-   -   930S with embossed crest--anyone know? (http://forums.pelicanparts.com/porsche-911-technical-forum/132915-930s-embossed-crest-anyone-know.html)
81SCp 11-07-2003 03:50 PM
island911 -
if you are asking me how much - U$380.00. I thought that was pretty good. That's the wheel, embossed horn pad and adapter/spacer (looks like the pelican part PEL-SPEC-911).
bS
island911 11-07-2003 03:53 PM
Cool, thanks. Which dealer?
callipygian911 11-07-2003 04:16 PM
oh yeah, that's not embossed, as with the 968CS. but i assure you it IS definitely different than the one sold at pelican. it's actually flush with the surface of the wheel; it's inlaid and not merely glued on and sticking "out" as at pelican, which is far cooler IMHO, since that's how the ones from the factory came. oh how i wish wayne could get his mits on these...
island911 11-07-2003 04:21 PM
That does sound nice/better.
It seem to me that a person could inlay the crest themself. Just peel away the vinyl cover, and cut-away a recess for the crest, and recover. . . just a thought.
81 930 11-07-2003 04:26 PM
Well the suspense is killing me on this one. I just went ahead and ordered the 968CS horn pad from my local Porsche dealer. The list price at the dealer is $61.44. Of course, they don't have them in stock so it was a "special order" item. I will let everyone know when, and if, it arrives. I look forward to posting some pictures of it installed on my 930S wheel. My fingers are crossed!
SeaDweller 11-07-2003 06:31 PM
I'm waiting too!!!!!!!!!!!! :D
Otto 11-10-2003 11:07 AM
That part is in stock in the Fartherland,Otto
81SCp 11-10-2003 11:31 AM
island911 -
Sorry, been off-line trying to finish a bathroom tile job. The Porsche dealer is in Portland Or.
After talking to the parts manager, he's says it will not fit the way it is - 16mm shaft vs. an 18mm shaft on my '81 SC. He does believe that in '82 the changed, so some of you maybe in luck there.
Brendan
81SCp 02-21-2004 11:20 AM
Well I finally purchased the wheel from my local dealer who brought it in from Germany. It had the embossed crest and went on without problems and I love it! I did not need the use of an additional spacer as the distance between wheel and dash are perfect and in-fact the whole thing is perfect!
Just thought that I would let all know who were interested.
Brendan
http://forums.pelicanparts.com/uploa...1077391225.jpg
Wil Ferch 02-22-2004 11:13 AM
So...which shaft does this correspond to? Are there different part numbers for post and pre-82 cars? I'm confused....
---Wil Ferch
81SCp 02-22-2004 12:18 PM
Wil -
I am new to Porsche and have learned a lot from this BBS - so others will be more knowledgeable. But, I was told before there was a difference in shafts (see above thread) and that's why the 968CS wheel would not fit my SC.
However, this is a 930S wheel direct from Porsche and fits my 81SC. I know that others wanted to know if the horn pad would fit there 930S wheels bought from Pelican and I would be more then willing to take detailed measurements and photos if someone wanted to know if the pad would fit there previously purchased wheel.
bS
81 930 02-22-2004 12:49 PM
Brendan,
Out of curiousity, what is the part number of the wheel you ordered? The 968CS wheel is P/N 968.347.084.00, but it is not a direct bolt-on for an early 80's 911. Do you happen to have a picture that shows the hub adapter as well?
Thank you,
Brian
81SCp 02-22-2004 01:03 PM
Brian -
No pics other then what I posted - sorry! But, if some of you really want to see other shots, I may be willing to remove and photograph.
I have a PN - but, it my be the dealer's number 000-043-161-00-8YR - not sure.
It bolted right on to my 81SC!
bS
maxnine11 02-22-2004 01:29 PM
PET says the number posted above is "sport steering wheel"
8YR is the code for black
price list quotes about $440
max
81SCp 02-22-2004 01:41 PM
sounds correct then, but I paid about $60 less then MSRP :)
bS
ubiquity0 02-22-2004 01:49 PM
Brendan- could you possibly take a pic of the back of the horn pad? The pad on my 930s basically attaches to the horn ring setup with 3 plastic clips. I'm assuming that if yours is the same & the radius of the horn ring piece is the same then they are interchangeable.
thanks!
81SCp 02-22-2004 02:19 PM
Here is a couple of pics of the back of the horn pad. I hope this helps, if more or something else is needed - just let me know.
bS
http://forums.pelicanparts.com/uploa...1077488380.jpg
NoLift911 02-24-2004 01:47 PM
So what does the adaptor look like that came with this wheel? What dealer did you get it from?
-Jeff
nolift911@hotmail.com
ubiquity0 02-24-2004 02:02 PM
It certainly *looks* very similar to the pad on my 930s wheel. Can't quite read the calliper measurement but I think I'm going to keep waiting for the pad from pelican
aseem 02-24-2004 02:15 PM
Are you and Island looking at the correct item. Look two items down; thats definetively EMBOSSED
EDIT: It also has the long seam in the bottom spoke, and no seams or glued smaller patches on the two upper spokes as the AJ and PP items have
