The effects of a broken belt Re: idiots guide #2
Well I drained the oil and pulled the sump plate and here's what I found. They are iron or steel and not brass or Al. dtw and I are thinking it's rings or cylinder material. I'm still not sure the FT will be ready to go come sat. All depends on how bad this is.
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer Last edited by Tim Walsh; 06-19-2003 at 05:28 PM.. |
Navin Johnson
FOCUS!!!
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
I'm goin' to take more pics since these didn't come out so well
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
What are we looking at?
Neil '73 911S targa |
ok that second pic looks much better to me
Now the big question.. teardown now or later?
Administrator
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
scary? well I've already resigned myself to a rebuild.. just now or in 6 months?
Weird, looks a lot like the results of running a drill through something, or shaving the edge off of something. Very weird, I am curious to know what these are part of.
Good luck
Senior Member
almost looks like bits of the oil control ring. don't think it is but if I can find an one I will bring it with me on Saturday for comparasion
are you missing any part of the sump screen?
78 Euro 911sc Targa 03 Hayden SCWDP |
well I talked to zuffhausen and dtw and they belive it's toast. I'm starting to think the same thing. They/we are theorising that the fan stoped, the cylinders, rings and pistons overheated and the shavings are from the rings cutting the cylinders. Those peices are actually peices of the cylinder wall. Since those pieces have been through the whole pressure system the whole engine's has to be tore down.
any second opinions?
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer Last edited by Tim Walsh; 06-19-2003 at 08:31 PM.. |
The sump screens is ok and I'll bring the shavings on sat.
Senior Member
If you where cutting the cylinder walls I would think the compression would be low and you would be burning oil. Is that happening? Have you done a compression check. I would say a tear down is in order but I would be temped to buy a 3.0 or 3.2 from some of these guys sticking 3.6's in their cars.
Bandwidth AbUser
Tim, that's a bummer. I'm looking forward to you and your FT getting back on the road soon.
Jim R. |
I haven't done a compression check but I think that those shavings are conclusive enough to warrent a teardown.
Jim, I was really hoping to be on the road to but it looks like it'll be a few month minimum. I have an unknown 2.0T motor than I may drop in as a temp and run that for awhile while I rebuild the 2.4
Bandwidth AbUser
Jim R. |
It all really depends on expenses. The three options I see right now are stock 2.4 (blah boring), 2.5S (interesting and unique) and 2.7RS (kick ass but lots of people have done it)
Sorry to hear about your engine. Mike |
I would rather be driving
Tim, Sorry to hear about the bad news. Don't worry we can build the FT faster, stronger, and better than before.
When are you planning a rebuild? I happen to have a 3.0 under wraps that may be useful while you rebuild. I am planning to need it back by August. Jamie
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Jamie,
If I do more than just a stock 2.4 rebuild it'll take me about 6 months to build up the cash so thanks for the offer but I'll probably use the 2.0 if I can.
