LinkBack | Thread Tools | Rate Thread |
Almost a bad day, then good day, but maybe bad again! Trans Fluid Change
83 SC, just turned over 65k miles.
Another good opportunity to remind folks to remove your fill plugs first! I did, fortunately, and I almost became a prime example of why. I don't know if its a PO or shop that blasted this thing tight after a fluid change or this is just the nature of these drain plugs if they haven't been touched in over 10k miles. but I was very close to having a less good day... deformed and cracking. I almost called it quits, but then I pulled out a bit of aluminum tape and gave it another shot and fortunately it budged and backed out. So thats where my almost bad day turned pretty good actually, but then I turned the plug around and I see this.... The records that came with the car indicate the trans fluid was changed at 55k (and quite possibly somewhere between 61k and 63k - its unclear) I'm not sure what to make of it really. The 915 shifts nicely, especially now that I've installed a WEVO. She can be a bit cranky at times but I believe she does perform in line with what I read on the forums as "normal". Luckily I got a service kit that includes new magnetic fill & drain plugs along with Swept from our host.
1983 911SC - Helibronze Metallic L966 Last edited by cky3396; 11-17-2024 at 10:28 AM.. |
Replace the fill plug with a drain plug with the magnet. So you end up with two magnets.
The differential throws oil right on the top plug. The magnet will catch metal particles before it goes through the rest of the transmission. I noticed I had a LOT more crud on the top plug than the drain p[lug. Engine drop and transmission taken apart to replace the differential bearings. The rest of the transmission was fine.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
yes thanks glen I have set of new magnetic trans plugs. interested to check out the fill plug magnet next time around
1983 911SC - Helibronze Metallic L966 |
gearhead
Totally normal. No chunks. Just fine synchro shavings. Carry on.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Cheers thanks Matt. That was my guess as well and based on the transmission feel in general I felt pretty good about it.
The previous gear oil was definitely different.. now just interested to see how the swepco compares. The old stuff also didn’t seem as viscous |
PCA Member since 1988
Ditto what Matt (the expert) said. It's normal for manual transmissions to generate some fine fuzz. Just watch for trends or bigger bits.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Then it's a good day all around !!!
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
