dannichols1474's Avatar
Exhaust Header Size for My Rebuilt 2.7L Motor
I decided maybe it would be best to start a new topic thread to continue the discussion about the best header OD size for my recently rebuilt 2.7L motor.
We (mb911, mikedsilva, scarceller, winders and others) have been having a very good, enriching, knowledgeable discussion on this topic over on my "CIS to ITB EFI conversion" thread.
But that thread has run it's course as a "how to" for like minded folks that want to successfully install Al Kosmal's X-Faktory CIS to ITB EFI conversion kit.
As a recap, I decided towards the end of the rebuild of my 1975 911 Carrera 2.7L engine to employ the "bigger is better" philosophy in the selection and installation of 1.750" OD exhaust headers. All of the more experienced members of this forum quickly pointed out the 1.750" OD headers were way too big for my little 2.7L motor and that 1.50" OD headers were most appropriate.
Well, I had the 1.750" OD headers (Bursch Exhaust BX.9258.SS) installed so I ran with them for the initial start up, 1000 mile break-in. and dyno tuning run.
The dyno tuning results clearly showed there was a problem: a "hole" in the torque curve between 3000-4000 rpm.
That dyno result was not acceptable to me, so I have ordered a set of 1.625" OD headers (Bursch Exhaust BX.9158.SS) and a set of 1.50" OD headers (Dansk 1620800470 & 1620800480) which I will install and run on the dyno once I receive them. Then based on the dyno data, I will decide which size header (1.50" OD or 1.625" OD - I have already conceded that 1.750" OD is not right) to run given my intended use for the car as a weekend canyon carver.
I will receive the 1.625" OD headers tomorrow, so they will be the next exhaust option that I will run on the dyno (my next dyno appointment is Aug 28th), and I will share the dyno data as it becomes available.
Dan
1975 911 Carrera
Updated (2) Table of Contents pg17 post 339
Last edited by dannichols1474; 08-18-2024 at 09:26 PM.. Reason: correct mikedsilva's name
Old 08-09-2024, 06:05 PM
Racer
winders's Avatar
Dan,
I am running some 1 3/4" custom headers William Knight has made so I don't need another set of headers. Plus, I am not a fan of the Bursch headers in any O.D.
Here is Williams contact info:
William Knight
knightrace@mac.com
615.969.4917
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 08-09-2024, 07:28 PM
Dan the 1.625 headers will work better for sure. I want to put this information down for others to see so they can reference it.
ALL tubing is measured OD
ALL pipe is measured ID until over 12” ( that is of no concern to us folks)
ALL headers when advertised size are referring to OD. In my many years of doing this and hundreds of sets made/sold I have never seen it different. For example the original SSI was 1.5” with an ID of 1.375 because a wall thickness of .0625 and no they weren’t metric tubing and most the headers you see are not metric tubing.
I hope this helps someone else
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 08-10-2024, 02:28 AM
Hi Ben,
Thank you, that is good info for all of us.
I will add that when I was looking on the internet for off the shelf 1.50" OD headers without heat exchangers yesterday, the vast majority of the units I saw advertised were 1.625" (41mm) and advertised in US measurements.
The only exception to the tube size in OD rule I saw was from Patrick Motorsports (Porsche 911 Exhaust Header Set With Street Adapters - 1-1/2 Inch (1.50") (EXH P911 112SA)) and those units specifically state "Exhaust Headers - Porsche 911 - 1.50 in. / 38mm I.D. Primaries - Mild Steel - includes Street Muffler Adapter Set" in their description.
Dan
1975 911 Carrera
Old 08-10-2024, 05:30 AM
Originally Posted by dannichols1474 View Post
Hi Ben,
Of course, if you go for custom built headers such as the 1.75" units from knightrace that winders mentions above, you can get any primary tube size / length tailored to the specific operating conditions you are trying to optimize for.
Dan I am 99% sure that PMS is identifying OD then ID in that description which makes it even more confusing.
I also am almost certain William Knight is having his headers made elsewhere but that could be a bad rumor but regardless those are quality units.
Ben
89 944,85.5 944
914-6werkshop.com
Old 08-10-2024, 05:52 AM
Yes , if PMS unit is 1.50” OD , then their description is very confusing as 1.50” = 38mm.
Dan
1975 911 Carrera
Old 08-10-2024, 06:01 AM
It is for sure. Have you looked into MSDS headers and having them ceramic coated. If you call Marty he is extremely knowledgeable and has been doing this since the 70s
Ben
89 944,85.5 944
914-6werkshop.com
Old 08-10-2024, 06:16 AM
Crotchety Old Bastard
RarlyL8's Avatar
We've been designing and building custom headers specific to application for years.
There is a lot more to achieving an optimal torque curve and HP number than OD tubing size. Muffler design is also extremely important, we build the entire exhaust as one system where the flow is optimized from exhaust port to tailpipe. You can't expect to slap on a set of generic headers and a one size fits all muffler and have anything good come of it.
Here is the info we request:
Displacement
C/R
Induction
Cam profile
Head work and I/E port sizes
Redline RPM
Expected torque curve and peak RPM
Expected HP and RPM
How the car will be driven and if it is track or street or both
How loud and where do you want the tailpipe(s) to exit
Do you need heat exchangers
With this information a properly optimized system can be designed and produced. I cannot imagine spending the money these engines cost to build today and leaving so much on the table using an off the shelf exhaust system.
Old 08-10-2024, 06:43 AM
Bill Verburg's Avatar
You want to maintain a balance of capacity between the intake event, the combustion event and the exhaust event.
Here's a comparison of flow volume at 100% VE for the different sized combustion events, notice that a 2.7 @ 8k flows the same as a 3.8 @5.6k
a close up of the above
when sizing the intake or exhaust the idea is to keep flow up but also to though put the necessary volumes, too big a flow velocity drops too small and unwanted pressure builds
the exhaust tube length and width is also a tuning tool to constructively put a neg. pressure wave at the exhaust port @ TD compression overlap when both valves are off their seats, The more overlap the more constructive this signal is. The purpose here is to draw extra gasses out of the exhaust port and to draw extra gasses in through the intake port. But this is only efficiently done w/ open headers w/ the right geometry and topology. This neg. acoustic signal strength is solely determined by the cross section area of transitions in the exhaust, the largest being at the collector outlet in an unmuffled system.
muffled systems have this refracted wave but in weakened form and from smaller cross section transitions found in the exhaust.
There is also a destructive rarefication presented to the exhaust @~2k rpm, this one inhibits flow, it can usually be detected by a drone in the exhaust noise.
different exhaust cross section areas mostly move the torque peak up or down a few hundred rpm a long as they are close to what's need to maintain flow velocity, the gasses leave the exhaust port @`~120m/s, you want to keep that velocity up despite the slowdown caused by cooling and expansion
length of the primary tubes merely rocks the the torque curve around the torque peak
to actually move the torque curve and change it's shape you need to play w/ cylinder pairings, using what's called Tri y merges vs the usual 3 or 4 into 1 collector, it's easier to see w/ a 4 cyl or a V8 than w/ a flat 6 because the flat 6 has ideal pairings w/ the 3 into 1 we mostly all use.
to get a similar result from a flat 6 you need to do something like this
Bill Verburg
Old 08-10-2024, 01:28 PM
Dan is that centerline measurements? Pretty long headers
Ben
89 944,85.5 944
914-6werkshop.com
Old 08-10-2024, 05:25 PM
Centerline is the best way. You can take a piece of string and hold it right where it goes into the collector, then work your way down the tube and once at the flange mark the string and lay it out flat on a table and measure.
Ben
89 944,85.5 944
914-6werkshop.com
Old 08-11-2024, 02:33 AM
RarlyL8's Avatar
Critical aspect of measuring tube length at the center line is to replicate the pathway of the center of the tube by staying in the center of the bend radius, not going to the outside or inside of the bend. This may seem obvious but may not be to everyone. The spec we use on primary length is +/- 1/4" to remain true equal length.
Old 08-11-2024, 09:44 AM
VE Table After 1st Auto Tune Session With 1625 Headers
This morning I took the car out for an auto tuning session after installing the 1.625" OD headers. I ran the car mainly on the freeway at idle to about 4800rpm and mainly 0 to 60% TPS with a couple of WOT pulls.
Difference Report from TunerStudio of the After (left VE table) versus Before (right VE table).
On the right side table (1.750" headers) you can see most of the VE cell values increased (red numbers) with the 1.625" headers in the target region.
Since the AFR targets have not changed, increasing VE cell values means air flow at the rpm / load for those increased cells is also increasing. That means when I run the engine on the dyno with the 1.625" headers, the torque should also increase (more air & fuel, bigger bang, more pressure).
There will probably still be a dip in the torque curve at 3000-4000 rpm, but it should be less. Then I will install and run the 1.500" OD headers and see what that data shows me.
Dan
1975 911 Carrera
Old 08-11-2024, 10:55 AM
This is great VE comparison data on the two headers - thank you for posting the analysis.
It looks like you have a nice bump 3k-4.5k with the new headers --- and even better, no loss on the top end. I look forward to seeing the dyno and 1.5" header comparison.
Old 08-11-2024, 08:04 PM
Maltese Falcon's Avatar
Thx Ben for the MSDS,inc. honorable mention !
We mfg this 'Merge collector style>> much like the way the factory built their competition racing headers back in the '70s. 1.625" od is correct for a 2.7L; and as a side note we mfg the three popular sizes 1.500" 1.625" and 1.750" od's...and No upcharges for the larger sizes either.
Three styles of 1,650°f Ceramic coating availble.
www.msdsinc.com
Porsche builds the 21st century 9146
so easy...even a Cayman can do it !
Old 08-11-2024, 08:34 PM
Racer
winders's Avatar
This evening I got back out to the garage to re-measure the length of the primary tubes on the headers I am (had been) using.
I used the string down the inside of the primary tube method suggested by Ben (mb911).
I tied a nut to the end of the string and dropped the nut into the head flange end of the primary tube, then moved the header around until the nut came out at the flange on the end of the collector. I pulled the string taught and marked the string with a black Sharpe at the edge of the head flange. I marked and measured the distance from the end of the primary tube to the collector flange - 5 inches.
That is not what Ben said to do. the method you are using is not close to accurate. Look here:
https://forums.pelicanparts.com/911-engine-rebuilding-forum/940145-how-primary-length-measured.html#post9406586
The key is to keep the string at 90% of any turn...this means you may not be able to measure it without measuring in sections.
Scott Winders
PCA GT3 #3
Old 08-11-2024, 11:16 PM
(man/dude)
Jonny042's Avatar
Yes, thanks for posting this! The information posted by the OP (so far!) has created the single most valuable header diameter thread that I've seen.
I also was very interested to see the lack of change in the upper range of the ve tuning, but it was unclear if the autotune session included any activity in the upper RPM ranges?
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 08-12-2024, 06:28 AM
Hi Jonny,
When I ran the auto tune session I stayed in the 2500-4800 rpm range to focus on changes in the 3000 - 4000 rpm region of the VE table - so cell values in VE table above 5000 rpm haven't seen the effect of the 1.625" headers.
Dan
1975 911 Carrera
Old 08-12-2024, 11:41 AM
PCA Member since 1988
The string method is close enough. The difference of an inch or so will make very little difference in the computation of resonances in the exhaust primaries.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 08-12-2024, 12:27 PM
Hopefully, 3rd time gets me in the ballpark. This time I measured each welded section individually from center of weld to center of weld, positioning the header so the I was looking down on the section, orthogonal to the plane of the curve of the section, and used the string to trace a path along the centerline of the section. Then I added the sections together to get the length of the primary from the head flange to the end of primary in the collector.
1.750" OD header - #1: 34 3/8", #2: 33 1/2", #3: 33 1/8"
Dan
1975 911 Carrera
Old 08-13-2024, 08:00 AM
