After the next project
Flag mirror 1976 - where to connect this plug?
Hello,
I have another question for the experts. I purchased this car as a project and finally getting it back together after repaint, engine rebuild and interior work. I am unable to find this plug in the frunk area that this is supposed to connect once it travels from the door into the car. I started to look under my dash as I thought maybe it was there but my memory is telling me it connected inside the frunk. I can't seem to find the other connection plug that matches anywhere. Could someone provide an idea of where it would be sitting so I can a better idea of where to start tearing into? Thanks in advance! Pic below.
Current cars: 2012 Cayenne TT, 1997 993TT, 1912 Buick Model 34, Audi S8, 1976 912E, 2016 Cayenne Diesel |
Should be near the hood hinges on the respective side of the car. Can be tucked back a bit.
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings) Dynamic CR calculator: https://dcr.questionable.services/ |
Thanks @silverlock
I was also thinking the same thing as I remembered where I detached it from but can't find it. It would be helpful if I knew where it had come from... maybe then I could trace backwards to find it! Thanks for any additional help.
ROW '78 911 Targa
Find the only violet/black wire connected to the fuse panel and follow it into a small loom towards the lower hood strut area.
ROW '78 911 Targa
76-77 drawings: remember to count your fuses from the headlight back to steering wheel when using factory schematics.
