Install pop out rear quarter windows
This is the closest I can come to writing a "tech article", which, considering the source, is amusing. Please suggest alternate methods if what I've done is heavy handed or stupid and I'll edit as appropriate. FYI, the source is a newbie, former Marine. If you've never been acquainted with such a creature, Marines like to do things like frontal assaults and kick unexploded ordnance.
Please forgive the horrible images--my camera was lent out. The car: 1979 California SC, no a/c What you need: 1. pop out windows from an older 911 2. hinged latches and white plastic flange that fits between the latch and the headliner. All should come with the windows ![]() 3. bottom metal trim which covers the ledge (photo courtesy of island911). This image shows your original, more narrow trim vs the wider, old trim you need: ![]() 4. tap for the rear latch holes 5. nut inserts for rear latch holes in the c pillar: M8 exterior; M5 (or less) interior. Note that the holes are untapped and 8mm sized; but the screw which fits through the latch holes is 5mm 6. sheet metal bolts for the latches: M5--can't remember the length but take the latch and flange to the hw store to ensure you have 1/4 inch or so of threads 7. self-threading sheet metal screws for the B pillar holes--I drilled out the holes a bit to M8s, but this was a mistake; I should have used a tap (don't know the size) and the hex screws that came with it. Oh well. 8. headline molding trim (see photo above) 9. b pillar molding trim (see photo above) 10. tap for the c pillar holes--M8 and match the thread Howto: 1. Remove black vinyl or leather interior trim at the base of the window 2. Remove old fixed windows: no picture, but it's easy. Use a putty knife or box cutter to separate the fat rubber molding in the interior of the window from the glass. Pull away the molding and gently push out the windows. 3. drill out the "spot welds" on the b pillar. This piece of thin sheet metal covers the slots through which the "tabs" of the leading edge of the window will go. I do not believe there's a workaround for this--prior discussions have questioned whether this piece is structurally necessary. All I can say is that it is very thin and I don't really need the extra stiffness in the frame anyway, even if it did add to it. Drill out the "filled in holes" all the way through then take a large flathead screwdriver and hammer and insert the screwdriver between the new piece and b pillar on its leading edge. The piece will quickly pull away from the b pillar and you can pretty easily pull it off. File or dremel around the spot weld holes. ![]() continued...
Warren Hall (Early S Man), 1950 - 2008 ------------------------------------ 2006 Tri D675 Scorched Yellow 2006 Ducati Sport Classic mono SOLD 1979 SCWDP #0020 Talbot Yellow SOLD Last edited by holtjv; 05-20-2007 at 05:41 PM.. |
4. Locate the c pillar holes with your fingers and punch through the headliner with a phillips head screwdriver or whatever. Tap the c pillar holes. If you've never tapped a hole before, buy the tap (ensure you match the threads--I bought an M8 with 1.25), a t-handle, and lubricate the tap prior to tapping each hole. I used wd40.
![]() With the tap inserted: ![]() 5. Screw in the nut inserts ![]() 6. Install the bottom chrome or anodized trim (you can do this anytime, really). You'll need to drill a hole for the end piece on its leading edge as well as one of the top trim holes. I'm certain this will vary for each car but it's what I had to do. 7. Install latches onto window, if not already done. Take a look at the latch and make sure you have it oriented correctely, with the knob up and the flange which attaches to the window correctly oriented. You'll see what I mean. 8. Gently pull away the interior trip from the b pillar to expose the holes. Drill out the b pillar holes for the size of self-threading screw you bought, or thread the holes for the included original hex bolts. 9. Insert window through the slots and align with the holes. Use a screw driver to move the tabs inside of the b pillar. 10. Screw in b pillar bolts or screws ![]() 11. Screw in the rear latch into the c pillar 12. Slide on the window frame headliner molding. I glued it on. 13. Slide on the b pillar molding 14. Installed! ![]() 15. Enjoy!
Warren Hall (Early S Man), 1950 - 2008 ------------------------------------ 2006 Tri D675 Scorched Yellow 2006 Ducati Sport Classic mono SOLD 1979 SCWDP #0020 Talbot Yellow SOLD |
threads referenced:
Fixed rear quarter window? Rear quarter window Modification Many thanks to spyderman for selling me the kit--everything I needed. Any questions feel free to PM or post. Regards, Jack
Warren Hall (Early S Man), 1950 - 2008 ------------------------------------ 2006 Tri D675 Scorched Yellow 2006 Ducati Sport Classic mono SOLD 1979 SCWDP #0020 Talbot Yellow SOLD Last edited by holtjv; 05-20-2007 at 05:26 PM.. |
Jack can you email me your tele # so I can call you and save typing for an hour. My email is:
bobf@design-associates.us Thanks a lot! Bob
I live for 911 tweaks... |
Senior??? Oh very well
Kewl....thanks for sharing....
I'd love to do this to my '88 Carrea but it's so choice, I cant bring myself to do something like this..... |
bookmarked
99" 996 C2, 04" Mini Cooper, 66" sprite (scca "DP" sold) 87" M5 (sold), 73" 914 2.2 (sold), 72" 914 1.7 (sold) 79" Alpina B6 (sold) |
I wonder if this can be retrofitted into a 964.
-Don |
(man/dude)
One thing to note to others rounding up the parts to do this - the white plastic edging along the headliner shown in the above post may not be available - if you check the 1973 pet this edging is black and comes in a roll, it's often seen on cars around the door opening.
It's a u-shaped rubber channel that has metal embedded in it so it clamps itself around a flange. |
(man/dude)
BTW - To the OP - Thanks and great tech article!
Thanks for the post...
I want to add these as part of my backdate, but it is more involved than I thought it would be. It looks like I need to round up a few more parts!
Nice DIY - this will prevent some trial and error that could have ended badly. |
The windows I received didn't come with the plastic spacers. Does anyone know if they're still available?
This is excellent.
Jonny042 brings up a good point. I believe the fixed window installation eliminated the need for welt covering the flange at the top and front of each window opening. Pop-out equipped cars used a black welt on the b-pillar flange and off white welt along the headliner flange.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
Great write-up.
I would be curious to know if you get any water in the window (especially when washing the car). My '74 has pop out windows and I get a small amount of water when I am washing the car. I don't really get any during a rain storm. I've always wondered if this is normal. |
I'm thinking of using this which appears to be the same sort of thing for Beetle pop-out windows. $20 for 2 - 75" pieces. https://www2.cip1.com/ProductDetails.asp?ProductCode=C16-113-131B-BK ![]()
I ended up buying some pinch welt from Jbugs.com, it was about $25 shipped for a roll with enough to do both side and plenty to spare.
Black Pinch Welt, (Seal clips on body) Fits All Years. - JBugs.com This is what it looks like ![]() ![]() And installed ![]() ![]() ![]() I cut a slit in the top pinch weld so it would run past the vertical piece
When I purchased my 912, it did not have the rear quarter window trim sill. I just bought a set as well as the special screws from Pelican. Is there a rubber/weatherstrip piece that goes in between the sill and the quarter window frame? If so, any idea what the product number is, or name?
Oddly, there were both white and black bits of dum-dum / butle tape under there. ![]() ![]() ![]() ![]() ![]() ![]() Tim K |
Banned but not out, yet..
After doing an AC delete after getting the car, it became quickly evident that the flow thru ventilation is poor compared to an early car, so I bit the backdate bullet.
Today a good friend/skilled mechanic and I completed the backdate on the '82. A few thoughts. Rather than using self tapping screws which are not too robust, we ended up cutting threads in the B pillar and using screws. It was a real PITA since extra drilling was involved to provide enough space for the screws but it is now very stout. For the rear latch, we ended up drilling the existing mounting holes and using riv-nuts. See pic. Since no vendor had all the hardware I needed (seals, missing latch, mounting hardware) I used pelican and Aase. I ordered the welting named above and it was perfect. The only change I made was cutting channels on the vertical pieces which are then nicely hidden by the horizontal. So the welting on the B would lay flat, I notched it on the inside which you can't tell by looking at it from either outside or in. I still need to paint the body trim pieces, so I just installed without, filling the mounting holes with body color paint. Also need to paint the used frames, but that will be another day. Considering the precise thread tapping and drilling needed for the taps and riv-nutsLbbgngnnhnh <-cat typing, it takes some good skill to do it right, which are two notches above my level. Breaking off a tap I can do no problem. This is the result ![]() ![]() Total time was 6 hours.
An air cooled refrigerator. ‘Mein Teil’ Last edited by RSBob; 08-29-2016 at 05:29 PM.. |
