Have you read this thread?? If nothing else, it may give you hope
![]() https://forums.pelicanparts.com/porsche-911-technical-forum/670262-spark-plug-socket-stuck-2.html |
Use an easy out ( spiral bolt extractor) first freeze it with a can of duster hold the can upside down. Screw in the extractor and use vice grip slide hammer.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
Freeze the socket
If it went in it must come out, i would leave the spark plug screwed in by hand, there are locking extensions that capture the socket. And jiggle, swear at it. You will get this.
Are you using a universal joint on that socket or is it connected directly to an extension? Sounds like a U joint configuration has become misaligned. If so, move the joint around to try different angles.
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
as i mentioned we need to see the picture of the problem and the tool
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Thank you all very much for the responses. Sorry, I've been pulled away from this project for a water leak at a rental today...
I'm just using a 3 inch extension directly into the socket. As soon as I can get back at it, I'll post a couple of pictures. I'll also try the upside down duster to freeze the socket when I'm back at it. Thanks again! Christian
1983 911SC Cab |
911sc stuck socket/spark plug in hole #1
It came out. thank God!!! I used Dpmulvan's method of attempting to freeze the socket with upside down dust cleaner can, but I used a small pair of vice-grips (used by another person on pelican having a similar issue). After spraying, and then wiggling around, I was able to shift the socket in such a way that it, with quite a bit of force required, slowly slid out.
A good 5+ hours of dealing this this crazy issue. Now I need to figure out why it happened in the first place, since I have never had this issue before in the 26 years of owning this car and doing my own maintenance. I'm grateful for all the responses and encouragement...thank you all! Here are two of several pictures that I took this morning, attempting to capture the issue of the flared part of the socket stuck in the back of the hole/well, as well as a picture of the socket removed. ![]()
1983 911SC Cab |
"But instinct is something which transcends Knowledge We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile" Nikola Tesla |
Still here
Have these in the tool kit ?
Thanks pmax. Can you give me the name of what those are called?
1983 911SC Cab |
PCA Member since 1988
If you use the original toolkit spark plug tool, you will have a hard time overtightenting the spark plug, which will make it easier to get out. Although I have a 3/8" ratchet and appropriate length socket and extension, I make a point of using the tools above so that I don't over-do it.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Thank you. I'm going to order them now.
1983 911SC Cab |
or get yourself tool like this.Craftsman socket and 2 extensions
No need for snap on -kinda expensive i would imagine these days,any other brand will do I use mine since 1986 .. Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 03-26-2025 at 03:30 PM.. |
Thank you Ivan!
1983 911SC Cab |
Slippery Slope Victim
The factory tool is the best IMHO. I have a slew of plug sockets and revert to the factory one. Just make sure what ever socket you purchase is thin wall. Whenever I have used a socket and extension for plugs I duct tape them together.
Mike² 1985 M491 |
+1...get the factory tool......works great
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
This is my favorite because it’s one piece, swivels, is narrow, and magnetic so no dropped spark plugs.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
I have three or four of these in different lengths. I like them, because I’ve had the extension fall off the socket. Of course, you could tape them, but it’s nice to have the right tool.
Wildman Emeritus
I just love happy endings(not the massage type). They serve as a reminder of how things can go wonky but can be resolved with time, patience and the help/advice of others.
Lost a socket doing this but managed to get it out fairly easily. I have used the tool kit tool ever since with no problems.
Mike Andrew 1980 SCWDP 2024 Suby Forester 2018 BMW X1- Wife's 2000 Boxter - Sold |
