2,7 liter 1976
unknown connector
This connector with black,brown and blue wires comes out of the harnas near the 14 pin connector.
On the connector the 3 are marked as D- D+ and DF
This seems a generator connector,but on the car the existing wires are allready all attached to the generator.I checked to see.
Just leave it ? or remove?
Old 02-01-2024, 07:07 AM
There was an option where the voltage regulator was located to the left of the engine, next to the fender. That must have been its connections.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 02-01-2024, 07:12 AM
2,7 liter 1976
Thanks, I ll leave it as it is.
Old 02-01-2024, 08:34 AM
PCA Member since 1988
Yes, that was for an external Voltage Regulator mounted on the relay panel. Someone probably installed an internally-regulated alternator, so those are not needed. What year is your car?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 02-01-2024, 02:19 PM
2,7 liter 1976
76 Pete
Old 02-02-2024, 01:29 AM
E Sully's Avatar
Just for reference.
Ed
1973.5 T
Old 02-02-2024, 07:07 AM
