frencjas's Avatar
Turbo Brakes Extremely Noise *HELP*
Help me folks.
I just got the Big Red Turbo 4 piston brakes put on my 1977 911s, with Pagid Orange pads, and they are LOUD!!!!
They emit a super loud high pitched screach louder than tires squealing, when applying almost moderate to hard pedal pressure.
What can I do to fix this??? I realized that there would be some squealing and additional noise due to the hard pads, but is this going to keep happening?
Also, what is a good break in procedure for this setup. I will not be tracking my car for a while, so I will have to use streets/parking lots.
Please help me.
Thanks,
Jason French
Jason
Keep Right Except to Pass!
2000 Audi S4 Quattro Non-Sunroof
1989 BMW M3 (sold 12/06)
1977 911S Wide Body 3.6 Varioram (sold 11/05)
Old 04-15-2003, 08:58 PM
one of gods prototypes
bell's Avatar
alot of "racing" pads won't work properly until they're very hot......do they quiet down when they get hot?
Brought to you by Carl's Jr.
Old 04-15-2003, 09:01 PM
frencjas's Avatar
I havn't got them hot yet, I drove the car home only.
Jason
Jason
Old 04-15-2003, 09:03 PM
Automotive Monomaniac
Emission's Avatar
Most huge brakes are underworked on the streets. They tend to glaze a bit and make noise. Try heating them up with several stops from 60 mph or so. This should wear off some of the glaze and they should (hopefully) quiet.
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 04-15-2003, 09:08 PM
Jason, we use pagid orange pads on our race cars and they are loud! The noise will not subside, I'd change to a street pad until track days. They squeel until there worn out.
Old 04-15-2003, 09:10 PM
You have the pagid oranges which are meant for track use. They are very, very noisy and you can forget about them being quiet for street use. I have 930 brakes and pagid orange for the track. The pads are so easy to change, take the plunge and buy a set of street only pads. You occupants and wheels will appreciate the quiet, low dust alternative.
Old 04-15-2003, 09:11 PM
frencjas's Avatar
OK, sounds like I may need to get some street pads then.
Is there anyone who thinks that these pads may quiet down once heat cycled?
They are EXTREMELY loud, ear drum shrilling screeching!
I appreciate all the input.
Jason
Jason
Old 04-15-2003, 09:54 PM
Limbo
Slider79SC's Avatar
Jason,
They will never quit down under normal street use. Take the plunge and buy street pads........
Big ol built Duramax
Durango R/T 19’ Current Custom project
V8 M3 08’ Built and spoiled
Old 04-16-2003, 07:47 AM
Todd Simpson's Avatar
Same experience here. Pagid oranges were quite loud on the street.
Old 04-16-2003, 09:11 AM
Insert Tag Line HERE.....
rattlsnak's Avatar
I have the same issues with Pagid Oranges, get a street set.. Applying permatex blue anti squeel well help, as will chamfering the front edges, but it will not go away even after they are heat cycled.
Marc
Old 04-16-2003, 09:25 AM
IROC's Avatar
I use Pagid oranges on the street and they are essentially silent. No squealing for sure. My application is in Carrera brakes, though. I thought the phenomenon of the "loud squealing Big Reds" was due to the calipers actually flexing somewhat and allowing the pads (especailly racing pads) to vibrate? Am I wrong?
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 04-16-2003, 09:31 AM
My Pagid Oranges squeal like a sorority girl. To quiet them, I do a couple of hard stops occasionally, which cleans off some of the crud, and makes them quiet for a day or so.
Old 04-16-2003, 09:51 AM
Bill Verburg's Avatar
Pagid Orange pads are notorious for their noise when cold. The larger the pad the more noise. Get Some Pagid Sport Blues of Ferodo 2500s for a nice dual purpose pad that won't squeel.
Letting the pads get packed w/ debris makes it worse.
Bill Verburg
Old 04-16-2003, 02:26 PM
Administrator
Jack Olsen's Avatar
There's no good reason to waste expensive Pagid Oranges on street driving. They're not particularly good pads until they're hot, which is going to be very rare in street driving, unless you're circling the same block again and again, and braking like a maniac.
It's so easy to change pads, get street pads for the street, and track pads for the track.
Old 04-16-2003, 03:35 PM
You can't possibly bed in brakes using mall parking lots and the like. You need to do half a dozen gentle-to-moderate stops from about 60 to a walking speed, another half dozen hard stops from 80 to about 20 with the last two just short of lockup--between all these stops let everything cool down thoroughly, like for a couple of miles of brakeless cruising--and then one final stop from 130 or so to a stop just short of lockup all the way. Then don't touch the brakes again (foot or parking) and simply coast to a stop, put the car in gear and let the brakes cool for about 15 minutes.
Not that I'm so smart and experienced that I know this, it's the marching orders I got from Steve Weiner of Rennsport Systems after I installed his Turbo brakes system with Ferodo pads.
Stephan
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 04-16-2003, 03:58 PM
Super Moderator
cstreit's Avatar
I agree with Jack. Pagid orange are also quite hard on rotors and it's not worth wearing out $300 pads on the street, nor the wear and tear on your rotors. OEM or similar sets are fine for the street.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 04-16-2003, 04:16 PM
Somewhere in the Midwest
MotoSook's Avatar
Ferodo pays for the street? Good idea or no no?
Old 04-16-2003, 04:20 PM
Irrationally exuberant
ChrisBennet's Avatar
I've been running Pagid Orange for around 6 years on the street and track. Here are some data points from my own experience:
1. '86 Carrera with stock brakes. Quiet on the street and good on the track. I used some brake quieting goop on the backs of the pads.
2. Same '86 Carrera with floating 930 rotors in front with 993 calipers and 930 brakes in back. Extremely loud. So loud I scared a horse in a passing trailer and caused a pedestrian to cover his ears. I now run them on the track only.
If you have pre-90 stock brakes with their small pads I don't think you will find that Pagid's make noise.
Unlike other race pads, Pagid Orange pads stop fine when cold. My experience has been different than Chris CStreit's; I've found them very easy on rotors. That may be because my street driving does not involve many stops or stops from high speed. If it wasn't for the track, I think my pads would last for many years.
Speaking of rotor wear, after 3 years of track use with Pagid Orange pads (on the track) and Porsche pads on the street, my rear 930 rotors measure new! The pads wear out but not the rotors. (The Coleman front rotors were worn out.)
-Chris (the slower)
Old 04-16-2003, 04:51 PM
I'm ( again) with Chris B on this one...
I run Pagid Orange on my stock 85 Carrera and they are the best combo street pad/ track pad I've found. The new Ferodos may be as good but I haven't tried them yet. Also...not loud ( on 2 piston calipers....any 4 piston calipers using Pagid Orange tend to be loud). Also, very *easy* on rotors....what's all this about hard on rotors ???
Anyway...some help for you 4 piston guys...might not cure noise completley but:
- before you install, file a small 45 degree edge on at least three sides of the pads. If you're not sure how they're installed, do all 4 sides.
- a "slight" amount of hi temp brake grease on the "edges" of the metal backing pad...don't get it on the brake surface...but only a smidge on the edges that contact the calipers.
- use the acrylic 3M aluminized stick-on anti rattle pads on the backside of the brake pads. Not that brake "goo" that is offered for this purpose... as it tends to grab the dust seals and take them out when you remove the pads.
- When you're all done, the squeeking should be substantially reduced or even eliminated.
Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 04-17-2003, 07:34 AM
