SSI's for 3.6 mod
I've just learned that Pelican now offers SSI back dated heat exchangers for the 3.6 mod for our cars. Has anybody here have any experience with them?
Tom
Ice Green '77 Targa 3.6 w/ Steve Wong chip One Way To Get More Horsepower Is To Get A Bigger Horse! "I couldn't find the sports car of my dreams, so I built it myself" Ferdinand Porsche |
PATRICK MOTORSPORTS ALSO HAS THEM. YOU HAVE TO REMOVE THE AC CONSOLE AND SWITCH TO SINGLE CRANK PULLEY .SWITCHING THE CRANK PULLEY IS'NT A GOOD IDEA IN MY OPINION ,BECAUSE IT'S ALSO A HARMONIC BALANCER, AT LEAST IT DOES ON 95 3.6.
I have plenty of lead for my pencil... just not enough paper to write on.. 82SC with 95 993 engine 2004 Ford Powerstroke |
Are you saying this has to been done in order to run with the SSI's?
Tom
I also just noticed there is a mistake in the online catalog (I think) two left HE's and no right? Are these for 993's and 964's? What are the tube sizes?
SORRY FOR THE EARLIER CRIPTIC REPLY ROUXZY. THE SSI SYSTEM WILL FIT ,BUT IF Y OU RETAIN THE A.C. BRACKET IT MAKES THE ENGINE ABOUT 2 INCHES LONGER. TO USE THE SSI YOU HAVE TO REMOVE THE A.C. CONSOLE ,SWITCH THE CRANK PULLEY TO A SINGLE OR P.M.S. T YPE PULLEY. IF YOU HAVE A 95 UP ENGINE SWITCHING THE PULLEY PROBABLY IS'NT A GOOD IDEA, IT ACTS AS A HARMONIC DAMPNER. THE PROBLEM AS I UNDERSTAND IT IS .THE BANANA STYLE MUFFLER CONTACTS THE A.C. CONSOLE .YOU WOULD HAVE TO BACKDATE THE ENGINE CROSSMEMBER AND MODIFY OR BACKDATE THE FRONT SHEETMETAL. THIS IS INFO TO THE BEST OF MY KNOWLEDGE GUYS.
It would help if the picture link wasn't the same genaric link for all of the SSI choices. There are many places in the PP catalog where this sort of thing occurs.
If there is a pic link it is useless to have a genaric link and there ought to be more complete information as to the distinct properties of the parts in question. I know that this has stopped me from making a purchase more than once.
Senior Member
I am in the middle of this right now. Got Bill's old motor in my car ten days ago, then got a bad cold and have not touched it since.
Was able to hold the SSI's I used on my 3.2 up to the motor and they will not fit!!! Seems that on the the air duct for the heating hits on the back on both units and keeps them from being able to be bolted on the heads. Was going to look at B&B until I saw this thread. Would really like to know if SSI is making 3.6 versions now! Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Joe, they will fit if a hammer is appropriately employed.
I sent you this pic of the SSIs which were removed from that engine a few years ago. The hammer is gainfully used at the points labled A the flanges at B are just not used(I bent them down so as not present any possibility of a rattle. You will find that the pipe size is fine for street use but will strangle the engine at higher revs.
Senior Member
Bill,
Thanks again. I have so many pictures, schematics and such that I could not remember receiving them. Right now am looking for any RPM and not worried about running out of breath at high speeds! Joe
Still, someone needs to step up and clarify the listing in the Pelican catalog. What, exactly, are they selling?
Senior Member
My question is, with the "old style" of exhaust for the 3.6, would you have to have the "old style" (73 or so) oil line from the motor or the "3.6 style" oil line!
From looking at everything I believe that using the orginal type of exhaust for a 3.6 that it would not work with a "SSI" type of oil line. JoeA
If the SSI's are the same as modding the 993 heat exchangers flanges to fit the 964, why spend the extra $750?
1980 911SC Targa 3.6L |
w/ 993style? dunno never attempted that. B&B and SSI both want the same pre'75 911 oil lines
Moses, I agree with you. The orders probably won't flood in until there is a clear understanding of what fittment is being offered.
Not to add more confusion...wait, I guess that's exactly what I'm doing. I was told several months ago that SSI was working on a set that would work for increased displacement (based on 3.2l case) motors. Similar build but larger pipe diameter. Is this that answer? |
Author of "101 Projects"
Hi folks. It's really not that confusing (at least to me). The 3.6 versions offered are exactly the same as all of the other versions, with the tin modified to fit the 3.6 engines. At least that was what was told to me by the folks at SSI. The picture is the same for all of them, because they all look the same. Frankly, I can't tell them apart just looking at them. The pipe diameters are all the same across all of the heat exchangers - SSI has not increased the pipe diameter (despite calls to do so).
So, the 3.6 heat exchangers are SSIs that are slightly modified to fit the 3.6 engine conversions that are placed in older cars. According to SSI, the whole setup should allow you to use the stock muffler with little or no modifications. -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
