97 degrees outside - 40 degrees inside
Some of you might recall my recent installation of a ProCooler and a condenser/fan assembly in the front left fender of my 84. Well, today was something of an "acid test."
It was 97 degrees outside today. I could feel the heat baking through the Targa top. I was still getting vent temps of 39-40 degrees. Given that the car is a Targa, and given the marginal P-car a/c to begin with, I think this is about as good as it's gonna get. Not gonna be able to hang meat in there, but I'm a happy camper nonetheless.
1984 Targa Last edited by scottb; 08-04-2004 at 12:04 PM.. |
Sports Purpose 911 Driver
I am thinking about adding a/c would you mind posting your experience/pics?
thx
James Shira R Gruppe # 271 1972 911 Coupe 3.8 RS ‘nbr two’ 1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie' 1955 356 Pre A Coupe ‘old red’ 1956 356A Emory speedster build in progress |
Could you provide some more details about exactly what you did regarding the front condensor fan assembly? Or is this in a previous thread?
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
88911: I bought an aftermarket condenser/fan assembly from www.iceac.com. I removed the washer bottle and vapor recovery tank, and installed the unit in the front left fender. The kit is not a "turnkey" arrangement, so brackets were fabricated. I relocated an aftermarket washer bottle into the luggage compartment, and replaced the vapor recovery tank with a catch can. The new fan is triggered by a relay wired into the existing front condenser fan. So, now I have three condensers; the two original ones from the factory and the new one in the front left fender.
1984 Targa |
My 86 3.2 gets down even lower on Propane instead of R12. Only problem I have is having my evaporator freeze up if I keep the t-stat set too low.
Joe |
PRO Motorsports
Joe, how safe is it to run propane? I'm intrigued by the this idea. It's cheap and effective, but it kinda scares me a little.
If you don't respond, I'll assume an arcing plug wire combined with a compressor leak sent you hurtling into the stratosphere in a mushrrom cloud.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Tyson, think about it...only 16oz of Propane in your entire A/C system. How many gallons of gasoline under high pressure with lines running all around a hot engine do you carry without a thought?
Besides, Propane is odorized, so you'll know if you have a leak in an instant. Just like when I'm camping, I know when the Propane bottle isn't screwed on the lantern correctly when I get that nasty smell. Anyway, it's been in my car now for about 6 months and I'm not loosing any sleep over it. Cheers, Joe Garcia 86 Carrera Redwood PCA since 1976 (former tech chair) |
I have heard of this use of propane before on this site and it does sound strange.
If it is so cheap and effective , why is it not used on a wider basis? is it less safe? Can it effect the life of any compressor parts? Is it worse for the environment? There must be a reason/some reasons why we do not use Propane on a wider basis. Please enlighten us Rgds` Ben
AKA "86ragtop" 1986 911 Carrera SOLD 11/2001 1984 Carrera 3.2 IROC RSR look |
Gee..I'd like to hear from fire professionals here. But my strictly amateur thought is that gasoline burns. Propane explodes.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
PRO Motorsports
Yeah, it can't be any more dangerous than those propane powered vehicles.
Certainly cheaper than R12! Is it as efficient as R12, or maybe even more-so? What would be involved in converting? Evacuating the R12, then drawing a vacuum for a good half hour. Then just charge it with a propane bottle hooked up to the standard gauges? What pressures would I be looking for?
IMO if a car is on fire, and nobody's in there, stay away unless your a pro. Exploding air bags, bumper shocks, batteries, toxic cyanides from interiors, etc., etc., etc...............Ron
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Yeah, everytime a car runs off a cliff on TV they always seem to explode. Must be all that explosive gasoline...
When was the last time you saw a Propane powered car or forklift explode? To convert, I had my R12 recovered at a gas station, pulled a vacuum and charged with it with a 16oz Coleman bottle that I picked up at Payless for $3.00. I also recalibrated my t-stat to keep the compressor engaged longer since the Propane runs colder than R12. Initially my idea was to run the Propane to make sure I got all the leaks and not waste a lot of money on R12 in case I scewed up. But, as it turned out, I like the way it runs on the stuff and do not plan on going back to R12. Joe |
Guest
Posts: n/a
I'm not here.
"Ahhh, sweet lady propane..."
"When do we say we can stop the Whole-Sale State-backed discrimination against straight white males? - island911 (This guy is insane, no?) |
Not Quite Banned
Joe - what oil are you running in the a/c system?
Thomas Owen 1972 911T 1972 911S |
Unconstitutional Patriot
If it is so cheap and effective , why is it not used on a wider basis? is it less safe? I understand propane/isobutane mixes are used overseas. I do not know to what extent. R-134a is reportedly a carcinogen, much to the chagrin of the plant workers overseas. I feel the risk of running propane is overestimated due to fear. Can it effect the life of any compressor parts? I have read that propane in the presence of moisture does not form a caustic solution, as opposed to freon. Is it worse for the environment? R-12 is claimed ozone-depleting. R-134a contributes to global warming. Propane/isobutane will break down in the atmosphere and does not destroy the ozone layer or contribute to global warming to the degree of R12 and/or R-134a. There must be a reason/some reasons why we do not use Propane on a wider basis. Please enlighten us Rgds` Ben Money. The only drawbacks to propane/isobutane, in my eyes: 1) Using this stuff requires you to be a DIYer. Few A/C shops will work with you. 2) If you have a leak and are using a blend of propane/isobutane, the only way to top off is to evacuate and recharge. 3) Propane/isobutane from the speciality shops is more expensive than r-134a. If propane was used more extensively, then things might change. Jürgen |
Thomas, I used the same oil the R12 used.
Joe |
I've used the propane/butane brew for two years. Same problem as Joe though, if the thermistat is set too low, the evaporator freezes up. With no other mods to a stock system, vent temps of 3 to 5C with outside temps of 35C.
Tim |
Tim, how did you get the Isobutane mix? I'm still on pure Propane but would like to bring my pressures down closer to R-12.
I thought the propane/butane cocktail was supposed to solve the freeze up problem. I found the p/t chart on Propane R-290: http://www.paceindustrial.com/chart1.html Joe Last edited by stlrj; 10-26-2003 at 10:29 AM.. |
Joe:
Go to the end of this link. It describes two methods. I use the direct fill method. http://vettenet.org/acfaq.txt Tim |
