I AM BUILDING MY OWN HEADERS LIKE THE PICTURE BELOW....
JUST NEED ONE QUESTION ANSWERED..... WHAT WIDTH OF PIPING SHOULD I USE FOR THE 2 PIPES THAT CONNECT TO THE MUFFLER FROM EACH HEADER.... I AM THINKING 3 INCH PIPES... I WANT A THROATY SOUND, NOT A HIGH PITCH SOUND.... MAYBE I SHOULD USE 4 INCH PIPES.... ANY ANSWERS.... THIS IS NOT MY AREA..... THANKS... ![]()
Irrationally exuberant
You need to do more homework before you start. Bigger pipes = lower velocity = no low end torque.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
I got the original older style pieces that fit right to my engine.... I am
just custimizing the pipe on each side that goes to the muffler... I think either a 2 1/2 inch or 3 inch would be best for performance.... but not too sure... |
Hilbilly Deluxe
What car, what engine?
Tom |
2.7L '75 911.. ... I have a stainless muffler with an empty cat right
now and my car runs really strong... I am hoping to gain some horsepower by adding a header system with dual inlets to the muffler.. .. ... |
If you want to add power, copy/study SSI's. SSI's themselves are an improved version of the factory '74 headers. They are a very good design - superior to the system you have pictured even.
-Chris
Do you think I will notice a big difference from changing to dual
inlets instead of the single inlet that wraps around the side of my motor? |
-Chris |
When I sent my headers out to get jet-hotted I used a stock setup and I could definetly tell the difference the duals made. I use a headers, not cats, 2 dansks mufflers, and to 2 1/4" outs.
Hey Chris I am wondering the same.... I hope it's worth it... I may just
put the old style headers on and fabricate another inlet to my stainless muffler... I hope it runs stronger... .. ... I think I will gain torque.. Terry..... Did you notice a big difference in torque.... I heard that I would have more torque in every gear.... Is this true.... and it will cost me basically nothing to convert over my exhaust so I think it will be worth it... |
Oh and by the way... Has anyone heard of by design.... That is my
stainless muffler.... is it good or just some aftermarket junk.... Sounds good when the car is on so thats what counts to me.... HAHAHA |
Black and Blue
Be sure and post some pics...this looks like a worthy project. Im sure that porsche put alot of time in developing the tuned headers up to 74...then SSI picked it up from there, not to mention Bruce Anderson's view of the early style HEs. So as Chris Bennet pointed out, you would be on the right track by copying someone that has already made a great product
...if anyone has dimensions on the stock early style HE's or 2.7SSI's, that would most likely be the right diameter.
Kemo 1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore 1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver |
Black and Blue
you could build in an 'X' pipe of some sort...that would be cool.
Anyone have a picture of the old headers.... I need to see what
they look like..... I cannot seem to find a picture of them.... |
Black and Blue
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
There was definetly a increase in power.
I would do some serious calculations on all your diameters and lengths before starting, even if you copy someone else's design. If you make it out of stainless you will probably spend several hundred dollars, time spent in design would be well worth it. Here's a good site for material and tips: http://www.burnsstainless.com
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
