techweenie's Avatar
Any tricks to restoring faded black anodizing?
I dislike the idea of spraying black paint on the rear grille on my '73, but it's gone all the way through the purple stage to a silver-grey...
Is there any kind of treatment other than reanodizing?
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 06-30-2003, 08:21 AM
RETIRED
Joe Bob's Avatar
Have you tried Vaseline? They say it works on anodized Fuchs....
2012 ML350 3.0 Turbo Diesel
Old 06-30-2003, 09:08 AM
techweenie's Avatar
I havent' seven *seen* Vaseline for years. I'll try it... what the heck.
1969 coupe hot rod
Old 06-30-2003, 09:18 AM
Certified Pre-Owned
BGCarrera32's Avatar
Yes, take it off and have it reanodized...
'84 Carrera Coupe
Old 06-30-2003, 09:36 AM
Anodizing, by itself, has no "color", it's a form of protection created by forcing the creation of a particular aluminum oxide on the surface of the part. The "black" that's fading on your car (and a couple places on mine) is paint or, perhaps more properly, a stain; usually these pieces were dipped rather than sprayed, but either is acceptable.
Jerry M
'78 SC
Old 06-30-2003, 09:41 AM
Autodidactic user
David E. Clark's Avatar
What's the best way to remove the old anodizing?
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 06-30-2003, 09:59 AM
IROC's Avatar
Jerry M
'78 SC
Actually, you can anodize in different colors. Black especially is common.
Mike
Old 06-30-2003, 10:01 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Deanodizing. It's the reverse process of anodizing. I believe you dip the whole thing in a solution that reverses the anodizing process.
Look in the yellow pages for your local area and you'll be surprised to find how many metal finishing places might be in your area. I was. But I live in a highly populated suburban area outside of Chicago so.......
Or you can use something harsh like a lye solution. Easy-Off oven cleaner is a milder version of this.
Kevin L
'86 Carrera "Larry"
Old 06-30-2003, 10:45 AM
Certified Pre-Owned
You can anodize in many different colors, by adding dyes and or complimentary metals to the process. You can have the shop doing the plating chemically strip the old stuff off first, and than reanodize. You could also have them hard-coat anodize it, where a thicker and stronger anodizing is done, by cooling the chemical process with a refridgerant system (slowing down the oxidation process.) Make sure you tell them it is going on a car, and that color and uniformity are important to you. Ask to see samples if possible, or find another friend in your area who has had it done. Some shops may be unwilling to mess with your small parts, and be prepared to fork $100 or so for a few pieces.
If you are feeling creative, you could try these guys:
http://www.caswellplating.com/
-BG
'84 Carrera Coupe
Old 06-30-2003, 10:48 AM
Chuck Moreland's Avatar
I love the look of the early metal grille when worn / faded. The patina gives it character, a sense of history. Wear it with pride.
Chuck Moreland - elephantracing.com - vonnen.com
Old 06-30-2003, 10:49 AM
-BG
Quite right, almost any color is possible, but, correct me if I'm wrong, but the anodizing is done first then, if you want color, the piece is dipped in stain or dye. So couldn't you re-dye the, already anodized, piece? Or does the loss of color mean the anodizing is also lost?
Jerry M
'78 SC
Old 06-30-2003, 11:00 AM
Certified Pre-Owned
Well, I always thought that you added dye pellets to the solution itself at the time of anodizing, but you may be correct. Perhaps they anodize, dye, and then seal it...
'84 Carrera Coupe
Old 06-30-2003, 11:05 AM
If it is possible to just re-dye, it would certainly make refurbishing some of these trim pieces easier.
Jerry M
'78 SC
Old 06-30-2003, 11:20 AM
Certified Pre-Owned
Yup, I'd be interested in knowing...
'84 Carrera Coupe
Old 06-30-2003, 11:35 AM
Information Junky
island911's Avatar
. . the anodizing is done first then, if you want color, the piece is dipped in stain or dye. So couldn't you re-dye the, already anodized, piece? .. .
I do believe he is right.
Try the Rit-Dye trick. That stuff is amazing. It will find it's way even deep in between plastic molecules! Considering how porous anodize is, it should be easy.
Old 06-30-2003, 06:18 PM
techweenie's Avatar
Rit Dye
Wow! That is one amazing trick (the knobs).
I bet it'll work on the grille.
I don't mind the faded-pewter color, but a P.O. had a couple of badges on the grille and they left shadows...
1969 coupe hot rod
Old 06-30-2003, 06:53 PM
nostatic's Avatar
What, no one else uses a Sharpie pen (permanent marker)? Works great for sunroof felt too...
Old 06-30-2003, 06:59 PM
That's the trick Todd. Works for me and costs about 1/100th.
1987 Carrera, Guards Red, Black (sold but never forgotten!)
1965 356SC Coupe, Silver on Red
Old 06-30-2003, 07:09 PM
Information Junky
island911's Avatar
I've seen the Sharpie pen trick on lug-nuts. It kinda looks "off" IMO. . .kinda slightly purple-ish.
Though, maybe that was Magic Marker. (?)
Old 06-30-2003, 07:15 PM
fogcity's Avatar
Techweenie - where the Hell do you keep all those cars?
1984 Carrera Coupe
Old 06-30-2003, 07:17 PM
