First Engine Drop: Almost Done
With the help of Pelican and Bentley I did my first pcar engine drop last week, 86 Targa 3.2. I used a homemade engine stand with castor wheels, and dropped the transaxle with the engine. The number 1 reason was to replace the guide tube. I found the guide was only slightly worn, BUT the plastic bushings for the TO fork were missing, and the fork was rubbing on the lip of the TO bearing, making shifts difficult.
The first three days were spend cleaning....what a mess! I've done engine transplants in old BMWs that were not half as nasty as this engine. OK, now to the point. The plugs were in good shape, so there is no excessive oil burning. In addition to fixing the clutch, I have adjusted the valves, replaced the fuel filter, new plugs, new bolts for the CV joints, new intake gaskets and phenolic blocks, and new rear shocks while the getting was good. I took off the tinware, cleaned, painted and replaced. The motor mounts and tranny mounts were new 6 months ago. What else should I do before I reinstall? TIA MFB 86 3.2 with 113K, all srock |
Engine Flywheel side main seal.
oil pressure warning switch O-ring oil thermostat O-ring Cam oil lines, left and right. clutch cable Your bushing (at the guide tube) was missing? I hate hackers PO.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Other things that are a pain with the engine in, so good to do now if you need them:
- sound pad - trailing arm to torsion bar tube bushings - decklid shocks (only a half-pain)
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
Unregistered
Crankcase vent gasket and hose if necessary.
If you want a copy of my list email me chrispetron@teamvanguard.com. I am in the same position and I made a list with part numbers of everything I should do while in there.
It has about 60-65 items on it. Took about three weeks to compile. a few tasty tidbits from a lot of people. The only thing "wrong" with my engine is the clutch needs to be replaced. Somehow though I am going to end up doing about $2500 worth of work to it.
'83 SC |
wasnt there an issue with a fuel rail or fuel line bursting on the 3.2's? Changing them was a pain if I remember reading correctly?
Chris |
Quote: "wasnt there an issue with a fuel rail or fuel line bursting on the 3.2's? Changing them was a pain if I remember reading correctly?"
Uh oh. Is this the start of 3.2 Urban Legend #3?
Warren & Ron, may you rest in Peace. |
Friend of Warren
Kurt V No more Porsches, but a revolving number of motorcycles. |
