TurboRuf's Avatar
Question Front Fender Mounting Bolts - Torque Value?
Can someone please check their 911 service manual to see what the torque values are for the front fender mounting bolts?
Old 04-17-2003, 12:16 PM
TurboRuf's Avatar
Bump
Old 04-17-2003, 03:21 PM
probably no torque value given for those. the idea is to get them tight enough, but not so tight that the two panels distort. it's a feel thing.
206 637 4071
Old 04-17-2003, 03:34 PM
TurboRuf's Avatar
Thanks John, I can always count on you. Do you recommended loctite or anything else on the bolt threads?
85 930 Ruf BTR
Old 04-17-2003, 06:02 PM
You do not have permissi
john70t's Avatar
I just got them tight, and used big washers to distribute the load.
One mistake I made was to straiten out the inner edge of the fender (it had previously been "custom fitted" to follow the hood line, and I also used thick fender putty(body dope?) inbetween which increased the gap even more.
Old 04-17-2003, 06:18 PM
