Flat Six
3.2 Idle Speed Adjust Screw
Just a PSA. Was resetting base idle speed on the Carrera and as I was making the adjustment I heard a little wooshing/hissing coming from the idle speed screw area.
Wasn't sure if this sound was an actual air leak from atmosphere (e.g., false air) or just the sound of additional air inside the TB bypassing the screw. So I pulled the screw completely and thought I'd post some pics in case they'd help someone else: Idle Speed Screw: ![]() O-Ring dimensions: ![]() Since I already had it out I went ahead and replaced the o-ring w/a fresh one and reinstalled w/grease on it and the screw threads. HTH
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
Thanks, Flat six
Burnin' Rubber
Yes thx, nice info
Gilles RoW 88 Carrera coupé Last edited by wazzz; 10-08-2023 at 10:51 PM.. |
Has anyone found a replacement o ring?
I see kits online, just wondering if anyone has found a suitable replacement. Thanks- Erik
1986 911 Coupe 1986 911 Targa |
And yes, thanks for posting this! Erik
If you remove this to replace the o ring how hard is it to reset the idle correctly? Do you try to put it back in in as close to the same depth as possible?
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
I think some just count the revolutions upon removal to get it close and then go through the procedure of setting base idle. I have removed before (to inspect) and had no issues going through the reset procedure. Idle was high at first and corrected from there. 800rpm in my case. I ordered a set/variety of o rings for this from "the internet" so hopefully one comes close.
Then rev the engine a few times and make sure it doesn't "hang" at a higher RPM than the setting.
Dave |
So Dave, would I just remove the idle speed screw, add the new o ring and put it back in fully seated, then start the car and drive around till its warmed up and then back it out till a steady 800 rpm?
Works every time.
Dave |
Please be careful on the O-ring you use; it should be Viton or similar flurosilicone material, as hydrocarbons could eat away at EPDM or TPE/TPV "off the shelf" O-rings from hardware stores, etc.
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc. '07 Boxter |
Not exact specs so we shall see how they work. I just know the current o ring is shot.
Nitrile is a "poor man's" Viton / FKM. Should be fine OK in this application, but it will now depend on how anal you want to be. Viton is best, though.
I will dive further down the rabbit hole as weather is keeping me from the yard and garage work
![]() Thanks!
Or...I'll just order a replacement for 10 bucks from our host!
I have a large assortment of the "green" AC o rings...would that material work?
Those are likely HNBR (typically green color); very similar in performance to nitrile. Not as good as Viton / FKM, but probably OK here.
