Where is that wrench?
Screw extractor help needed
After giving up on my stripped transmission fill plug I bought this:
It says to use a 17/32" drill bit. The hardware store I bought it at did not have a 17/32" drill bit. They weren't out. They didn't carry them! I went to a couple more hardware stores + Sears, and no 17/32" bits. I did find one at an auto parts store that said it was good for soft metals. I don't think that will do the job. Anyone have any suggestions on where to get a good 17/32" drill bit (either in Orange county, CA or online). I already tried Pelican of course.
Home Depot or Lowes? You might wanna try www.Grainger.com they should have that bit.
Rick
Rick '76 Carrera 3.0, track '77 3.2 targa, back home '95 993 C4 M030, SOLD PCA San Diego |
I believe you will find that a 9/16 bit would work just as well if not better. Measure the diameter of the extractor to see how deep a 17/64" diameter hole would allow the extractor to set and then measure a 9/16" hole the same way. With this type of extractor, you REALLY want it to go as far into the hole as possible. That way, when you put lots of torque on it, maybe, just maybe it will not break off in the hole.
Good Luck! Fred Cook '80 911SC coupe |
I have never had any luck with screw extractors. They really don't work. I don't know what is wrong with your plug but here is what I might try. Weld on a bolt to the drain plug and use heat on the tranny then back the plug out.
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
Platinum Member
There have been quite a few threads on proven methods to remove the fill plug. If you drill it out, how are you going to get the filings out of the transmission?
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Irrationally exuberant
A friend once told me "a screw extractor is a tool for replacing a hard to drill out bolt with an impossible to drill out screw extractor". Of course I had to learn that for myself...
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Senior Member
The only extractors I will use are the Snap-On ones. Mercifully the set is only like $30. But I would also agree with the above, that in this case I would try to avoid drilling the plug. When I do decide to try using an extractor, I use a REVERSE drill bit. Often, the drill bit removes the screw. And I take my time. I have had them break off, particularly the "arrowhead" ones like pictured above, and that's when problems REALLY begin.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Yeah the screw extractor set I bought from sears was a total waste of money. It hasn't managed to get out stripped screws from my kitchen cabinets, the 911, or anything else I've used them on. Worthless. They'll get out a screw that is stripped and not stuck, but if its not stuck, how did it get stripped?
1968 911L 2004 Dodge Dakota SLT Plus |
As far as a drill, try McFadend-Dale hardware in Santa Ana, off the 55 and edinger, IIRC. They have EVERYTHING! Chris |
Detached Member
If you have about 3/8" of the plug sticking out, go to Sears and buy a large clench wrench (sort of like a basin wrench, and you may be able to use the clench wrench to get the plug out. You will destroy the plug. At least that's how I got mine out.
Hugh |
13 or 14 mm drill bit might also work. Before you buy any large bit make sure it will fit into your drill. Most drills won't accept a bit larger than 1/2 inch.
Thanks, Mike When I was a kid, I didn't want a stupid pony, I wanted a PORSCHE. 1970 911T Coupe, 1979 911SC Targa Euro, 1971 Honda CT70 HK Trail 70 (the ultimate in two wheeled transportation) |
7/32" =.531 It is a standard clearance drill for 1/2" bolts. I wouldn't worry to much about the .03 on a hole for the extractor, especially if you are going to do this with a hand drill. You will likely wobble around more than enough to give you the .030 so a 1/2" drill should be fine.
Schleprock
I thought the fluted extractors like the above-pictured one were the better kind? Aren't the kind like these
the ones that break more often? Either way, the extractors are not all that reliable. I like Chris Bennet's description............. www.mcmaster.com has that drill bit. 17/32" is big! Looks like about $10. I'd go with the nut welding idea first though. That hand drilling can get ugly in a hurry. A good local repair shop should be able to help you out with the nut welding? Many of those corner garage kinda guys are pretty "resourceful" and knowledgable since they've seen so many different makes of cars.
Kevin L '86 Carrera "Larry" |
You'd likely use a Mig welder to weld a nut on. Any local mebers with a portable unit?
You could also use a oxy/Acet or TIG setup as well.
Warren & Ron, may you rest in Peace. |
