Report on New Uro Windshield Seal
Just a quick post to report on the newly-redesigned Uro windshield seal. My glass guys (one with 40 yrs of auto glass experience, the other has 28) do a lot of work for Porsche restoration shops in S. Florida. They first tried the factory seal and, after fitting it on the glass but before even putting the glass on the car, could see that it wasn't going to work and rejected it. I gave them the Uro seal and within half an hour they had the glass in. They really liked the way it fit in the corners with the wider lip. Needless to say, I'll be returning the factory seal. Here are some photos of the corners:
Old 11-15-2022, 08:10 AM
Cairo94507's Avatar
That is a very nice looking seal/fitment.
'71 914-6 #0372
'17 Macan GTS
Old 11-15-2022, 08:14 AM
Carmagic.us
rothaus's Avatar
Good to know Thanks for posting.
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems
Old 11-15-2022, 08:36 AM
Any idea how to tell the old and new style apart when ordering it? Different part number? Wo'pac lists a URO-009765. Is that it?
206 637 4071
Old 11-15-2022, 08:37 AM
Hi John- Yes, the Uro part number I have is URO-009765. To my knowledge, it just became available last month.
Old 11-15-2022, 09:08 AM
Administrator
Anyone know if they're doing the various targa seals?
Old 11-15-2022, 09:51 AM
7783911's Avatar
Black 993...I assume by your moniker you have a 993...if your looking for older targa seal (the Bar one) I have an extra that I ll let you have for 50...
Old 11-15-2022, 10:56 AM
PCA Member since 1988
How is this seal different from the previous URO windshield seal? I installed the last version on my 1973 coupe, and after relaxing in to final position, it fits very well and has held its shape for the past 3 years.
Old 11-15-2022, 11:09 AM
Maybe a Uro rep will chime in, but here's a thread that talks about some of the differences:
https://forums.pelicanparts.com/porsche-911-technical-forum/998122-re-designed-new-uro-windshield-seal-review.html
Old 11-15-2022, 12:27 PM
FYI - just found this post by Uro from 11/8/22:
Hi guys, we're still working on setting up a new production line for seal 911 541 225 03 / 91154122503, so it'll be quite a while before we have more available. Remember, our latest version of this seal (softer rubber with the wide lip) has batch code 7874 or higher in the bottom right corner of the URO label. There's a chance batch 7389 might have been the new version, but we can't confirm.
*** FYI ***
If you buy an old-version "NOS" URO seal at a swap meet or in the for-sale section, be aware that it's going to be harder rubber (even more so the older it gets) and have the same lip width as OEM, which means it won't be easy to install and you'll probably have gaps at the corners. As an example, batch 5012 is more than seven years old, and batch 6306 is more than five years old (and well outside of our two-year warranty). Be sure to verify that the code in the bottom right corner of the label is 7874 (or higher) if you want to minimize installation challenges.
Last edited by isby; 12-14-2022 at 07:09 AM.. Reason: Updated Batch Number for New Seal (per Uro)
Old 11-15-2022, 12:31 PM
I really like new URO front window seal.
If you have a car with a paint line at the window gasket the URO seal wll cover it right up.
Old 11-15-2022, 03:15 PM
I was advised to use the factory seal. Which I did. Was a major struggle but it is in. I feel strange saying this but I wish I had used the Uro product.
Old 11-15-2022, 03:26 PM
Do they make a rear window seal?
I'm going to replace all four window seals, my new to me 87 roller definitely has a leak in the rear and I will need to take the front out to repair the dash... and I need to replace the headliner so all four will be coming out.
Old 11-15-2022, 03:42 PM
UROParts's Avatar
That 's fantastic Isby, thanks for the report! Good news everyone - Windshield Seal 911 541 225 03 is back in stock! Only about (200) units from this production run, so don't delay if you've been patiently waiting to order one. Doesn't look like Pelican is currently showing them available; we'll send them a message.
Our current version of this seal (softer rubber with the wide lip) has batch code 7874 or higher in the bottom right corner of the URO label. URO-009765 is our internal part number for 911 541 225 03, so you can search for it using either number.
Originally Posted by eastbay View Post
I really like new URO front window seal. If you have a car with a paint line at the window gasket the URO seal wll cover it right up.
That's a great tip Eastbay, thanks for sharing.
We offer Rear Window Seal 911 545 225 00 for coupes, and Rear Window Seal 911 545 051 41 for targa models. About two years ago the rubber was softened a bit for both seals, and around that same time the coupe version was updated with molded corners (the prior version was a continuous loop of rubber extrusion). Both are similar to OEM, and do not have a wider exterior lip like our redesigned Windshield Seal 911 541 225 03.
URO Parts Online Catalog for Porsche: https://apaindustries.com/catalog?make=2
Old 11-16-2022, 07:51 AM
proporsche's Avatar
URo..any updates on windshield seal without trimming?
Ivan
1985 911 with original 501 645 miles...807 319 km
Old 11-16-2022, 09:15 AM
Ordered two 009765 from Wo'pac. Hope they're the good ones.
206 637 4071
Old 11-16-2022, 09:18 AM
UROParts's Avatar
Ivan
Hi Ivan, sorry but Windshield Seal 964 541 225 00 (911 541 225 03 without trim groove) isn't going to happen, unfortunately. Thanks for checking.
URO-009765 is our internal part number for 911 541 225 03, so you should be good to go.
Old 11-16-2022, 09:38 AM
Can you link Pelican's link or whoever has the new one for sale? Is there a direct URO buy link?
83' Coupe - Ex-RaceCar
77' Targa Narrow Body - SC powered
Copper Brown Metallic
Old 11-16-2022, 09:44 AM
UROParts's Avatar
We just sent an email to Pelican to get this seal reactivated in their system, now that it's back in stock. Normally it takes them about a day to make updates to their online catalog, thanks for your patience! (Sorry, we only sell through retailers.)
Old 11-16-2022, 09:50 AM
Amazing, I'll check back on the forum to see if they pop back up in the next day or two and buy both the front and rear so I have them on hand when I take on that project.
Thank you
Old 11-16-2022, 10:25 AM
