First time spark plug change
I just finished my first spark plug change…seems to have gone well. I also changed the wires and distributor cap and rotor. I was a little discouraged at first as the plugs on the right side are a pain to get out…should have started on the left side. I did not have the Porsche tool but used a swivel socket as outlined in the 101 Book. I think next time I will buy the tool and give it a try.
Below is a picture of the plugs…not sure if anyone can give me any feedback on the condition. The car ran great beforehand but I’m not sure how long they were in the car…they have at least 18,000 miles on them. The car currently has 102,000 miles. V/r Wayne C. 83 SC
Also, one other question. The old plug wires (original) had an extra wire coming from the distributor and was grounded next to the coil The new wires, Magnecor, did not require...how come? TIA
Wayne C. 83 SC |
Make Bruins Great Again
Pardon the hijack but what is "the tool" you use to get the plugs out?
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
It'll be legen-waitforit
Wayne,
What plugs are they? They look a little white, could be fine or could be running too hot (incorrect plugs), and/or too lean. Just my two cents (CDN) as far as original wires if you are talking about the braided ones, these had ground wires on them.
Bob James 06 Cayman S - Money Penny 18 Macan GTS Gone: 79 911SC, 83 944, 05 Cayenne Turbo, 10 Panamera Turbo |
13/16 swivel spark plug socket, it has a rubber inset to hold the plug. Do not use just a standard 13/16 socket as the plug will fall out and it's a pain to get the spark plug out. The tool is $10 at Sears. You will also need a 3" extension. However, as noted, I'd try the Porsche tool referred to in other posts...others make it sound much easier.
Wayne C. 83 SC |
v/r Wayne C. |
Go Speedracer, go!
The ground straps were added by Porsche because they thought that it would prevent air boxes from cracking. At least that's what I have heard. Since the plug wires don't cause intake backfires, and don't cause the air box to crack, you don't need plug wires with ground straps. I also have magnecor wires and am happy with them. See below
1981 SC ROW Coupe |
On a great circle route
Spark plug tool from Porsche tool kit.
Russ |
That Porsche plug wrench makes the job extremely easy. What a simple, well-designed tool!
Sorry to borrow the thread, but speaking about tools, what is the tool that looks sort of like a big eye-bolt?
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
Go Speedracer, go!
1981 SC ROW Coupe |
The Porsche tool is great, but I prefer a 3/8" air rachet, it spins the plug out quickly and you can set it so that it will stop once it hit a pre-determine torque while spinning the plugs in. |
Good to know that, will look for the plug, never noticed one. Thanks.
Ya they look a little whitish, too hot a plug or too lean of fuel mixture. Wayne, if possible get the original plug tool and check them out after a thousand or two, that tool really makes removal easy.
Rick
Rick '76 Carrera 3.0, track '77 3.2 targa, back home '95 993 C4 M030, SOLD PCA San Diego |
v/r Wayne C. |
Go Speedracer, go!
1981 SC ROW Coupe |
Definitely try to get the Porsche spark plug tool. Its perfect for the job. WIth this thing you can whip all 6 plugs out & out new ones in in ~15mins.
CDiercks,
Your going to like the Porsche spark plug tool, it makes what you just did so much easier you won't believe it. You'll be changing plugs every week. Your plugs do look just a little whitish but not bad. I'm interested in backdating the heat on my 79sc, would you be willing to sell the left side heat duct that your no longer using? Gerard |
they look fine, just dont leave 'em so long between changes. 10-12k miles is enough for plugs.
Rich ![]() '86 coupe "there you are" |
