3.6 conversion heating w/stock heat exch.
I would like to know what type of hose the 3.6 gurus used on their conversions. I am keeping the 993 heat exchangers, so i need a hose which connects the outlet of the exchangers (oval) to the connector for the heating.
Winter is coming and I would like to be ready!!!
Mario
'76 911 w/'97 3.6 Euro Vario Engine & Turbo body kit & TPC Supercharger
'15 GT3
Old 11-17-2005, 12:20 PM
On the top or the bottom?
On the bottom, I fabbed up my own connector with exaust tubing and a piece of aluminum dryer hose. For the top, there's a really trick carbon fiber piece available
Old 11-17-2005, 12:41 PM
thanks Tom. My problem is on the bottom, I already have the carbon fiber tube for the top
Do you have any pics of your setup?
Mario
'15 GT3
Old 11-17-2005, 12:45 PM
It isn't pretty, but it works...
Old 11-17-2005, 01:03 PM
Mario
'15 GT3
Old 11-17-2005, 01:39 PM
A much nicer solution is to use the 993 cast aluminum heat crossover tube. I found one on this BBS for $75 I then used 2 1/2" aircraft defroster hose (the orange silicone high temp stuff ) which is the same as Porsche uses originally I think I paid less than $40 for 6 feet.I made 2 simple funnel adapters from sheetmetal to connect to the oval outlets. It works well and looks fine.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 11-17-2005, 02:00 PM
Bill Verburg's Avatar
W/ 993 header use the 993 heat tube
You can see it here below the sheetmetal, if the cat was present it would be below the heat tube.
On my 993 I use B&B headers w/ a 964 heat tube.
Bill Verburg
Old 11-17-2005, 02:09 PM
john, where can I get the 2 1/2" aircraft defroster hose ?
Mario
'15 GT3
Old 11-17-2005, 04:46 PM
I called a small airplane repair place at our local airport,from the phone book.. They had it in stock for a Cessna I think I just described it as high temp silicone hose possibly orange and they had several diameters.Sold by the foot..A hydraulic hose supplier I spoke to knew exactly what I was looking for also but had to order it and I would have to take 12 ft @$8/ft.min. They suggested the aircraft industry used it for defroster or heater duct.
Timmons will sell you the same stuff I think he wanted $75-80 for 5 feet plus shipping.He wanted about $100 for the 2 sheetmetal adapter funnels.The end result looks exactly like a pic on his website but costs much less.
1995 993 coupe
2012 Boss 302
Old 11-17-2005, 04:58 PM
CBRacerX's Avatar
Take a look here at the very effective heating system I have with mostly stock 993 parts. I have a 993 heat tube for sale if you need one
I got crabs this weekend!
Chris
Chris
https://dergarage.com
‘07 GT3, '80 SC Weissach (For SALE), '01 986S, '11 958S, '18 Stelvio, '18 Dursoduro 900
Old 11-17-2005, 07:16 PM
Senior Member
Chris,
Just left you a msg on the other thread. Might be interested in the tube.
JoeA
Old 11-17-2005, 08:18 PM
Hello
What is the part number for the "cast aluminum heat crossover tube? Do you happen to know?
Old 01-23-2021, 05:20 PM
CBRacerX's Avatar
I still have one of these 993 cast crossover tubes for sale
Chris
Old 01-23-2021, 08:28 PM
In my recent 3.2 build, I pre-fitted 993 HEs, but wanted to begin with the existing bolt-on 2in/2out muffler and SSIs. However, here's how I fabricated the early hot air system onto the 993 heat exchangers:
Heat exchanger inlet modified for valve cover access:
45º silicone elbow adapter connects engine air shroud hose to HE inlet (There's a short internal tube behind the double hose clamps to connect the SCEET hose to the silicone adapter.
Heat exchanger Al outlet hose adapter (Revotec.com). I don't recall the large OD end (before reshaping), but the small end is 2.5" OD:
Al adapter annealed, then ovalized and expanded a bit to fit heat exchanger outlet:
Hose connection, HE to cabin hot air valves using add'l 2.5" (63mm) SCEET hose as above:
Works for both Gillett and Bishoff HEs (Gillett shown). Add'l SCEET and hose connection tubes missing:
Hope this helps,
Sherwood
Old 01-23-2021, 08:47 PM
midnight911's Avatar
1984 911 Carrera Coupe - 32C #73 - M64/05
1998 E36 M3 4dr
2006 Sienna 5dr - the hauler
2004 Lexus GX470
2010 Cannondale Caffeine II - Lefty
Old 01-23-2021, 10:00 PM
