Smog Problems
Good Day, my 1985 Carrera has failed California Smog testing 3 times recently. I’ve had a smoke test done and no leaks were discovered. I’ve run a fuel additive through one complete tank of gas and the most recent Smog Test failure showed very high NOx readings. It seems that I may have to replace the Catalytic Converter and/or Oxygen Sensor. Any advice or solutions. Frustrated.
Old 09-28-2020, 04:36 PM
Post your full results ....
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 09-28-2020, 05:59 PM
Failed evap also?
Old 09-28-2020, 07:39 PM
Motor must be very hot when you take it in. Also I put 45 pounds of air in the rear tires for less drag while it’s rolling. Change oil. Make sure car is tuned up. Again, real hot motor .
Old 09-28-2020, 10:19 PM
Hi
Targa Me's Avatar
I believe a high NOx reading indicates running Lean. Could be a vacuum leak.
How many miles on this engine?
Can we see the smog check results?
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 09-29-2020, 11:15 AM
High NOx on a car with no EGR system is a bad CAT
Old 09-29-2020, 02:35 PM
Agree; I have an unused CARB-certified cat that I could sell at a discount...
Old 09-30-2020, 01:07 PM
