Where is that wrench?
EdT82SC's Avatar
Screw extractor help needed
After giving up on my stripped transmission fill plug I bought this:
It says to use a 17/32" drill bit. The hardware store I bought it at did not have a 17/32" drill bit. They weren't out. They didn't carry them!
I went to a couple more hardware stores + Sears, and no 17/32" bits. I did find one at an auto parts store that said it was good for soft metals. I don't think that will do the job. Anyone have any suggestions on where to get a good 17/32" drill bit (either in Orange county, CA or online). I already tried Pelican of course.
Ed T.
1982 911SC
Porsche Wallpaper
Old 11-13-2003, 12:20 AM
Silveresrty911S's Avatar
Home Depot or Lowes? You might wanna try www.Grainger.com they should have that bit.
Rick
Rick
'76 Carrera 3.0, track
'77 3.2 targa, back home
'95 993 C4 M030, SOLD
PCA San Diego
Old 11-13-2003, 02:50 AM
fred cook's Avatar
Cool A Bit hard to find.....
I believe you will find that a 9/16 bit would work just as well if not better. Measure the diameter of the extractor to see how deep a 17/64" diameter hole would allow the extractor to set and then measure a 9/16" hole the same way. With this type of extractor, you REALLY want it to go as far into the hole as possible. That way, when you put lots of torque on it, maybe, just maybe it will not break off in the hole.
Good Luck!
Fred Cook
'80 911SC coupe
Old 11-13-2003, 03:54 AM
I have never had any luck with screw extractors. They really don't work. I don't know what is wrong with your plug but here is what I might try. Weld on a bolt to the drain plug and use heat on the tranny then back the plug out.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 11-13-2003, 04:53 AM
Platinum Member
dad911's Avatar
There have been quite a few threads on proven methods to remove the fill plug. If you drill it out, how are you going to get the filings out of the transmission?
Old 11-13-2003, 05:53 AM
Irrationally exuberant
ChrisBennet's Avatar
A friend once told me "a screw extractor is a tool for replacing a hard to drill out bolt with an impossible to drill out screw extractor". Of course I had to learn that for myself...
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 11-13-2003, 05:58 AM
Senior Member
Superman's Avatar
The only extractors I will use are the Snap-On ones. Mercifully the set is only like $30. But I would also agree with the above, that in this case I would try to avoid drilling the plug. When I do decide to try using an extractor, I use a REVERSE drill bit. Often, the drill bit removes the screw. And I take my time. I have had them break off, particularly the "arrowhead" ones like pictured above, and that's when problems REALLY begin.
Mocha 1978 911SC. "Coco"
Old 11-13-2003, 06:42 AM
Yeah the screw extractor set I bought from sears was a total waste of money. It hasn't managed to get out stripped screws from my kitchen cabinets, the 911, or anything else I've used them on. Worthless. They'll get out a screw that is stripped and not stuck, but if its not stuck, how did it get stripped?
1968 911L
2004 Dodge Dakota SLT Plus
Old 11-13-2003, 07:29 AM
that is exactly what I would do, weld on a large nut and use the heat generated from the welding to crack the sucker loose!
As far as a drill, try McFadend-Dale hardware in Santa Ana, off the 55 and edinger, IIRC. They have EVERYTHING!
Chris
Old 11-13-2003, 08:10 AM
Detached Member
Hugh R's Avatar
If you have about 3/8" of the plug sticking out, go to Sears and buy a large clench wrench (sort of like a basin wrench, and you may be able to use the clench wrench to get the plug out. You will destroy the plug. At least that's how I got mine out.
Hugh
Old 11-13-2003, 09:09 AM
EdT82SC's Avatar
Chris
I've never welded anything beyond copper pipes. What kind of torch will I use to do this?
Ed T.
1982 911SC
Porsche Wallpaper
Old 11-13-2003, 09:30 AM
limble's Avatar
13 or 14 mm drill bit might also work. Before you buy any large bit make sure it will fit into your drill. Most drills won't accept a bit larger than 1/2 inch.
Thanks,
Mike
When I was a kid, I didn't want a stupid pony, I wanted a PORSCHE.
1970 911T Coupe, 1979 911SC Targa Euro, 1971 Honda CT70 HK Trail 70 (the ultimate in two wheeled transportation)
Old 11-13-2003, 10:01 AM
7/32" =.531 It is a standard clearance drill for 1/2" bolts. I wouldn't worry to much about the .03 on a hole for the extractor, especially if you are going to do this with a hand drill. You will likely wobble around more than enough to give you the .030 so a 1/2" drill should be fine.
Old 11-13-2003, 10:19 AM
KTL KTL is offline
Schleprock
KTL's Avatar
I thought the fluted extractors like the above-pictured one were the better kind? Aren't the kind like these
the ones that break more often?
Either way, the extractors are not all that reliable. I like Chris Bennet's description.............
www.mcmaster.com has that drill bit.
17/32" is big! Looks like about $10.
I'd go with the nut welding idea first though. That hand drilling can get ugly in a hurry. A good local repair shop should be able to help you out with the nut welding? Many of those corner garage kinda guys are pretty "resourceful" and knowledgable since they've seen so many different makes of cars.
Kevin L
'86 Carrera "Larry"
Old 11-13-2003, 12:18 PM
You'd likely use a Mig welder to weld a nut on. Any local mebers with a portable unit?
You could also use a oxy/Acet or TIG setup as well.
Warren & Ron, may you rest in Peace.
Old 11-13-2003, 12:57 PM
