911sc 3.0 1982 Engine Harness source
Just pulled my 911sc engine . 1982 3.0.
The wiring has been butchered and messed with and there are some burnt wires; the engine started and seemed to run fine before I took it out. I think it's time for new sub harness - engine harness. Multiple sources and multiple prices - any suggestions please ? Also should the car have an oxygen sensor ? books says it should but nothing to be found - just a cut green wire ![]()
‘82 SC’s had oxygen sensors, although they are not required to run (open loop mode).
Harness should be 911.612.016.04 for an 82-83 car.
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings) Dynamic CR calculator: https://dcr.questionable.services/ |
https://911-manuals.questionable.services/porsche-pet-911-sc.pdf will be your best friend.
You still need to hook up the lambda control under the passenger seat.
The connector behind #3 intake should plug to the harness inboard the left rear shock. Your pre lambda cat replacement not showing tap for ox sensor. I have replacement cat pipes if you decide you need the sensor installed. Bruce |
He even fitted the much larger alternator cable that came with my 175A Classic Retrofit alternator. ![]()
Find Spoke's LED Products: www.spokeworksled.com |
Kroon Wire Harnesses
https://www.kroonwireharnesses.com/porsche-911/porsche-911-1982/wire-harness-for-engine-sc-82-83
We can also deliver it in a "HI version" https://www.kroonwireharnesses.com/porsche-911/porsche-911-1982/engine-harness-for-porsche-911sc-82-83-artno-91161201604hi-upgraded-25mm2-alternator-wire-for-high-output-alternators-
Kroon Wire Harnesses Specialized in Classic Porsche electrics www.kroonwireharnesses.com Check also our Facebookpage: https://www.facebook.com/kroon.wireharnesses |
Timmy2 (Dennis Powell) makes fantastic harnesses. Custom harnesses too. Almost all the harnesses in my '70 are from him. Some are custom. Car wouldn't be running without him. Easy to talk to.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
I just received a harness for my 81 SC from Timmy2. Very good craftsmanship.
dennis (Timmy2) makes all of the harnesses for my EFI kits....good stuff.
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
+1 on Dennis. He got me setup on a harness for my 82SC. Same situation you are in now. Great fit and finish with all wires labeled was a plus!
Look up Restoration Design. They have what you need all to OE spec.
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Thanks Jeff - sourced from Restoration -- met them in LA - it was on special too !!!
