HarryD's Avatar
As Chris notes, do the checks including oil consumption verification. If the compression/leakdown is good and oil use is ok, drive and enjoy. Plan on a rebuild sometime in the future.
Best of holidays to you across the pond.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 12-23-2022, 12:16 PM
That makes sense, $8500 for labor. That is probably the going rate in the US as well.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 12-23-2022, 03:16 PM
scarceller's Avatar
Hi Luka, Just saw this post after you PMed me. I suggest this simple test to see if the smoke reduces some.
- Get engine fully warm
- With engine running at idle, OIL LEVEL ALWAYS CHECKED AT IDLE ENGINE RUNNING.
- Check oil level on the dip stick
- Add/Remove oil till you are between the low mark and only 1/4 on the dip stick.
I'm just suggesting to not overfill the tank much above the low mark.
Also remove the black 90deg rubber boot from between the TB and the AFM. Is the inside of that boot very oily? It should not be.
And with the boot removed, open the throttle blade, is the backside of the blade very oily?
Report back the findings.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 02-22-2023, 12:13 PM
Tags
3.2 engine , blue smoke , piston rings , valve guides
