Is there a required ambient temp range for engine rebuild?
Other than what I need to keep myself comfortable, is there a recommended ambient temperature range that the engine should be kept in during the re-build?
Should the engine be kept at this temp throughout the entire rebuild process or can I let it sit in colder temps, warm it up well ahead of touching anything, and then let it return to ambient until I work on it again? It'll see below freezing temps unless I find a place to keep it warm all winter. |
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Senior Member
Good question.
Not having an enviro-controlled room, I did the 'Bomber's motor in my (sometimes) frosty garage. Worked for us.
'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. |
You could work in a freezer if you wanted to...but for measurements (crank journals,rod bearings,etc.) the temp should be a nice 72 deg F.
If you look at most calibrated tools (micrometers,etc) you will see on the cal chart the temp they were done at. This is usually a lab environment at 72 deg. Remember...the colder it is the more it shrinks...so if you want to hit the correct sizes...you should normalise (everything at 72 for at least 24 hrs) before measuring. Bob
Bob Hutson |
Non Compos Mentis
Outside of the measurements stated above, as long as everything is the same temp, I think you should be okay.
I just wouldn't bring out the heads from the nice warm house and bolt them up to the cylinders that have been sitting in the freezing garage overnight. |
Irrationally exuberant
What about sealants? Will they harden OK in a winter garage?
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
What about in a temperature controlled class 100 clean room? You can build a better engine that way.
Caliber 1987 911 Cabriolet |
Perhaps you're not familiar with the concept of "shrinkage"? I believe there was a Seinfeld episode on the topic.
Mike 89 Carrera 3.6 V-ram #94 Livin' for Targa time! Want to make God laugh? Tell him your plans! |
Heck, I’m only 5 not 71!
I rebuilt my motor in a car port during November and December. It was dang cold the temperature droped to just below 60 when the sun went down. It also rained a couple of days but that had no effect on the motor running after the rebuild. Did I mention I live in SoCal.
Pat Henry Targa80 1980SC Targa (Mocha Brown) |
I think the one killer would be condensation. Avoid that.
Senior Member
Hi Tim!
Don't let the moose eat your seats over the winter!!
Doug:
Just spent a month in Ft. McMurray and have a true story on moose drool. I'll pass it on over a beer at the next Round-up. Tim |
The recommended temp range is with the garage closed, and the heat turned on.
Or, in southerm california where I did my engine rebuild, it was with the garage door open all night.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
