You reported some improvement cleaning battery terminals and charging the battery. Have you tried substituting the battery with a known good one? Swap out your battery with one from another car and see if there is any difference. It's a long shot, but one of the quickest easiest things you can do. I solved something like 5-problems by putting a fresh battery in my old S10 pickup truck.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
Crotchety Old Bastard
Initial observation of your video looks like a weak ignition. A failing battery, CDI, coil or alternator could be the culprit. If it is a weak ignition use my part of the bounty to fix the problem.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
CDI box is a 8-pin core with new internals from another vendor that I prefer not to name on the forum, but I will send you a PM.
The truth is that it has not been a good experience for the CDI , but a great source for hard to find stuff for our cars. 1st time it lasted just a couple of weeks, fixed and they recommended to change the engine wire harness. I also installed proper Ohms ends on spark plug wires. Since then it has been back 2 more times for service. Last time it was upgraded for more resilience. I guess mine was not the only one with problems.
79 SC Back to Basics! 2006 997 C2s Cabrio - Sold 1999 996 C2 - Sold Last edited by ivanuf; 12-27-2020 at 08:20 AM.. |
79 SC Back to Basics! 2006 997 C2s Cabrio - Sold 1999 996 C2 - Sold |
Housing to troubleshoot. Sensor plate was verified when engine was out
On my ground verification taks I removed the alternator to verify strap, verified strap on CDI base, engine/transmision support to chassis.
All verified with power probe and in working order.
This was just for that video, not normal use.
I have, I tested the wire signal to injector with power probe, took injector out and applied power and tested. Also tried starting the car cold w/o CSV and it gets way worse. Once you plug the wire to the CSV it starts faster.
ivanuf..there are many more locations you should check for grounds, front trunk to start with behind the fuel filter just name some.....
sensor plate was verified means -you have adjusted to correct location? Also seeing the engine running backwards when starting..how is your ignition timing on distributor?? Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Update!!
I went into the garage this morning to do the daily start test and the car started right up and then died and did not started any more. It felt different than previous test, verified and sure enough no-spark and dead CDI again for the 4th time! So at this point I will assume the problem will be due to the failing CDI, but I can not confirm this is the case until I replace the CDI and use the car for a while. I will definitely not go via the same route as all this time because seems that all the times I am getting a repaired CDI it may be having some internal problems with intermittent CDI performance. Here is a PIC of the inside of the CDI. Suggestions on: 1. Any testing recommended to the (new) wire harness before I install a new CDI, besides obvious ground and 12v readings? 2. What is the most reliable route on my CDI quest? A 6-pin with modified harness end plug? Classic Retrofit Option?(a little hesitant with modern electronics after bad experience with MSD and this modified CDI) I guess the ideal will be to source an 8-pin CDI and have it sent to Ingo, but they are very hard to find. Pros and cons or ideas welcome. Once I sort this CDI failure I will update and if problem persists I will proceed with fuel pressure readings and smoke test if needed, but probably not, price money will be pending to confirm if CDI failure was 100% of the problem, so far the car won the price by giving up on starting, but Rarly8 and Jonny H were the closest to the cause so far...
79 SC Back to Basics! 2006 997 C2s Cabrio - Sold 1999 996 C2 - Sold Last edited by ivanuf; 12-27-2020 at 09:37 AM.. |
I suspect that your CSV is faulty and providing too much fuel and flooding the engine.
regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
cycling has-been
OK - I'm out - I already had the $$$ spent.......
73 911T MFI, 76 912E, 77 Turbo Carrera Last edited by bkreigsr; 12-27-2020 at 10:25 AM.. |
Just keep going, you seem to have a process going.
I did read one claim that a weak battery can ruin a starter and alternator because of the diodes in them. The diodes can go bad or in some cases be fused together. Since you took care of the battery replacing any new stuff should in theory eliminate those items from contention. I know it's poor form, but on my older vehicles I adjust and lower my expectations. Do I really need a working dome light? Do I really need working A/C or heat for that matter? Starting issues are frustrating because you really do need the car to start.
Sounds like you may have found your culprit- I once had a intermittent Permatune box that drove me nuts trying to verify that it was indeed the problem.
If the replacement CDI box doesn’t solve the problem, I would hook up a timing light every time I tried to start the engine to see if you have spark during the no start issue. Slight pain, but pretty simple way to track down if it’s an ignition problem.
Rutager West 1977 911S Targa Chocolate Brown |
Still think it is a CSV problem.
You may want one of these to test for spark. https://www.amazon.com/dp/B001OK8KK2/ref=sspa_dk_detail_1?psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFVMDA5SVpOQlA0MTEmZ W5jcnlwdGVkSWQ9QTAyMjkwNTYySzk1Q083RkoyTDVaJmVuY3J 5cHRlZEFkSWQ9QTA3NDI1MDEzUFI5SFdPMlBBVDdBJndpZGdld E5hbWU9c3BfZGV0YWlsMiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZ kb05vdExvZ0NsaWNrPXRydWU=
Caveman Hammer Mechanic
4 dead CDIs? This would seem to indicate that something is killing them, my bet is the alternator is overvolting, killing the CDIs plenty of the caps in the electrical components are rated for 16V, not much headroom for overvolting. When my alternator was dying it took some electrical components with it.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
My 75 non turbo did the same thing. Sometimes it would start easily other times not so easy. Random. Had it towed twice thdn it started when back home. Checked everything. Pulllrd the distributor adjusted points etc. bought a pertronix ignitor. When i installed it i noticed that the black points wire in one section was bare from rubbing against the distributor cam lobe. It did not alasys touch but i assume would shrink or expand to cause a problem. Pertronix installed the problem was solved.
#147 of 2096
Saludos Ivan !
Two things that I would do: 1- Klassic Retrofit CDI is a very good alternative (We are using it on one of the Jose's cars) 2- Please.... confirm that valves are correctly adjusted (I have seen a lot of problems with engine valves just a little bit over adjusted) It is always better being on the loose side. Regards.
#147 of 2096 |
