the wiring. I'm betting it is the clock.
Old 06-14-2019, 11:37 AM
The clock on my '83 Targa was not working when I acquired it. I fixed mine with 2 new capacitors. It's easy. Pull the clock, get the correct capacitors, take apart, R&R them and then put back together. Mine keeps perfect time now....
Old 06-14-2019, 12:05 PM
proporsche's Avatar
i was working on one 911 and the clock , i was told did not work.So i have checked and guess what............... the battery was dead;-)
I had to keep it and got new clock for the guy;-)
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 06-14-2019, 12:33 PM
Fahren mit dem Wind.
mhackney's Avatar
I posted a detailed repair of the 2 capacitors in the SC clocks here. If the 87 clock is similar, that might do it. My fix has been working perfectly for a few years now.
911SC Clock Repair with annotated photos
Keeper of the 1983 911SC Cabriolet Registry (http://911sccabrioletregist.freeforums.net)
Caregiver to:
1983 911 SC Cabriolet - Fahern mit dem Wind.
(Moss Green Metallic over Champagne and Brown Leather)
Old 06-14-2019, 12:37 PM
any suggestion?
Do your interior "dome" lights, glove box light and trunk light work? If not it might be the fuse bad connection, or the little white connector coming off of fuse 4.
The connector is in the bottom right of the photo, and it has the black wire. On mine the connector was FUBAR, and I had to replace that connector.
Old 06-14-2019, 01:18 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Capacitors.
I replaced these on our clock.
All well now.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 06-14-2019, 09:00 PM
Did it stop working entirely...or did it give the the wrong time by a few hours?
If it's the second case...see mhackney's thread. It worked great for mine.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 06-15-2019, 01:09 PM
clock
it stopped working completely...fuse is fine, power is on, led light is on as well...
Old 06-15-2019, 04:50 PM
clock
1987 carrera....question: when replacing the 2 capacitors, do I have to break and solder the 2 new ones? if yes, please show where this is done on the clock...a picture, if available will definitely help. THANKS!
Old 06-16-2019, 02:27 PM
The capacitors are there for power storage...when the car is sitting with the battery/key off.
If the clock won't work at all...it's not the capacitors.
Mine would keep good time until it sat in the garage for a few days. Then it would work fine when driving again. Replaced the caps and all was good again.
98 Honda Prelude
22 Honda Civic SI
Old 06-16-2019, 02:39 PM
clock
so, if it is not the capacitors and there is power, what is it then?
Old 06-16-2019, 04:42 PM
Not exactly correct. The power to the clock is always hot regardless of switch position. Capacitors fail in 3 ways, short, open, and loss of capacity. You will have different symptoms for different type of failure. If you do not have sophisticated test equipment, I would think capacitor replacement would be a good starting point.
Another option, send it out for repair. I see a major online auction has a listing for repair $130, or any VDO repair vendor.
Rob
Old 06-16-2019, 05:28 PM
calidude's Avatar
Just fixed mine with 100uf 24v polarized caps from Amazon for $5.99 got 5 of them. If anyone needs a couple PM me
1987 Porsche 911 Carrera - Lagoon Green
Old 06-16-2019, 10:15 PM
Brown747's Avatar
I’d take 2 please. PM sent. Thanks
1978 SC coupe #1834
Old 06-17-2019, 03:43 PM
PRE-H20's Avatar
Help
Need some HELP..............
Soooo I have a 74 911.
Reading through some of these CLOCK repair threads.
Mine already doesnt work so why not try and DIY ?
stumped after 2 min.... this sucks, and gonna be a long road I'm guessing.
Black wire off!
Brown wire off!
What is that last attached wire?
How is it attached?
How do I disconnect it?
Old 06-17-2020, 03:20 PM
ROW '78 911 Targa
timmy2's Avatar
Pull the light bulb assembly out.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 06-17-2020, 04:05 PM
pavegeno's Avatar
Send a message via Skype™ to pavegeno
Sent mine to North Hollywood Speedometer. Works great now.
2002 GMC Yukon SLE - 4AT - Purchased New in 2002
1988 911 Cab - 5MT - Purchased Used in 2005
2008 Cayman - 5MT - Purchased New in 2007
2014 911/50 - #1173 - 7MT - Purchased CPO in 2014
2019 Macan S - 7PDK - Euro Delivery/New in July 2019
Old 06-17-2020, 04:22 PM
