Low voltage at idle with AC running
Now that it is getting warm (mid 90s the last 2 days) - my new Griffiths AC is getting properly worked out - producing some nice cold air in the cabin.. love it!
I changed out my USB charger in the cigarette lighter spot with one that shows voltage. At speed on the freeway getting 13.5ish Volts - which seems to be ok..sometimes dropping below 13, but not often.
At idle, at a stop light - drops down around 12, sometimes even 11.8 or 11.9 -
I don't sit at idle for long of course - so I'm not draining battery to a point where I'd see problems I think...
So question is - long term, is this bad for the electrical system? Should I really be looking to update my alternator? (WOSP?) - or just a newer battery?
Any thoughts?
1986 Carrera 3.2 Coupe in Grand Prix White
IG: @c.cal.porsche
Old 05-10-2025, 04:19 PM
Been here a while
I’d think your 3.2’s factory alternator puts out enough amperage to cover the griffiths AC system. I’d check the chassis grounds, but it might be time for an alternator rebuild. No need for the WOSP unit. I run a 3.6 with the full Mr Ice package from Griff, never see voltage below 12.5 and a steady 14 when cruising. Truth of it is that, unless you spend more time idling than driving, your battery is going to be fine.
looking for 1972 911t motor XR584, S/N 6121622
Old 05-10-2025, 04:44 PM
You might check the voltage with a high accuracy meter to verify you’re not chasing your tail. Also, you might make sure you idle is 950 rpm.
Old 05-10-2025, 05:07 PM
Almost all alternators do not put out much amperage (power0 at low RPM. I forget the numbers now, think I posted them in my long electric A/C thread……it’s something like a standard alternator in a car like the 3.2 will put out 25 amps at idle. Thats why headlights can dim slightly, interior lights etc. 12000-1500 RPM they are pretty good, and probably making max power by 2000 RPM. Some cars even run pulley that under drives the alternators for more HP. The Classic Retrofit alternator makes massively more power (amperage) at idle, and was specially designed to do so to support their A/C. I think it makes almost as much at idle (90amps or something) as the 3.2 ever makes. Even your Grifiths A/C draws a lot of current at idle, between the powerful blower fan, the condenser fan(s), etc. Also remember the A/C compressor does not work as well at idle. Even in my 2021 Jeep Wrangler, the air gets MUCH colder if I am at a stop light and rev the motor to say 1500 RPM. Good luck with your challenges.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 05-10-2025, 05:09 PM
kuehl's Avatar
Ccallana is not running the high out put evaporator motor. And, the 2 added fender condensers with fans do not add enough amp draw to cause battery amp capacity issues. And, he has the variable fan speed controller which tends to lower overall amp consumption.
He could do battery and alternator tests just to check how they are holding up; better to be proactive then find yourself stranded.
Even the factory A/C draws a lot of current at idle; never mind when you turn on high beams.
Statistically, with Griffiths systems out on the road nearing the 30 year mark, now worries here.
Kuehl
1987 911 cab, modified
https://griffiths.com/
Old 05-11-2025, 04:31 AM
pavegeno's Avatar
Send a message via Skype™ to pavegeno
I did this and it solved all of the same issues. Voltage sits high 13s to low 14s. I have full Griff’s with the dual Keuhl in the LR wheel well. Good luck.
https://www.classicretrofit.com/en-us/collections/upgraded-alternators/products/porsche-911-high-output-175a-alternator-kit-1984-1989
2002 GMC Yukon SLE - 4AT - Purchased New in 2002
1988 911 Cab - 5MT - Purchased Used in 2005
2008 Cayman - 5MT - Purchased New in 2007
2014 911/50 - #1173 - 7MT - Purchased CPO in 2014
2019 Macan S - 7PDK - Euro Delivery/New in July 2019
Old 05-11-2025, 05:29 AM
Thanks Griff! Correct - running the standard Evap fan motor -
Probably a good idea to get more accurate measurements than the $10 USB readout Battery is pretty old actually.
Thanks all for the comments and suggestions.
IG: @c.cal.porsche
Old 05-11-2025, 07:12 AM
I have pretty much the full Griffith's upgrade. 4 condensers, all new hoses, hurricane blower, variable speed fan controller, and temp controller. I do have the OEM original front and rear condensers, and no need to upgrade them as I get 38 degree air on hurricane velocity, on a 107 degree day after driving for 10 hours.
My old alternator was rebuilt 25 years ago and I noticed it was starting to rattle and the bearings were going bad. I tried to have it rebuilt, but the only local guy I could find did not get something right, and now he seems to be out of business.
I bought a brand new Valeo alternator. Now it sits at 13 volts even at idle with the brakes on, and the AC blowing at max. Once off of idle, it goes to 13,5 volts.
I had my tachometer changed to add a voltage gauge where the stupid shift light was. This was years ago, as I have almost 199,000 miles now.
Old 05-11-2025, 07:34 AM
PCA Member since 1988
Same as Porshedude said: First check that your lighter/voltmeter is accurate. These are usually cheap Chinese crap and I've had several that were not accurate. There's only so much you can expect for just $10.
If the voltage is slightly low at idle with the compressor engaged, but comes up above 13.5 when you get above idle, dont' worry about it, that's normal, as others have suggested.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 05-15-2025, 11:15 AM
