Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
The effects of a broken belt Re: idiots guide #2
Well I drained the oil and pulled the sump plate and here's what I found. They are iron or steel and not brass or Al. dtw and I are thinking it's rings or cylinder material. I'm still not sure the FT will be ready to go come sat. All depends on how bad this is.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 06-19-2003, 04:24 PM
Navin Johnson
TimT's Avatar
FOCUS!!!
'69 911 GT-5
'75 914 GT-3
and others
Old 06-19-2003, 04:29 PM
Tim Walsh's Avatar
I'm goin' to take more pics since these didn't come out so well
Tim
1973 911T
2005 VW GTI
Old 06-19-2003, 04:30 PM
What are we looking at?
Neil
'73 911S targa
Old 06-19-2003, 04:31 PM
Tim Walsh's Avatar
ok that second pic looks much better to me
Tim
1973 911T
2005 VW GTI
Old 06-19-2003, 04:36 PM
Tim Walsh's Avatar
Now the big question.. teardown now or later?
Tim
1973 911T
2005 VW GTI
Old 06-19-2003, 04:38 PM
Administrator
Jack Olsen's Avatar
Depends on your definition of 'better.' Looks pretty scary to me.
Old 06-19-2003, 04:46 PM
Tim Walsh's Avatar
scary? well I've already resigned myself to a rebuild.. just now or in 6 months?
Tim
1973 911T
2005 VW GTI
Old 06-19-2003, 04:49 PM
Weird, looks a lot like the results of running a drill through something, or shaving the edge off of something. Very weird, I am curious to know what these are part of.
Good luck
Old 06-19-2003, 05:08 PM
Senior Member
almost looks like bits of the oil control ring. don't think it is but if I can find an one I will bring it with me on Saturday for comparasion
are you missing any part of the sump screen?
78 Euro 911sc Targa
03 Hayden
SCWDP
Old 06-19-2003, 07:23 PM
Tim Walsh's Avatar
well I talked to zuffhausen and dtw and they belive it's toast. I'm starting to think the same thing. They/we are theorising that the fan stoped, the cylinders, rings and pistons overheated and the shavings are from the rings cutting the cylinders. Those peices are actually peices of the cylinder wall. Since those pieces have been through the whole pressure system the whole engine's has to be tore down.
any second opinions?
Tim
1973 911T
2005 VW GTI
Old 06-19-2003, 07:26 PM
Tim Walsh's Avatar
The sump screens is ok and I'll bring the shavings on sat.
Tim
1973 911T
2005 VW GTI
Old 06-19-2003, 07:33 PM
Senior Member
If you where cutting the cylinder walls I would think the compression would be low and you would be burning oil. Is that happening? Have you done a compression check. I would say a tear down is in order but I would be temped to buy a 3.0 or 3.2 from some of these guys sticking 3.6's in their cars.
78 Euro 911sc Targa
03 Hayden
SCWDP
Old 06-19-2003, 07:41 PM
Bandwidth AbUser
Jim Richards's Avatar
Tim, that's a bummer. I'm looking forward to you and your FT getting back on the road soon.
Jim R.
Old 06-19-2003, 07:43 PM
Tim Walsh's Avatar
I haven't done a compression check but I think that those shavings are conclusive enough to warrent a teardown.
Jim,
I was really hoping to be on the road to but it looks like it'll be a few month minimum. I have an unknown 2.0T motor than I may drop in as a temp and run that for awhile while I rebuild the 2.4
Tim
1973 911T
2005 VW GTI
Old 06-19-2003, 07:47 PM
Bandwidth AbUser
...into a 2.7RS???
Jim R.
Old 06-19-2003, 07:51 PM
Tim Walsh's Avatar
It all really depends on expenses. The three options I see right now are stock 2.4 (blah boring), 2.5S (interesting and unique) and 2.7RS (kick ass but lots of people have done it)
Tim
1973 911T
2005 VW GTI
Old 06-19-2003, 07:58 PM
IROC's Avatar
....and 2.7RS (kick ass but lots of people have done it)
Ahhh, but lots of people have done it for a very good reason.
Sorry to hear about your engine.
Mike
Old 06-20-2003, 04:07 AM
I would rather be driving
jpnovak's Avatar
Tim, Sorry to hear about the bad news. Don't worry we can build the FT faster, stronger, and better than before.
When are you planning a rebuild? I happen to have a 3.0 under wraps that may be useful while you rebuild. I am planning to need it back by August.
Jamie
Old 06-20-2003, 04:36 AM
Tim Walsh's Avatar
Jamie,
If I do more than just a stock 2.4 rebuild it'll take me about 6 months to build up the cash so thanks for the offer but I'll probably use the 2.0 if I can.
Tim
1973 911T
2005 VW GTI
Old 06-20-2003, 05:03 AM
