64E04132 1984 MY
wp0ab0916hs121755 1987 MY |
My '77 930 Turbo has the following engine number: PS 1082001 does anybody knows whta it means?
Thanks, |
It certainly is not a factory number. That probably means the engine was built using a new unstamped engine case. The engine builder then stamped his own serial number.
Hi, I was wondering if somebody could decode this. I have a friend overseas who recently acquired a non-running 1970 911 Targa and would like to know more about the VIN and engine
VIN - 9110210041 Engine 6200107 I am not familiar with early 911s. He wants to know if the engine on the car matches the year of the Targa. Last time car ran was 2002. Thanks JQ |
Car is targa 1970E and engine 1970 2.2E
Engine No. 93010191400
Also has this stamped on the side 901.105.111.1R Cheers. |
Willcall, that is not the engine number or type number. There are detailed directions where to find the correct numbers posted earlier in this thread.
Lower right side of engine fan will be engine number manually stamped on case with engine type (930-09 for example) behind it. Grab a flashlight and check them out and post back what you find. Also, model year helps as well if you have the chassis. Good luck |
I just joined and am astounded by the amount of knowledge and expertise on these boards. I am hoping someone could help me out with some specs and info on the following engine code:
*6116180* This is what I have deduced from other posts: 6 - 6cylinder 6180 - production # |
6116180 1971 911T-C zenith carb or weber 40idt
Thanks pors1968!
Sorry, my bad.
666908* |
Original Motor?
Hi Guys,
I'm Looking At Possibly Buying A '77 911 Targa. I Was Wondering If This Might Be The Original Motor? If Not What Exactly Is It? Vin# 9117210101 Build Date 08/76 Engine #'s 911/85 & 6270241 Thanks In Advance For Your Help :) |
Most likely the original engine |
Another Engine Question....
Is This Motor A 2.7 Or A 3.0 ?
Owner Thought Car Had a '77 Carrera Motor Installed In The 90's Any Chance Of This Being A Carrera 3.0 Motor? Vin# 9117210101 Build Date 08/76 Engine #'s 911/85 & 6270241 Thanks In Advance For Your Help :) |
According to the Red Book (not always 100% correct)
The body would be 77 911S Targa US The engine was fitted in a 77 911S (US) 911/85 is a 2.7 for US 50 state |
case number ?
How about case # 3180259
68 L with sportmatic
Please decode my engine number
The engine code is 6451005
I think it's a '75 engine. It sits in a 1973 911T Thanks, Tom |
Please decode this engine number
Well, let me try this again!
Engine number 6451005 Please decode this one for me. Thanks, Tom |
| All times are GMT -8. The time now is 02:34 AM. |
