engine 6550043 6 cyl, 911s CA, 1975, serial 0043 can anyone tell me any additional info on this motor? Is it numbers matching? sorry I can't access the type at the moment. |
6550043 is type 911/44 165HP for 911S US Calif. so at least it is an S and not the 150HP 911 engine
#43 out of 1783, so very low. It almost seems out of place for the VIN, but it is difficult to know for sure without contacting PCNA and asking. |
Hello everyone, I have had this 77 911S for a while now runs awesome,quite quick ,excellent autocrosser ,I have updated to pressure fed tensioners and SSi exchangers. Now rumor was told to me this was a very good 73 cases with RS barrels and pistons. I would like some help to find out the facts,was told car was sold by Beverly Hills Porsche? vin#9117202819
engine#6133042 right hand case #901 101 102 7R do I have a 77 S coupe with a 73 engine case? thanks Greg |
77 911 US, VIN: 9117200001- 91172003388 Eng: 6270001-6276041 Type 911/85 73 911T US , VIN: 9113101501-9113103444 EEng: 6133001-6136092 Type 911/91 911/91: Bosch k-Jetronic (CIS),8.0:1 Compression Ratio, 140 HP @ 5,700 rpm, 148.5 f-p Torque @ 4,000 rpm |
As you suspected and according to the RED book, you got a mix: 77 911 US, VIN: 9117200001- 91172003388 Eng: 6270001-6276041 Type 911/85 73 911T US , VIN: 9113101501-9113103444 EEng: 6133001-6136092 Type 911/91 911/91: Bosch k-Jetronic (CIS),8.0:1 Compression Ratio, 140 HP @ 5,700 rpm, 148.5 f-p Torque @ 4,000 rpm |
Thanks for quick reply JJ911SC. What are the Porsche enthusiast thoughts, a good mix?? thinking of selling this car after 12 years of ownership and moving on to a 997 GT3 (love autocrossing) or should I find a good 77s engine and swap it out? true thoughts pleaseSmileWavy
Hello Gang
Thanx ahead of time!! 72' 911 T 911/91 6135270 VIN: 9112101160 |
911/91 6135270 1973 911 T USA CIS, not original to this VIN
VIN: 9112101160 1972 911T USA coupe |
Looking for the same help please...
6281933 930/04 Vin 91A0143843 |
engine is 1978 type 930/04 for a 911SC USA version
VIN is 1980, and fairly late in the year |
Thank you for the response!
The engine (6280001-on) was for a 911SC US 49 State fitted to a 1978, VIN: 9118200001-9118202436 Your VIN is a 1980 911SC US within the range 91A0140001-91A0144272 witch would be fitted with 930/07 (6300001-on) Note to self: djpateman is on on Sunday night... :D:):D |
Thanks for confirming. I'm not surprised at the engine swap but was hoping for a numbers matching setup.
Hi, new on here and I posted elsewhere just before, but it looks like this is where I should be. I am Australia based and have a South African delivered 69t coupe non-matching numbers. The engine in the cars number is 6522602 and I am trying to identify it. It currently has mfi and I am also trying to determine if by chance the mfi came with the engine. Any help much appreciated. Many thanks.
Type B had Bosch CD Ingnition http://forums.pelicanparts.com/uploa...1446380255.jpg |
Many thanks JJ. It was with a manual as sporto was 911/67? Cheers
Sorry one more question, is there any way to tell which country the engine/car was delivered in? Many thanks again.
Someone (probably djpateman) might know.
What is the car VIN? |
VIN is 119100160. I know its a 69t. cheers
| All times are GMT -8. The time now is 06:10 AM. |
