Trackday experience has saved my bacon.
I was coming home from just having had four new tires fitted to the 911 and wasn't going fast. But there was a very slow bus going downhill through a S bends section of road. I decided to pass and WHOO I was going completely sideways past the bus and still in the S bends. I said to myself remember Manfeild Raceway and I gave it just the right amount of gas to not go backwards into a powerpole and to make the rest of the S bend. I suspect the tire company had coated the tires with something like silicon to make them shiny and pretty. |
I was driving to the track first thing with a brand-new set of Direzzas once, in light rain - and had to brake hard/abruptly on the freeway because everything stopped. Fully expected a bad outcome - but I'd apparently got enough miles on them by then, they behaved like champs...
'77 S with '78 930 power and a few other things. |
That release coating is even worse in the wet. Like a bar of soap. There really probably should be a warning over that. Someone goes out with a flash set of new tyres thinking - whoohoo, I've got super grip now.......
Thats what people mean when they say ' scrubbing the tyres in". Scuffing them up to get rid of that surface coating. Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
Still here
I suspect going sideways would scrub those tires in ... in a hurry
^^^ I scrubbed my tires in at 100 mph.
https://www.youtube.com/watch?v=gLPH7tFUVwQ https://www.youtube.com/watch?v=VchkuH6X5FI Last edited by A930Rocket; 01-20-2025 at 01:54 AM.. |
Hehe, that's quite fast for a bit of off-roading
Still here
and to top it off, Majel Barrett intones .. 9.36 seconds ...
Bland
So many variables…
If you want it to slide out, put in heavier torsion bars and a stiff antisway bar. In our chump 911 we ran no rear sway bar to keep it as driver friendly as possible. I did get it to rotate (spin) at Spokane in a race but it was very predictable up to that point. Far better than my other 911 track car with 29mm rear torsion bars and a stiff rear sway bar.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche Last edited by unclebilly; 01-20-2025 at 03:11 PM.. |
As a first approximation, you could ask the question: "at what lateral acceleration should I watch my rear to go?" There are plenty of second-order effects though. Some of which have already been mentioned in this thread.
📸 https://www.instagram.com/porsche.tech 📸 |
Those flat high speed long corners are a challenge. Alan
As all have said, there is no speed it will just suddenly oversteer. The summer of 2024 I was at Talladega Super Speedway going 125, AC pumping cold air, and my wife in the passenger seat, just cruising.
You can have oversteer easily in first gear in a tight turn. Tire pressures and suspension setup make huge differences, but the lose nut behind the steering wheel is the biggest determination of it.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! Last edited by GH85Carrera; 01-22-2025 at 05:22 AM.. |
I've found a good place to practice 911 handling is on a gravel road. Obviously with no one coming the other way LOL
Understeer happens easily , and oversteer happens VERY easily, without going fast. It's like taking your puppy to the dog beach - a lot of learning about what point gets you into trouble and how to get out of trouble. |
Still here
Looks like an offroad excursion well traveled by others less skilled. ![]() |
This was at Roebling Road last spring. When you see the windshield wipers, that’s me turning off the engine, as I didn’t know if I blew the motor up, fire, etc. ![]() ![]() ![]() ![]() Last edited by A930Rocket; 01-21-2025 at 06:45 PM.. |
Still here
^^^Yeah .... skid marks ... I won't ask further
![]() That's a nice track with the wide expanse of flat grassland next to the tarmac. I actually meant the second incident by my previous comment which you did save. |
Ah. That save was right after the kink on the back straight at Carolina Motorsports Park last fall. It happened so fast, and there was a 90° left-hand turn right after it. Didn’t have time to think about what could’ve happened. That’s why I will always track the BMW versus the 911.
When I did Robeling Road in a HPDE, they did not know me at all as I am from Oklahoma, and they assigned me an instructor for the first run. I ended up with the head instructor. Coming onto the front straight, I overcooked the turn and had my tail hung out as we slid out to two wheels in the grass. I calmly and instantly corrected the situation as I knew the grass was not good traction. I got it straight and continued on for several more laps. The instructor said you get bumped to the next level up, as you did great on the grass excursion. He added stay off the grass with a grin.
Years of autocross and an many HPDE as taught me how to keep an analog car on track. My daily driver is a 1986 El Camino with a limited slip rear end. Driving in the rain can be tricky. Leaving a stop sign or red light and making a right turn, I know to give it very little throttle. I can pop the rear end out and take the corner sideways easily as I say weeee. My wife punches me in the arm when I do that ![]()
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
did the rear end catch and push you off your line? looks like you made that corner before that happened? |
After getting it towed back to my staging area, we loaded it onto my trailer, and I brought it home. Long story short, one of the oil lines from the oil filter housing to oil cooler popped off the fitting. I was using Aeroquip push on connectors and Aeroquip hose. It was rated for the oil pressure and temperature, but I suppose being hot, it’s softened enough that the oil pressure pushed it off. I cleaned everything up and installed two.Otiker clamps on each end of the oil lines. No problem so far. |
Thread Tools | |
Rate This Thread | |
