Dept store Quartermaster
lendaddy's Avatar
Turbo mount revisited, got to resolve this
I test fitted the new K27-7200 last night and am posative that the turbo/muffler mount is different on this '85 exhaust than my original reactors. Does anyone have the PET showing both a '77 mount and more importantly an '85 mount? A part # would be golden. Thanks guys.
Cornpoppin' Pony Soldier
Old 04-29-2003, 06:30 AM
arrivederci's Avatar
I don't have a diagram, but different mufflers have different mounts. I recently put my cat-equipped (stock) muffler on the 930 for emissions purposes and was suprised to find that it had a different mount. The cat-less mount worked both for a euro muffler and my GHL setup.
- '72 911T
- '81 911SC Euro
Old 04-29-2003, 06:44 AM
lendaddy's Avatar
I am using a monty dual out muffler. Bu I am not concerned about that so much. It is the turbo I want located correctly. The turbo can be "moved" a little when it is mounted to the exhaust and I would like to get it right if you catch what I am saying. A small movement at the turbo could result in a fairly large change in where the exhaust tips exit.
Old 04-29-2003, 06:50 AM
lendaddy's Avatar
Sorry to bump, but this one is killing me. Thanks
Old 04-29-2003, 09:02 AM
Crotchety Old Bastard
RarlyL8's Avatar
I had the same problem when mounting the K27-7200.
Had to modify a used mount. There was no other way to make it fit perfectly. My exhaust is a Euro '86 with a (modified) stock muffler.
Old 04-29-2003, 09:55 AM
lendaddy's Avatar
Ok, I will go that route I guess. I really appreciate your response. Don't worry Rarely I have not forgotten that I owe you one from last year as well. Once I get the engine in I will get back to that air cleaner housing project. Thanks again.
Old 04-29-2003, 09:58 AM
hold on checking for you now
87 Carrera Backdate
Old 04-29-2003, 10:09 AM
lendaddy's Avatar
Thanks, I await your response.
Old 04-29-2003, 10:20 AM
this is the exhaust side of an 85 turbo. does this help ?
87 Carrera Backdate
Old 04-29-2003, 10:21 AM
lendaddy's Avatar
No, that does not show the turbo mount that goes between the muffler intake and the turbo exit. Close though.
Old 04-29-2003, 10:25 AM
this ? i hope its on this one otherwise i cant help you i,m afraid
87 Carrera Backdate
Old 04-29-2003, 10:33 AM
Here are the 77 and 85 turbo configs...Let me know the specific part and I will give the part number
Old 04-29-2003, 10:35 AM
last try
87 Carrera Backdate
Old 04-29-2003, 10:37 AM
ahhh someone who knows the turbo came in Good luck Lendaddy
87 Carrera Backdate
Old 04-29-2003, 10:39 AM
lendaddy's Avatar
Yes! definitely #5 in both diagrams. Could you give me both part #'s? They look the same but we will see. That is awesome, what program are you using ? Is that the PET program I have seen on Ebay? Thanks again.
Joel
Old 04-29-2003, 10:49 AM
930.123.121.01 77
930.123.121.05 85
I should have the later one around if you need to try one
Old 04-29-2003, 10:52 AM
lendaddy's Avatar
What do you need for the mount? I could definetely use it! Thanks
Old 04-29-2003, 10:54 AM
How about if I send it to you and if you use it we can work it out, if not you can simply send it back and cover shipping.
Old 04-29-2003, 10:57 AM
Keep in mind that the placement of the turbo is also dictated by your headers. And there are four connetions to the turbo...the air intake, outlet to intercooler, exhaust inlet, and outlet to muffler. All of these other connections will limit the amount of movement you can actually achieve. If you're simply worried about the muffler tips, I suggest having a muffler shop work directly on the muffler, rather than adjusting the position of the turbo via the turbo mount.
- '72 911T
- '81 911SC Euro
Old 04-29-2003, 10:59 AM
lendaddy's Avatar
My teory is that the mount is the only "rigid" mount and if I get that right the rest will fall into place.
Old 04-29-2003, 11:05 AM
