Senior Member
Help! 3.6 conversion wiring questions
I am in the middle of installing a 3.6 in my 85 Carerra. Question of the day is how everyone else did the wiring!?
I was given what appears to be a complete 3.6 motor wiring harness, that runs to the interior and DME computer and relay. It does not connect to the relay panel in the back LH fender. Then I have a second hand made wiring harness that has DME fuel injection relay terminals but no computer connection. There is a third wiring harness that is connected to a spare relay panel that could be used to replace the stock unit which is fastened in the left hand fender area in the motor compartment. The wiring loom here has been cut about 4 feet from this panel. Everyone I have heard from I believe replaced the entire wiring harness from the relay panel, to the motor, to the DME computer under the drivers seat as a assembly. Has anyone made up their own harness like someone has done here? My other issue is that I have sold my 3.2 motor to a gent who is going to put it in a earlier 911. He will need a wiring harness to fit the motor, computer and fuel injection relay. If I cobble up the harness in my car to make it work with the 3.6 then he is without a wiring harness and that aint gonna work either... Would sure appreciate some ideas... Thx, Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
I have some 3.0 to 3.2 wiring info at http://dowtynet.com/porsche/3_0to3_2electrical.htm . Don't know if it will help you but might help the guy who bought your motor.
Jim Dowty 97 911 Coupe (Forest Green metalic, sunroof, leather) PCA RSR region Insurance chair and Board member Gruppe B #309 |
Montana 911
wow...wish I could help you out, maybe Ingo will chime in.
H.D. Smith 2009 997.2 S 3.8 PDK 2019 Ford Ranger Lariat FX4 Baby Raptor 2019 Can Am Renegade 1000R XC 2020 Yamaha YFZ450R |
Non Compos Mentis
That's the one area with my engine swap where I decided there is no reason to re-invent the wheel. I took the car to a guy that has done a few of these before, and let him do it. A few bucks well spent.
this web site may have some wiring info.
http://instant-g.com/Products/36Conversion/index.html he sells a conversion kit that I have heard is very good.
There are basically two wire systems. One is the fuel injection system. This is the harness that hooks up to the various sensors on the engine and then goes into the interior of the car where it plugs into the DME "brain". You need a wiring harness adapter that powers this system. This is what Steve Timmons as well as Patrick motorsports sells. Basically this harness goes from the drivers seat area to the front trunk. It plugs into the fuel injection harness under the seat and then runs to the following items:
1) Fuel Pump 2) Battery 3) Tach 4) Switched Ignition (12 volts when the key is on or cranking) The second "system" is the normal engine items that run through the 14 pin connector. These are oil temp, oil press, alternater, alternator control, starter solenoid, backup lights, heater fan if installed. On mine there are only six pins being used on the 14 pin plug. If you know how to use an ohm meter you can figure out what each pin on the engine side is and then match them up with the corresponding pin on the chassis side. Some "kits" come with a small jumper cable that has a 14 pin male plug on each end so that you can remove the relay panel. I left my panel in so I didn't use this setup. If you want to call me I'll be home today until about 3:30 PM eastern, then will be leaving for 3 days. Pete 609-714-9049 |
again 3.6 conversion, you have to take the drivers seat out, install the dme under the seat, youhave to drill a hole in the passenger foor box or be hind the seat, the loom will run into the engine compartment, engine harness and coil wires, dont connect the dme untill your done, the home made harness goes to the fuel pump ground tach and oil, Kevin
I had 3 harnesses involved: 1) handmade from the DME to the guages/fuel pump/power; 2) from the DME that runs though the firewall and branches out in a "Y" to the engine compartment fuse panel and motor; and 3) the harness that is on the motor itself. Luckily I did nto have to modify the harnesses.
Ingo has a great understanding on this issue but I think he is still in Japan for a little while try a PM to him. I will repeat Kevin's advice Quote:
Hope this helps a little.
Joe:
I have the 14 pin connector for the 3.2 on the conversion page if you need a road map for the female side of the connector that is on your car. You will need a similar road map for the 3.6 if it has a 14 pin connector. As to the other issues, I haven't a clue. Sorry.
'94 CMC Firebird Trans Am '86 951 LS1 (C-2) Gone ![]() ![]() '77 911 3.2 (C-1) Gone but not forgotten. http://www.pelicanparts.com/MotorCity/marcesq1 http://www.youtube.com/user/958Fan#p/u |
Senior Member
Thanks to all the information and replies.
My situation is that I did take the drivers seat out and start removing the DME computer and relay. What the problem is, is that there is another wiring loom inside the same bundle that has the harness with the DME/Relay wires. It goes futher forward and appears to go under the dash. If I pull this out to give to the gent buying the 3.2 then it appears that it takes some other needed wires with it. My harness that goes to the DME/Relay also is a direct connnection to the motor items. I also have what appears to be two 14 pin connectors on the motor, not just one. This is a 964 motor and wonder if the wiring is different? Will go and digest what you guys say and take a look at the harness and get back and post later tonight! Thanks again for the help and ideas! Joe
Joe, I see you got Steve's message, the extra harness was from a 964, originally a diagnostic port was going to be hooked up through that harness, that never happened, so as Steve said "chuck it". I believe that the pins are correct as is, but do check, please. I do not have the wiring diagrams even for my own car. That is someting that needs to be collected in one place to simplify this process. Ingo's site seems to be a step in the right direction.
Senior Member
Bill and Paul,
Thanks for the ideas. There are indeed two connectors on the LH side of the motor. Did not count the holes and assumed that they were 14 but one could be 12. Have contacted Steve and paid for him to walk me through the wiring bundle mess as well as for the two fuel lines I need. My problem before was that I was assuming (you know what happens when you do that!) that the DME relay and DME computer were on the same harness, which it appears they are not. Will see what happens when I get the info and parts from Steve and go from there. If the wiring had not been a complete mess we could have gotten it switched in two days. Damm... was trying to get it in and out but thats life. Now I have time in the garage to backdate both ends of the car and maybe paint it! Thx, Joe
Joeaksa if your getting parts from steve youll get it figured out, here is what happen to me, when I recieved the motor and harness some things were changed, you will have two connectors in the engine compartment, one will be a big 12 pin and it will be a female on the DME harness you installed through the foot box, your cars harness will have a 14 pin male, the engine will have two plugs you guessed it a big 12 pin male and a smaller 14 pin female, the one you need to check is the one on the cars harness, after what I went through i would check them all, your motor was in a converted car, im not saying they did it wrong, just check that 14 pin female to make sure they didnt alter it, just for being safe,
The reason why i couldnt give you a answer on the fuel line is again, my car is all stock and is supposed to have 12mm fittings and it has 10mm, steve was the one that figured this out for me, i could have spliced it in but thats not the way im doing this install, I hope you already have your exhaust issue worked out, if your gonna use the 993 headers let me know i have a jig so you can flip the flanges real easy, Kevin |
Senior Member
Kevin,
Thanks and I have a hodgepodge of connectors on the harness and motor. Going to count the pins tomorrow and try to make more progress on the wiring. I gave up and ordered the fuel lines from Steve. Am going to use the SSI HE's for now and probably upgrade later on when I am able to save a few more bux. Cannot afford to do everything at once! I do have the 964 system that came with the motor but not sure if its worth looking at. Thx, Joe
Joeaksa the cross over pipe will have to be altered on the 964 pipe, i picked up a 1-5/8 B&B system with muffler on the bbs parts board at a good deal, the two connectors will be real close to each other, the other plugs go to different parts on the engine, i.e. injectors etc, if you get steves instructions it will help you alot, you can private e-mail me if you need info, stew09@aol.com, Kevin
Hi all,
The 964 conversion is something I will also be doing soon so I have been reading all your past posts and learning a great deal. I hope to buy the complete conversion set up to make my life easier, including the chip, clutch and so on. My question here is similar to Joeaksa's on the SSI set up, I plan on using these for now just because my wallet will be empty for a while but I have read that these will also need adapting. If so in what way...will the port need lenghening to clear the engine in order to bolt to the muffler. PS I know they are restrictive but they will do for now. I also have the complete 964 exhaust, has anyone tried to fabricate the cross over pipe so it will work with the 915 clutch arm? Also sorry to change the thread a little here but, the earliest chassis coversion I have seen is in a 72. is there anything else I should consider in my conversion as it is going in a 69 car which I belive will be the earliest chassis conversion. Very light car plus very powerful motor= big smiles. Alan.UK The engine I have is a late 964 from a 1993 C4 1971 911E 1971 911S |
Joe
Here are some pictures that will hopefully help you You should have a total of 3 wiring harnesses for the 964 engine as stated above 1) The engine should have a harness on it for the various sensors, as well as a long pigtail with connections for the starter and reverse light switch, it terminates near the fuse panel in the engine bay with these two connectors The large 12 pin connector will mate with the DME harness coming from under the drivers seat which we will see in a minute. The small 14 pin connector will mate with the 14 pin connector on your relay panel on the chassis This it the connection you will have to check for compatibility as some of the pin outs are not compatible between the chassis and the motor, you will need to check what the pin out on your chasiss is on a site like marcesq has above The pinout for the engine side of the 14 pin connector is 1 yellow;starter 2 not used, disconnect 3 not used 4 gn/red; oil pressure gauge 5 gn/ye; reverse light switch 6 gn/br; reverse light switch 7 bl/gn; heater fan, not needed 8 br/bl; heater fan, control signal 9 gn/wht; oil pressure warning light 10 re; relay blower motor, not needed 11 bl; alarm, not needed 12 re; a/c compressor 13 ye/gn; relay blower motor 14 re; relay fuse panel heater blower motor The other harness is the DME harness as shown below ![]() At the center of the picture is the large 12 pin connector that connects to the mate coming off the engine shown above The rest of the connectors mate to the motor sensors. At the top of the picture is the large DME connector which connects to the brain, and 2 smaller connectors a 6 pin and a 14 pin, these will interface with a homemade wiring harness shown below This is the one I made At the center is three connectors A 14 pin and 6 pin to mate to the connectors above by the large DME connector, and another 6 pin connector that holds the DME relay. Several wires extend from this harness to the battery, the fuel pump, fuse panel, switched ignition, oil temp gauge, check engine light, fan belt breakage light etc, Ingo has a nice shematic on his site. Hope this helps you and others. The interface harness is really quite simple to make, but then I have also done 2 of these swaps now. Let me know if you need more help Todd holyoak@brandeis.edu
1989 911 Targa |
Senior Member
Todd,
I owe you big time! That helps alot and really appreciate it. Let me lay my harness's out and see how it compares with yours. I have what I have been told is a Patrick harness and hope its about the same that you have made on your own. One question. The bottom picture of a harness in your hand, where you say "This it the connection," appears to be in the front of the car (I see the battery in the background) and I was under the impression that the 14 pin connection that I needed to "re-arrange" was coming out of the relay panel in the motor compartment. Where is this harness? Thanks and check six, Joe
That picture is the left rear of the car, the battery is just sitting on the floor in the hole vacated by the motor. Sorry for the confusion. Again this connector is the one that would be situated on the relay panel under the black cover at the left rear of the car.
![]() Todd
1989 911 Targa |
