Ebrake install help for 930 rears on 911SC
Hi all!
I looking to work out what parts I need to reinstall a mechanical ebrake system on my 911SC that has 930 brakes installed. I believe all the ebrake parts have been removed as this was a racecar and gutted in a previous life. Are brake parts universal? I will get some pics shortly to work out what to do! Any other options other than factory ebrakes handle / actuator that are popular? Thanks in advance! Last edited by Tap46; 11-10-2024 at 03:50 PM.. |
e-brake using 930 calipers
This kind of implies I need something custom…. Willwood mech calipers or some mod to factory stuff to make it work. My calipers are indeed on the forward side of the rotor. Maybe it would work on a 911 vs the thread is for 914? Unclear. Last edited by Tap46; 11-10-2024 at 04:37 PM.. |
![]() ![]() PS: Or do you mean 930 non turbos (no 4-piston calipers)?
Roland 930 Turbo '81 Too many modifications to list |
Registered Minimalist
Were your 930 brakes redrilled for 3" spacing to fit on the SC trailing arm? In that case I might try SC parts. I think they would work even with the different Turbo rotor but haven't done it personally.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
I mean that the SC parking brake works fine w/ either 911 or 930 rotors, I've had mine for over 40 yrs.
yes the 930 calipers need to be modified to 3" leading mounts and the dust shield will need top be discarded, but the parking brakes are totally compatible.
Thanks all! Will post some pictures shortly today and get some definitive answers hopefully on what to order
Did this on my "83 SC a while back. All of the parking brake hardware was retained and works perfectly with the 930 rotor. You can see in pic # 3 and # 4 the parking brake backing plate with the rotor installed.
1983 911SC 1977 930 Turbo (again) 2018 GTS 2023 Audi A4 '74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone) |
Pics
Pics for more clarity
Pic of bolts . Hard to see or know what modification was done to mount?
Hard to measure but seems like 3 spacing? Maybe 3.1 by my paper impression but probably its 3
all 911 from at least 69 are 3" leading mount, stock the calipers need to be modified to fit the al. semi trailing arms or new inner halves w/ the proper 3" mounts purchased, part #911.352.540.00 ![]() ![]() ![]() stock 3.5" rear ![]() modified rear
Hmm seems I have the new inner half as it looks like that part number
Ok so consensus seems to be I can get all the SC parking brake gear and it will work! I’ll let you all know how it goes!
