While engine is out to do list help
I bought this motor. Was running over a year ago. Has sat since.
1983 3.0 stock ~86k miles. Going into 68 chassis Currently this is what I’m thinking of doing while motor is out: -adding Weber carbs -adjusting valves ( new gaskets). Anything else? -flywheel seal and bearing -oil tubes -new plugs -has the braided wires. Should I replace them? -recurved or older distributor What else should I do or inspect while it’s out? Thanks.
1975 911 3.4 outlaw/hotrod? lsd 1988 535i 1987 535is 1973 bronco ranger Last edited by stubble88; 12-01-2020 at 10:52 AM.. |
Racer
Get PMO carbs instead.......
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
I know. I was looking. But I found some freshly rebuilt Weber’s for $2200.
PMO’s would have been $5k.
1975 911 3.4 outlaw/hotrod? lsd 1988 535i 1987 535is 1973 bronco ranger |
Not terribly familiar with '83's but if it's a CIS engine you won't realize the true potential of the carbs without changing pistons and cams.
Bone stock 1974 911S Targa. 1972 914/4 Race Car |
Replace the rubber seal. It’s installed in the chassis and seals to the engine tin.
Surprising how stiff and brittle it gets with time. |
Replace the oil pressure switch and the breather gasket in the triangle area. Upgrade to hydraulic chain tensioners if not already.
Walt 82SC 3.0 81SC 3.6 |
It's wrong to put carbs on a CIS engine. It wont work. You'll need different cams and cam timing.
Have you thought about cylinder studs? Rob
You might also think about stuff to do on the car while the motor is out. Fuel lines, shifter bushings, any in the tunnel is easiest to address when the motor is out. Rear swing arm bushings, too.
this....
do this......
![]() regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
As for the chain tensioners. Is this a must do at any mileage? It’s just a bit costly. How often do these fail on the pre 84’s?
This was the first mod I made when the car was purchased knowing a failure of the tensioner could be catastrophic to the engine. I don't have any experience with the tensioner guards but they are very inexpensive and look easy to install. I would certainly consider this as a minimum.
Edit: They used to make a repair kit for mechanical tensioners but they may be NLA.
Walt 82SC 3.0 81SC 3.6 Last edited by walt; 12-02-2020 at 05:47 AM.. |
You may want to smoke test the intake and look for leaks. Working on seemingly simple CIS components with the engine in is a pain.
Forgive my ignorance. Still new to this motor.
But do these oil lines indicate that I already have the upgraded tensioners? ![]()
ROW '78 911 Targa
Yes, tensioners are upgraded to oil fed type.
Oh my. This is a big relief. I was stressing seeing the $1800 kit on pelican. Nice!! Thanks Dennis
1975 911 3.4 outlaw/hotrod? lsd 1988 535i 1987 535is 1973 bronco ranger Last edited by stubble88; 12-02-2020 at 08:39 AM.. |
As for your question on the braided wires. I'd leave them at least for now, easy enough to change out later after the engine is installed.
Banned
Replace 37 year old fuel pressure regulator and twist the crimp fittings on all the associated hoses, if any fittings spin replace all 3 hoses.
I have my 76 on jackstands right now. I havn't driven the car in a decade so I'm dropping the motor to inspect everything and replace what doesn't look good.
I got the axels out today and I was looking at the grease. I replaced the boots maybe 13 years ago and cleaned and packed the cv joints. The boots and grease looks ok and I probably can get away with just bagging the joints and reinstalling as is.. but then I started thinking about the rear wheel bearings. They're probably still packed with the original grease from 1975. I'll just clean, inspect and repack everything now. |
Slippery Slope Victim
Years ago I bought a nice '80 SC with 46mm PMOs and SSIs. I put in DC40 cams, 10.5 to 1 pistons and that car screamed. Not so much for the stock 3.0 and PMOs. Oh, don't forget that the distributor needs to get recurved.
Mike² 1985 M491 |
