kellzey's Avatar
What is header collector diameter?
I know the primaries for headers can be 1.5", 1.625", or 1.75".
What is the ID of the collector portion of most headers? (i.e., the ID of the part that bolts to the muffler)...
2" 2.25", 2.5"
Thanks,
Karl
Qarl
Old 07-03-2003, 03:38 PM
Bill Verburg's Avatar
B&B headers
1.75"OD Primaries
1.625"ID Primaries
2.25"OD Collector
2.125"ID Collector
weight
26lbs
SSI headers
38mm 1 1/2"OD Primary
1 3/8" ID primary
42mmID 1 7/8" collector
51mmOD 2" collector
Weight 24lbs
Bill Verburg
Old 07-03-2003, 03:56 PM
kellzey's Avatar
Alright... so if I am going to look at a muffler such as those offered by Coast Fabrication or Burns Stainless...
Should I go with one that has a 2.0" inlet, 2.25" inlet, or 2.5" inlet? I, of course will have to weld a flange to it to mount to the headers...
The Coat fab mufflers offer a larger exit diameter as well (i.e., 2.5" inlet diameter, and a 3" outlet diameter).
Any advantage/disadvantage to something like that?
Qarl
Old 07-03-2003, 06:52 PM
I used 2.5" OD ss tube going into 2.5" ID muffler can inlets for a slip fit. The ss tube serves as an extension of the collector.
The Coasts sound fabulous!!
Bill Verburg
Old 07-03-2003, 07:39 PM
Navin Johnson
TimT's Avatar
get a muffler with an inlet dia that equals or exceeds the dia of the collectors you have. 2.5" should be fine.
'69 911 GT-5
'75 914 GT-3
and others
Old 07-03-2003, 08:02 PM
